POV-Ray : Newsgroups : povray.off-topic : Eve Online Battle of Asakai Server Time
5 Feb 2026 02:35:49 EST (-0500)
  Eve Online Battle of Asakai (Message 1 to 8 of 8)
Subject: Eve Online Battle of Asakai
Date: 28 Jan 2013 19:34:25
Message: <51071911$1@news.povray.org>
Evidently this was a big enough event to register in places not devoted
to gaming.  I watched one of the posted videos, and it looked like every
ship parks and fires until it is either destroyed to bails out of the
fight.  Since I don't play it appeared as a rather confusing mess.
My only questions at the moment (for those who actually play the game) are:
* From time to time there are flashes that look like balls of pink
lightning.  Are those ships being blown up, or something else?
* If one ship fires on another, are non-targeted ships along the line of
fire in danger of being hit?
*It looks line maneuver is not a terribly important part of fleet combat
in this game.  Is that appraisal accurate?
John
Subject: Re: Eve Online Battle of Asakai
Date: 28 Jan 2013 23:53:04
Message: <510755b0$1@news.povray.org>
Well, I have never played Eve Online, but seeing as how nobody else has
replied, I may as well provide some blind speculation.
I'd guess those are ships either warping in or out of the area.
Keep in mind that the ships in Eve Online have vastly different sizes,
as illustrated by this image:
http://twitz.brainthink.com/assets/images/EVE_Shipchart_Apocrypha_Edition.jpg
(warning, 5250x10800 pixels)
Most everything I could see the video I looked at were the larger ships,
which are probably not very maneuverable.  There could well have been a
swarm of more agile ships darting around in there that were too tiny to
really see well.  Or maybe in a battle this size small ships are less
helpful, I dunno.
Date: 29 Jan 2013 17:59:55
Message: <5108546b$1@news.povray.org>
> Regards,
> John
Very large ships need to use a different method of warping in, so, yeah,
that may be the case with the pink things. I can't remember ever seeing
them myself.
I don't think the game mechanics takes into account line of fire, but I
can't be 100% certain. I have never been in big fleet battles, save
where its been me in one little ship, trying to deal with masses of
NPCs. However, I think the only thing accounted for is your own motion,
and how that effects their odds of hitting a target. In fact, I am
fairly certain of this. I have shot "through" large objects, like
asteroids, to hit targets on the other side. The game really doesn't
care what is in the way, just what you are shooting at. I have no idea
if an obstruction might make you miss more often, though, I doubt it.
No, maneuvering isn't really even possible. You have basically three
options - orbit something, which makes you a bit harder to hit, but also
plays havoc with targeting at the extent of your ships range (you may
keep losing locks), and puts you at risk, in an NPC battle, of catching
the attention of another group of ships, which you haven't entered
detection range of yet (which can be really bad, if your ship isn't able
to fend them off, because even if you manage to warp out, when you come
back *all* of them will be paying attention). Warping out can also be an
issue, because some enemies may be carrying warp scramblers, which makes
it nigh impossible to get away, or they may equipped with stasis webs,
which low you down, so you are easier to hit. Combine both, and you may
be blown away before you have a chance to kill which ever ones have the
warp scrambler on them.
The last method is "kiting". This basically works by having a smaller,
faster, ship, and heading out from the combat area, as fast as you can
go. The slower ships, even if they follow, can't a) keep up, or b)
successfully fire, at the ranges you widen, and you can, in theory, pick
off the smaller ones, before concentrating on trying to take out some of
the bigger ones. But, this doesn't do you much good, unless you tank,
whether it be your shield system, armor, or structure, and the repair
systems that maintain them, are up to keeping them from stripping you
bare. Large ships often have missiles, so their range is greater, and
their guns, if they do get a hit, can rip through you pretty fast. So..
you either go for high speed, and avoid being hit, but poor firepower,
of you go more balanced, add in a lot of stuff to maintain your
defenses, and hope you don't get mobbed by more than you can handle
(hence the "don't orbit things stupidly in an NPC mission, where there
are 4-5 fleets sitting around, waiting to notice you). ;)
So, I would say that maneuvering isn't just not important, its almost
meaningless. Other than things like, "When do I launch bombs, so they
hit the opposing fleet.", or, "Do I launch drones now, and risk the
other guys bombs frying them all, before they even get there?", and
other "range based" decisions making. Otherwise, it mostly comes down to
speed, and defenses, and whether or not you can hold out, against an
enemy, longer than they can. And, for fleet combat, PVP, instead of NPC
missions, the odds are that things will be rigged to do mass damage,
fast, with little reserves, which means, the biggest worry for most
people will be if their capacitors drain down, to the point where repair
systems, and others, stop running, before they take out their opponents.
