POV-Ray : Newsgroups : povray.off-topic : Learning C# Server Time
13 May 2026 16:30:03 EDT (-0400)
  Learning C# (Message 13 to 22 of 32)
Subject: Re: Learning C#
Date: 29 Sep 2012 06:27:58
Message: <5066cd2e$1@news.povray.org>
On 28/09/2012 09:27 PM, Warp wrote:
> Orchid Win7 v1<voi### [at] devnull>  wrote:
>> Heh. It amuses me that run-time polymorphism via inheritance is /the/
>> central contribution of the OO movement, and here I am reading a book
>> warning me not to use inheritance under any circumstances unless
>> absolutely unavoidable...
> Does it explain why?
In most OO languages (e.g., Java, Eiffel, Smalltalk...) you can override
any method. Java adds a "final" keyword which you can use to disable
overriding on a given method (presumably resulting in a small
performance benefit). Eiffel of course achieves the same thing
automatically using whole-program analysis - then again, Eiffel doesn't
support dynamic code loading like Java does.
Regardless, C# turns this backwards. In C#, by default you /cannot/
override anything, unless you explicitly turn it on by writing
"virtual". Meaning that if the author of some class didn't foresee the
potential need to subclass it, you may not be able to override the
necessary methods.
But that's nothing. According to the author of this book, you should
mark all classes as "sealed", preventing them from ever being
subclassed. Every class should be sealed, and no methods should be
marked virtual, unless absolutely necessary.
Apparently it is "very hard" to design a class in such a way that it can
be subclassed correctly. So you should only allow this possibility where
a class has been explicitly designed with the intention of being
subclassed later. In all other cases, you should disable subclassing,
because if you didn't design for it, it won't work anyway.
All of which strikes me as a little baffling. I mean, I know that
inheritance is overused and collaboration is underused. But this just
seems excessive!
Then again, this is from the same book that explains how to write
destructors (i.e., "don't") before explaining how to write methods with
named arguments. The former is an obscure and very dangerous feature
which you should never use, under any circumstances, ever. The latter is
a pretty simple and common feature. Really, the order of presentation
here seems rather strange. Rather than a coherent introduction, it seems
like a random grab-bag of "features", in no particular order...
Date: 29 Sep 2012 12:51:55
Message: <5067272b$1@news.povray.org>
>> So, what's their solution? You have to reinvent the wheel all the time?
> Use interfaces instead.
Sounds like a stupid book. I wouldn't trust its advice.
Don't use inheritance unless you're obviously making a subclass of the thing
you're inheriting from. Don't use polymorphic dispatch unless you intended
to use polymorphic dispatch.
I think of all the code in my entire project, I have exactly one set of
routines that inherit from some other routine I wrote, and they're basically
type-specific widgets for displaying the results of searching over
collections of various kinds of documents.
I have a bunch of .. well, database connectors, one for each table, that all
inherit from the general "database connector."  I have a bunch of protobufs
that all inherit from "generic protobuf".
Otherwise, there's virtually no inheritance in my work code.
I have a game, where I do indeed have some inheritance, but where multiple
inheritance might very well have worked out better. For each stackable
screen (say, you have a help screen on top of a file selection screen on top
of a start game screen on top of a top-level-menu screen), it inherits from
the appropriate superclass (input-blocking screen, input-blocking screen
with timeout, etc).  Other than that, again, very general.
IME, libraries often have classes you'd almost never use as is, which you
can inherit from, and applications generally have very few classes you
actually inherit from. And for the latter, you almost always know when
you're writing the base class that you're going to be inheriting from it.
   "They're the 1-800-#-GORILA of the telecom business."
Date: 29 Sep 2012 13:32:20
Message: <506730a4$1@news.povray.org>
On 9/29/2012 3:27, Orchid Win7 v1 wrote:
> Regardless, C# turns this backwards. In C#, by default you /cannot/ override
> anything, unless you explicitly turn it on by writing "virtual". Meaning
> that if the author of some class didn't foresee the potential need to
> subclass it, you may not be able to override the necessary methods.
In practice, this is generally not a problem. If you're not thinking of code
at the level of overriding virtual methods, it's usually impossible to
override a method correctly, unless you're just doing something like adding
logging that the method got called. (At which point, how do you get your
custom class into the places where it's supposed to be, if others are
instantiating the wrong class?)
> Apparently it is "very hard" to design a class in such a way that it can be
> subclassed correctly. So you should only allow this possibility where a
> class has been explicitly designed with the intention of being subclassed
> later. In all other cases, you should disable subclassing, because if you
While this is excessive, it's probably good advice for people who haven't
done a fair amount of work on such projects. Sealing the class is probably a
bit much, but not declaring things virtual that you don't expect a subclass
will want to override is not a bad thing.
> inheritance is overused and collaboration is underused. But this just seems
> excessive!
It is. But then again, absolute advice given in a beginner's book is usually
excessive. You develop the good habit, *then* you learn from experience
where the right place to break the habit is.
