POV-Ray : Newsgroups : povray.off-topic : Fruit flavours Server Time
13 May 2026 15:03:06 EDT (-0400)
  Fruit flavours (Message 71 to 80 of 90)
Subject: Re: Fruit flavours
Date: 26 Mar 2013 08:31:15
Message: <51519513$1@news.povray.org>
On 26/03/2013 11:20 AM, scott wrote:
> On the Acorn there was no concept of CPU load as we have today - the CPU
> was always running at 100%.
Interestingly, this is apparently how MS Access 97 works. It always uses
100% CPU. Because, in 1997, busy-waiting was an acceptable design decision.
http://www.youtube.com/watch?v=dOV5WXISM24
Date: 26 Mar 2013 08:58:08
Message: <51519b60$1@news.povray.org>
On 26-3-2013 11:25, Orchid Win7 v1 wrote:
> Interestingly, there were several virus scanner programs for the Amiga,
> so clearly there were viruses around. I guess without the Internet, it's
> just that much harder to catch one...
They were spread through the exchange of floppy disks I seem to remember
from my Amiga days ;-)
Date: 26 Mar 2013 12:09:04
Message: <5151c820@news.povray.org>
That's probably why I never saw an actual Amiga virus. I didn't have any
friends.
Date: 26 Mar 2013 17:06:07
Message: <51520DB1.5060706@gmail.com>
>>> The mouse was drawn as a hardware sprite overlay, so moving the mouse
>>> pointer involves poking new coordinates into some video registers. This
>>> takes a handful of compute cycles, and is easily implemented by a single
>>> interrupt handler.
>> IIRC it was not even that. I don't have my hardware books lying around
>> anymore, but I think the horizontal and vertical motion of the mouse was
>> determined by two bit gray codes. These two bits were directly connected
>> to the video chip and the coordinates of the mouse were updated in
>> hardware. No interrupt required.
> I'm pretty much certain that's not correct.
well, they were directly connected to Denise and there were hardware
counters in Denise for X and Y.
> Under sufficiently heavy CPU load, the mouse pointer became slightly
> less responsive. There's no reason for that to happen if it's all
> implemented in hardware.
I can not find the logic circuit of Denise, so perhaps you are right and
the contents of the register had to be fetched and put in the mouse
sprite x and y.
>> At the user level it was not fully preemptive. You had to do an explicit
>> call to allow other programs to get some time too.
> What in the world makes you think that?
Because I have written programs at that level.
It is a great way to avoid a busy wait on an event in a high level
language. Just check if your condition is met, if not pass control back
to the scheduler. Repeat until you have something to do.
What I remember from those days is that a process could be interrupted
by a higher level process, but user programs ran until they voluntary
gave control back to the scheduler.*
> If you run two programs that
> both try to use 100% CPU, they both end up getting approximately 50%
> CPU. (And everything else becomes fairly slow.)
Because all programs you used behaved decent and passed control to the
scheduler regularly? Remember we are thinking about a multitasking
single user machine. There is no point in annoying the user by not
giving other programs a change to run. There is not even a point in
trying to get more than your fair share. But see the note below.
*) trying to google things, the wiki page on Exec_(Amiga) claims that
linus once mistakingly said that AmigaOS was cooperative. In earlier
versions of this page it *was* apparently considered cooperative,
because google quotes a text that is no longer there. Another source
says that the first version of AmigaOS was cooperative, implying that
later versions weren't. Possibly I have been programming the earlier
version and later versions indeed were fully preemptive, but the system
calls still worked, so I did not notice the change.
For what I needed cooperative multitasking was exactly what I needed.
E.g I had a multichannel dataacquisition running on a PC that was
connected to the Amiga over a parallel port. I had one channel live in a
separate screen** and a data analysis program that could use the same
parallel connection to get the full data of a part of the recording. On
the Amiga side I had several programs running, all cooperatively,
including the parallel communication program (a sort of device driver
but at user level). On the PC side I had to solve it with one big event
loop.
**) for the non-amiga users: the Amiga was able to display several
'screens' at the same time. Each with its own resolution and color
depth. Transistions between screens were always at a horizontal line and
the display line where that happened was handled by another custom chip.
You could move a screen in front of another revealing or hiding as much
as you wanted.
Date: 27 Mar 2013 04:34:57
Message: <5152af31@news.povray.org>
> friends.
LOL. I didn't meet any virus either but at work one guy was a huge
collector of all kind of more or (mostly) less legal copies of Amiga
software, and he regularly struggled with virus problems.
Date: 27 Mar 2013 06:56:22
Message: <5152d056@news.povray.org>
On 23/03/2013 8:48 PM, Jim Henderson wrote:
> On Sat, 23 Mar 2013 20:23:19 +0000, Stephen wrote:
>> I never really took to Willie R. Too much of a middle class snob to my
>> mind. He was funny, though.
> I don't know much about Willie other than that I found him funny on
> Clue. :)  But he often had one-liners that would just bring the house
> down, and even the other guys who were on the team at the time just don't
> have the comedic sense of timing that he did.
