POV-Ray : Newsgroups : povray.off-topic : Basic arithmetic Server Time
13 May 2026 13:33:50 EDT (-0400)
  Basic arithmetic (Message 11 to 20 of 39)
Subject: Re: Basic arithmetic
Date: 13 Mar 2013 08:53:05
Message: <514076b1@news.povray.org>
Orchid Win7 v1 wrote:
> But hey, that's Unix all over. Don't expect there to be any reason or
> rhyme to it, just memorise this crap.
No need to memorise such things. There is always the manual. There are
more important things to learn about UNIX than that. And if an exam
testing your UNIX knowledge in general _requires_ you to know -e without
giving you access to the manpage of RPM, then this is a clear indication
of the quality of the exam itself.
Date: 13 Mar 2013 15:43:55
Message: <5140d6fb$1@news.povray.org>
Le 2013-03-12 15:23, Orchid Win7 v1 a écrit :
> The LPI website seems to indicate that /subjects/ are weighted, with
> more important subjects getting more questions. This seems to imply that
> each individual question is worth the same amount.
Back in the days where I was Cisco certified, not only were the sections
weighted, but the exam questions focused on the stuff you didn't know.
2-3 questions per main area... then delve into the ones you failed to
see if you were just unlucky with the first questions, or if you really
don't have a clue.
This is why you hear:
"it's all about subnetting"
"I had 20 questions on MPLS switching, you?"
"Me?  every second question was about IPv6"
etc...
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 13 Mar 2013 16:28:05
Message: <5140e155$1@news.povray.org>
Well, that's the thing. In the Real World, it's trivial to look up what
some specific obscure option does. It's arguably important to realise
that a particular command offers a feature, but remembering the actual
switch to turn it on is something you can easily look up if and when you
ever actually need it.
On the other hand, what else can they put in the exam? They have to ask
you questions about *something*...
Date: 13 Mar 2013 16:30:10
Message: <5140e1d2$1@news.povray.org>
On 13/03/2013 10:37 AM, scott wrote:
> Were they all proper questions with only one correct answer, or did it
> include stupid wordy answers that you can only get all the marks if you
> write exactly all the keywords and phrases they have on the answer sheet
> (of course you get no marks for valid answers not on their sheet)?
The majority are multiple-choice, with 5 options. (And if one of the
options is "none of the above", this is almost ALWAYS the wrong answer!)
There were about 6 questions which require you to type something - the
name of a command or the absolute path to a file, or perhaps one command
switch. Stuff which is extremely easy for a machine to verify.
Date: 13 Mar 2013 17:52:09
Message: <5140f509$1@news.povray.org>
Removing a package is, arguably, not an obscure option one would use
occasionally.
I had a similar debate with a physics prof once in college - the course
was for engineering students, but I was a CS student, so I'd have
reference materials available to ensure that I was coding the forumulas
properly in my simulation - and if I didn't remember the exact formula
for calculating lift based on a particular airfoil shape, I wouldn't
guess, I'd look it up.
"Not good enough".
And of course, I lost the debate, because it was the professor's class
and he got to decide what was important and what wasn't.
Years later, it occurred to me that he did have a point (though I still
maintain he was applying it incorrectly by assuming all students were
engineering students and grading everyone as such, but that's a separate
issue).  There are some things that, while you *can* look them up, if
you're competent, you should never *need* to look up.
Remember that a certification exam is a measure of a minimally qualified
candidate to do a particular job or task.  A minimally qualified
candidate on Linux *should* be able to install/remove packages without
having to look the command up every time they do it.
Jim
Date: 13 Mar 2013 17:52:46
Message: <5140f52e$1@news.povray.org>
Some companies still use such adaptive testing, but it requires a very
comprehensive beta on the exam.
Jim
Date: 13 Mar 2013 18:19:23
Message: <5140fb6b$1@news.povray.org>
> occasionally.
Sure. But usually you wouldn't use rpm -e, you would use one of several
far more user-friendly tools such as Yum or Zypper or whatever.
The problem being that the exam requires you to know how to use every
possible package manager of every possible distro, not just the one you
actually use every single day.
If you ask me how to use Zypper, I can answer that. I use it all the
time. But if you ask me how to work, oh, ANY OTHER SYSTEM, I'm probably
not going to know the answer. But if some day I need to use one, I can
easily look this stuff up, and if I end up using it a lot I'll quickly
stop needing to look this stuff up.
I understand that it's important to know how to use different package
managers. I just disagree it's necessary to know every single one of
them to the level of detail where you've memorised every single option
and flag available. You're only going to do that for the one particular
system you use regularly.
Then again, I guess I should just be thankful there weren't more
questions about Vi. Do you know, the other day I had 3 LPIC-1 certified
staff crowding around my monitor, and between the four of us we couldn't
work out how to copy and paste a chunk of text using Vi...
Date: 13 Mar 2013 18:33:33
Message: <5140febd$1@news.povray.org>
>>> what some specific obscure option does.
>> occasionally.
Except those tools aren't common across multiple distributions.  'rpm' is.
And if you're trying to manage it in a distro-agnostic way, then you'd
use the more common tool.
>> qualified candidate to do a particular job or task.  A minimally
>> qualified candidate on Linux *should* be able to install/remove
>> packages without having to look the command up every time they do it.
It's a generic Linux exam - so yes, it's going to ask about things
relating to different distros.
If you want a certification that's for a specific distro, you get that
from the maker of the distro (a CLP from SUSE, a RHCE from RedHat, etc.)
The point of the exam is to measure a minimum set of necessary skills,
though, and for LPI, that's a cross-distro certification, so it's - by
its very nature - going to look for things that are broader than "on
openSUSE, what command would you use to remove a package".  That kind of
question doesn't meet the goal of being about general Linux knowledge.
"What general command do you use to remove an RPM?" does meet that
objective.
It's important to learn according to the learning objectives for an exam
when preparing to take the exam.  There is, in fact, an entire ISO
standard devoted to creating learning objectives so an exam can be
created independently from the content - both derive from the same
learning objectives.  (ISO/IEC 17024 in case anyone's interested.)
It's not "every single option", though, it's one of the more common
options one would use.
Or indeed on how to exit it when you've finished. <scnr> ;)
BTW, well done on the exam score. :)
Jim
Date: 13 Mar 2013 18:43:52
Message: <51410128$1@news.povray.org>
It sounds like you are enjoying your job.
And doesn't everyone outside of academia know that the exam system
sucks? Now, the education system "teaches" to pass exams not to educate.
A vicious circle that dilutes any benefit that being able to read
without moving your lips, gives.
Regards
Date: 13 Mar 2013 18:51:53
Message: <51410309$1@news.povray.org>
That's certainly true.
Not always, but usually in academia it's been my experience that that's
true.  In uni, most exams are not vetted as well as a certification exam,
and the professors/teachers aren't trained in psychometric analysis, item
analysis, or how even really how to write good questions that measure
learning effectively.
LOL
Jim
