Yesterday somebody said something about a "raspberry pie". So when I got
home, I looked it up. It turns out Raspberry Pi is a kind of cheap,
minimal computer system. It's powered by a 700MHz ARM11, which
apparently is comparable in computational power to a 300MHz Pentium-II.
It also has some kind of GPU onboard, which HDMI output. It's powered by
USB, and the entire thing costs $35.
Naturally, I immediately asked myself whether you could build a cheap
render farm out of these things. Having uttered the words aloud, at
least one website about this subject must now exist. A trivial Google
query verified this fact; there are indeed *several* such pages. They
conclude that 100 Raspberries have roughly the same compute power is a
In summary, you *can* do this, but the price per FLOPS is very poor. Or,
it is if you use the *CPU*. My next question is what the hell happens if
you try to use the *GPU* instead. I haven't seen an answer to this yet.
(I also haven't looked very hard.)
Obviously the next important question is "can it run Haskell?" And the
answer is obviously "yes" - although it seems it's difficult to compile
anything particularly large on the actual machine itself, due to it
having "only" 512MB of RAM.
You know, when I first learned Haskell, 512MB of RAM constituted a
*very* high-end system. What the heck has the world come to when you
need more RAM than that just to compile some source code?
(Then again, I haven't tried it personally. Perhaps they mean it can't
really *huge* stuff like the entire Haskell compiler or something. They
don't really quantify what constitutes "big".)
The goal of this project appears to be to churn out cheap computers that
kids can mess around with to learn about computers and programming and
stuff, similar to the way I did with the C64 when I was a kid. Trouble
is, no kid today would find something as primitive as a C64 interesting,
with its piffling 16-colour graphics and monophonic sound.
And there's the rub. It's got to be modern and powerful for anyone to be
interesting. But if it's modern and powerful, it's going to be far too
complex to tinker with at the level you would with the C64. If you have
a C64, it's *feasible* to write a short machine code routine which
performs a key-scan and pokes the video hardware in response to
different key presses. You could, given a month of Sundays,
realistically build your own micro-OS.
*Nobody* is ever going to do that for a Raspberry Pi. It takes something
as complex as Linux to power it. Recall that Linux is the result of
decades of effort by thousands of expert coders across the entire world.
(And no, I'm not just talking about the kernel. The kernel, by itself,
doesn't give you a runnable OS.) Nobody has the time or resources to
write an entire OS in their spare time.
Similarly, with the C64 you can write a few POKE commands and watch the
screen turn green or hear a sound play or something. The GPU on the
Raspberry Pi are closed-source; you need to sign an NDA just to see what
registers it has! Nobody is going to be experimenting with that anytime
soon.
So, yes, it's a small hand-held computer with Python on it. But it's
basically a normal PC, but smaller and cheaper. The fact that it's a
bare PCB doesn't make it any more inviting to tinkering or whatnot. I
suspect most kids are being to be really disinterested in this thing.
Now, the big kids who should know better? They might find this
interesting...
> interesting...
I seem to remember someone (Clipka?) trying to get POV to run on one...
Also, aside from the propeller-head scene, sone of the obvious
applications for it would be as "single-function terminals" such as cash
registers, call-center agent sets, ticket booths (movie theatres, train
stations, etc...)
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
does it have a GPU at all? if it is there, it may be more underwhelming than
any in the cheapest smartphone out there. after all, it's not meant to run
games or smooth user interfaces, but to be tinkered by cli geeks... :)
> stations, etc...)
Media centers seems fairly popular as well.
Jim
Supposedly it's meant to have hardware-accelerated real-time MPEG and
H.264 decoding. It has HDMI output, after all...
It runs OpenGL and OpenVG, but I have no idea what 3D performance would
be like. Unimpressive, I would imagine. (Remember, they're trying to
make this thing cheap.)
>> stations, etc...)
Seems reasonable. I could use one as an SSH server, for example.
(For reasons unknown, a bazillion SSH *clients* for Windows exist, but
not one single *server* that doesn't cost £££.)
I must admit, I have no idea what that actually means.
Download RiscOS for it - far simpler than Linux (no protection or
multi-user) and very simple to write assembler within the built-in BASIC
interpreter. By default the stuff you write will run as a single-task
you have complete control over the machine. Also the whole GUI is
ridiculously fast and responsive as it was originally designed for ARM
processors under 50 MHz (the web browser is way faster than whatever the
one included in raspbian, although not as feature-rich).
You can issue poke commands from BASIC directly in RiscOS - IIRC ?<addr>
is a variable you can use to read or write a byte to that address, or
!<addr> to read/write a 4-byte word in one go. RiscOS BASIC also allows
you to drop into the assembler very simply and then obviously reading
and writing to memory is easily possible. The assembly language is
pretty easy to learn.
The version of RiscOS for the pi also contains new software interrupts
(that are easily called from BASIC) to read and write to the GPIO pins
on the PCB. The following program will output a square wave on one of
the pins (apparently at about 300 kHz).
REPEAT
SYS "GPIO_WriteData" ,17,1
SYS "GPIO_WriteData" ,17,0
UNTIL FALSE
> The GPU on the
> soon.
AFAIK they haven't managed to get GPU access in RiscOS yet. If you
wanted to do GPU stuff then you'd be better off with Linux, for example
I use mine mainly with xbmc as a media centre, plays 1080p videos fine
from an external drive through HDMI to a TV, so the GPU must be involved
somewhere.
Orchid Win7 v1 <voi### [at] dev null> wrote:
[SNIP]
Not true, have a look at
http://www.cl.cam.ac.uk/freshers/raspberrypi/tutorials/os/
> The GPU on the
> soon.
The GPU itself is closed source just as the GPU in your PC is.
Well, the Linux API is open so you do have a way to poke it and also the
framebuffer is available for bare metal programmers, AKAIK.
Does your PC have GPIO pins that you can access by simply writing '1' or '0' to
a file? I thought not. The Pi is the cheapest and easiest way to do physical
computing.
> I suspect most kids are being to be really disinterested in this thing.
There's actually a lot of kids writing their own stuff either in scratch or in
python.
> interesting...
Regards
Aydan
>>> cash registers, call-center agent sets, ticket booths (movie theatres,
>>> train stations, etc...)
Wrong. Cygwin comes with sshd based on openssh, and it costs nothing.
A PC that's hooked up to a TV to play audio/video.
Jim
It seems rather silly to install an entire Unix emulator just to run one
tiny application... but sure, I guess that works.
Perhaps the part I don't understand is "why would you ever want to do this?"
Then again, I also don't understand why anybody would ever buy "digital
picture frames"...