Two apposed fleets, with an even match, and really well rigged systems,
can pound each other for 20+ minutes, and never get past defenses, right
up until one of them does something stupid, like activating something
they shouldn't, or they actually do finally hit the limit an recharging
their capacitors, and those defensive systems start going offline. There
have been cases, in the tournaments, where the winner was declared
"solely" on one team managing to destroy 1 ship more than the other,
because, other than that one ship, neither one faltered, until the timer
on the round ended. Needless to say, like car racing, these rounds where
deemed "boring". lol
Oh, and, graphics have been adjusted a bit, each update, so its hard to
say if the stuff in any given, unless recent, Eve movie/trailer actually
looks the same as it now does.
In any case, its almost all about ranges, rigging, and if your skills
give you an edge. Well, that, and who you kill first, so you have less
fire coming at you.
Date: 29 Jan 2013 18:19:03
Message: <510858e7@news.povray.org>
> helpful, I dunno.
Actually, the opposite. Larger weapons systems, like the ships, are much
slower. A small frigate, especially rigged with some extra speed, may
literally ***never*** get hit by a large carrier, or the like. Think -
'so small they are evading our turbo lasers' lol The drawback being that
you either need a huge mess of them, or you need the bigger ships on
your side to be hammering the target with heavy fire, so that the weaker
attacks from the frigates can penetrate the defenses.
Also, there are "drones" and now "fighters". Both of these are bloody
small, and, in the case of drones, they range from adding extra defense,
to extra repairs, to energy transfers, etc., as well as attacking,
depending on the type of drone. So, you are likely to see stuff so small
that its not even visible to most smaller ships, buzzing around, and
high speed, in there.
Hmm. There is this:
http://wiki.eveonline.com/en/wiki/EVE_Visual_Effects_Cheat_Sheet
But, not seeing "pink" in there. So, not sure what that flash is.
No, wait - its "smart bomb", here is another page with a better list:
http://wiki.eveuniversity.org/Identifying_Visual_Effects
Smart bombs basically detonate at a set range, and take down shields
**very fast**, while doing some damage, I think, to armor as well. They
however need to be used at range, and there are not so smart in the
sense of hitting only the enemy. They will hammer *everyone* in range of
the detonation, friend of foe. Often, they are used, in mass, to send
out a wave of explosions, into the path of an approaching fleet, in
hopes that they catch a) any drones that have been launched (it will
vaporize them just about instantly), or b) frigates, near the front edge
of the attackers, which would have less defensive ability, and may not
be able to repair the damage/recharge shield, before they hit firing
range on your own fleet. And, those long range, really slow, will never
hit your frigate when orbiting a huge ship, guns... **will** hit your
frigate, at 15k+ away from the enemy (while you, probably, won't be able
to hit jack, in a frigate, until like 5k from them, or closer.) That is
an awful lot of space, even at high speeds, to pass through, with your
defenses ripped up by a smart bomb.
Date: 29 Jan 2013 18:28:58
Message: <51085b3a$1@news.povray.org>
Ok.. I take it back "some" of those might be smart bombs, but.. holy
shit!! a lot of big ass command/carrier ships jumped into that mess. The
super-big pink flashes, which generate a big distortion when they
happen, have got to be jumps. Its the only way such huge ships can move
from point a to point b, outside their own systems, they have to
literally carry their own jump gate on them.
Date: 29 Jan 2013 18:33:25
Message: <51085c45$1@news.povray.org>
Or, not.. Damn, is confusing in that battle. I am not seeing new ships
showing up, so.. its got to be smart bombs, and like bloody close range.
But, ugh. what the hell do I know. lol
Date: 30 Jan 2013 00:54:38
Message: <5108b59e@news.povray.org>
...ugh.  Changed my mind about wanting to try out EVE again, from your
description of what can and can't be done in combat.
Looking forward to Elite: Dangerous!  XD
Tim Cook
http://empyrean.sjcook.com
Date: 30 Jan 2013 12:14:45
Message: <51095505$1@news.povray.org>
> Tim Cook
Well, its sort of understandable, when you consider the reality of what
they have to keep track of already. The specific video being discussed
here actually a) hit the time dilation limit of 10%, b) crashed the PS3
game in BETA, called DUST 514, which is now tied into the Eve universe
(You can buy mercs on planets, and provide planetary bombardment for the
troops on the ground, if your ship is rigged with the correct weapons
for it at this point), and it had as many as 3,200 people involved, at
one point, though there is some dispute as to how many of them where
"in" the system. Sector 0, which is where it took place, is usually not
running on the highest end servers, unless someone has clearly warned
CCP that such an attack is likely, so the servers where just not in a
state to handle things effectively. If you had to have those servers
track details, like object occlusions, during weapons fire, and other
factors.. the data involved would grow even more, and it would take
probably half as much as was involved in this mess to grind things to a
near total halt.
In fact, its purely the fact that they added the time dilation effect,
at all, that kept the server itself from going down entirely, like they
used to, not long ago.
That said, I am not sure how much good more accurate maneuvering would
do anyway. I mean, as much fun as it might be to hide behind an object,
to avoid fire, and maybe warp out/break locks, or webbing, etc., its
actually fairly rare that a) you have situations where that would be
available, or b) large enough fleet battles happen that you could use
other ships to block/break/etc. someone else's fire, or other effects on
you.