I’m sorry, I thought that I had replied to you. I had a BSOD which wiped
my own memory as well.
I grew up thinking Willie Rushton was the bee’s knees. Then, as I grew
aware of the world, I found his right ling views unpalatable. I can’t
hear recordings of him now without hearing a pompous, self regarding,
smart arse, too full of his own self importance. But he was funny.
> About the closest they come now to that kind of timing is in the game
> Word for Word, when (almost always as the second word), Tim will say
> "Pardon?" and then the other player will repeat what he said previously,
> to which Tim says "No, that was my word."
> That one makes me chuckle every time, even though it's entirely
> predictable.
I thought that it was Graeme who did that.
>>> And Humph.  Jack's getting the 'curmudgeon' routine down well,
>>> but nobody does it the way Humph did.
>> That is Jack Dee's normal persona. He does well but Humph had years on
>> the rest of the team and could look on everyone with the contempt of an
>> adult with adolescents. He does very well but he is a youngster amongst
>> giants. I think that in the long run they would have done better picking
>> someone else as the chairman, someone with a different style. Maybe
>> supper nannie. ;-)
> Yeah, I've seen Jack on QI and a few other things (Kingdom, IIRC), and it
> does seem to be something even his characters have in common with him.
> But I don't know who else they could've picked - they couldn't "promote"
> any of the panelists because that just wouldn't work - that group of
> panelists works well together,
Indeed that is true.
> even with the floating guest spot (which
> they really should just let Rob Broydon fill full time),
I like the variety, one day they might get Nicolas Parsons.
> but putting
> Barry or Graeme in charge (I couldn't see Tim doing it) would change the
> entire dynamic.
> But I think Jack does his own thing - he doesn't try to be Humph, and
> that's a good thing.  I think if he did that, it wouldn't work at all.
> His demeanor is similar, but also distinctly different.
He does the best at an impossible job - filling Humph's boots.
Regards
Date: 27 Mar 2013 07:13:48
Message: <5152d46c$1@news.povray.org>
> sprite x and y.
That was my understanding. The hardware may well be in the same chip,
but it's under software control. (Like I said, it only takes a few
op-codes to copy the X and Y coordinates from one pair of registers to
another.)
http://en.wikipedia.org/wiki/Exec_%28Amiga%29
"Exec is the multi-tasking kernel of AmigaOS. It enabled pre-emptive
multitasking in as little as 256k of memory (as supplied with the first
Amiga 1000s). Exec provided functionality for multi-tasking, memory
allocation, interrupt handling and handling of dynamic shared libraries."
Sounds pre-emptive to me...
In particular, like several other fully pre-emptive systems, Exec
provides Yield(), which lets you relinquish the rest of the current
quantum if you wish. However, if you do not call this, a hardware
interrupt causes Exec to perform a context switch to the next runnable
task, in round-robin fashion, whether you ask for it or not.
Indeed, were Exec not pre-emptive, there would be no need for Forbid()
and Permit(), which disable and enable pre-emption. (It's apparently
used as a crude form of critical section.)
Now, if you mean that a lower-priority task can never run until all
higher-priority tasks go to sleep, then yes, that's how the scheduler
works. Usually the very high-priority tasks were things like the
keyboard scan, which run for a tiny amount of time and then sleep again.
Date: 27 Mar 2013 17:42:00
Message: <515367a8$1@news.povray.org>
That's a shame.  I feel kinda the same way about Jeremy Hardy, even
though his leanings are similar to mine (but a bit more to the left).
There are places where comedy and politics play well (and he uses this to
great effect on The News Quiz), but other places where it doesn't belong.
>> previously, to which Tim says "No, that was my word."
>> predictable.
That could be.  It's usually late when we're listening. :)
>> even with the floating guest spot (which they really should just let
The variety is nice - it was fun to listen to a show from series <mumble>
with Sandi Toksvig on it.  She made a joke about being proud to be one of
a long list of female guests they'd had on the show, and it went over
very well. :)
>> but putting Barry or Graeme in charge (I couldn't see Tim doing it)
>> would change the entire dynamic.
That's the truth, no mistake about that.
Jim
Date: 28 Mar 2013 06:20:17
Message: <51541961$1@news.povray.org>
It is not a problem, nowadays. ;-)
True, some comedians have only one string to their bow. We had one, who
died this month, whose act consisted of speaking as if his microphone
was intermittent. He got thirty years of work out of it.
I know, that late night interference on the shortwave radio can be
dreadful. :-P
> very well. :)
That must have been the series when H&D did Hogmanay at the Big Hoose.
Regards
Date: 28 Mar 2013 13:28:06
Message: <51547da6@news.povray.org>
>> to great effect on The News Quiz), but other places where it doesn't
>> belong.
Can't fault him for continuing to do something that works. :)
> dreadful. :-P
It's pretty awful, I will admit. :)
>> <mumble>
>> of a long list of female guests they'd had on the show, and it went
>> over very well. :)
H&D?
Jim