> named arguments. The former is an obscure and very dangerous feature which
> you should never use, under any circumstances, ever. The latter is a pretty
> simple and common feature. Really, the order of presentation here seems
> rather strange.
Sounds like he wanted to mention destructors along with constructors, and
since he had nothing to say about them besides "don't", he had no other good
place to put them.
Date: 29 Sep 2012 13:40:06
Message: <50673276$1@news.povray.org>
On 9/29/2012 3:18, Orchid Win7 v1 wrote:
> This, it is claimed, can reduce page faults, improve cache performance, and
> so forth.
Reducing the working set is independent of how much code you have. It
depends on how much code you're working with right at this very moment. The
author doesn't understand the concept of "working set".
Working set is, roughly, the number of pages you're accessing faster than
paging in swapped-out pages is fast enough to keep up with. If you have a
300-meg executable in a tight loop 23K in size, you have a 23K working set.
> Yes, that's right. Your application is using 250MB of heap space, but the
> executable binary is 4KB smaller, and that's the important thing, right?
The part of the heap you're using is also part of the working set.
>> I have seen several arguments in the past that C++ templates
>> are bad because they increase code size, thus increasing memory usage.
Well, C++'s target platforms include things that C# isn't targeted at. If
you're trying to fit your code into a credit card terminal, you're going to
be worried about C++ template code bloat and the features of C#'s execution
model won't even enter the conversation.
>> In other words, their solution to the "huge" "problem" of increased code
>> size is to increase memory usage ten-fold in order to make the executable
>> binary slightly smaller. Great job.
> Yeah, that's about the size of it.
Nah. I'm pretty sure C# generics use the same code for each reference type.
I.e., you might have a version for int, a version for float, and one version
for anything descended from Object.
The reason C++ makes more code is that it actually does stuff like inline
the right calls, doing type-specific generic expansions. C# doesn't do that,
so I think you get far fewer versions of the code. Especially for generics
that are anchored, i.e., that are generic over some specific superclass.
Date: 29 Sep 2012 15:35:48
Message: <50674d94@news.povray.org>
If C# is anything like Java in this regard, then destructors are pretty
much useless (because when you need destructors for something other than
freeing memory, which isn't necessary in C#, you usually need the
destructor to be called in a deterministic manner at a specific point in
the program, not at some undetermined time in the future maybe.)
In C++ destructors are useful for more than just freeing memory. For
example they are commonly used in things like locks: If a function needs
to use a lock, it can make a static lock instance which frees the lock
in its destructor, and it's guaranteed to be freed immediately when the
function is exited, regardless of how it's exited (ie. no matter where
the 'return' sentence is, or even if it's exited by throwing an
exception). It's handy because you don't need to any special code to
make sure that the destructor is called when the function is exited.
Date: 29 Sep 2012 15:44:38
Message: <50674fa6@news.povray.org>
"Template code bloat" is a myth with little to no actual evidence.
If you need the same code to handle more than one type, you have to do that
somehow. Either you duplicate the code for each type, or you use runtime
polymorphism, or alternatively you use some really contrived code full of
conditionals that checks the actual type of the data when it tries to use it.
In most cases option #1 is most probably going to take *less* memory and
be a lot more efficient than either of the other options. That's because
with option #1 the compiler can optimize the code for those types while
with the other options it can't. In fact, your code might become *smaller*
when it's optimized for each type rather than larger.
Even if it doesn't become smaller, the increase in memory usage will most
probably be less than with the other solutions. If even that's too much,
then you shouldn't be using several types in the first place, but than it's
not the templates' fault, it's your own fault for wanting to use several
types on a machine with 1 kilobyte of RAM.
Inlining can actually *reduce* the size of the binary in some cases (because
of the subsequent compile-time optimizations).
Date: 29 Sep 2012 17:17:14
Message: <5067655a$1@news.povray.org>
> much useless
That was pretty much it, yes.
In particular, any objects that "this" points to might already have been
destroyed, so you can't touch those. You also have to make sure you do
/not/ cause any dead objects to become alive again by adding pointers to
them. Destructors are also run in a separate thread, so you have to be
careful about thread-safety... In short, writing a correct destructor is
a nightmare.
Yeah, if destructors behave in a deterministic way, I'd imagine there's
a few useful things you can do with them.
Date: 29 Sep 2012 17:28:03
Message: <506767e3$1@news.povray.org>
>> performance, and so forth.
> The author doesn't understand the concept of "working set".
The author claims that if you never try to print anything, the code for
doing printing will never be JIT-compiled, thereby resulting in a
smaller working set.
 From what you're saying, if that code is already compiled to machine
code but just never /runs/, then it won't increase the working set
anyway. (Unless it causes the running code to span more VM pages.)
> type. I.e., you might have a version for int, a version for float, and
> one version for anything descended from Object.
Sure. I meant in the C++ case.
> inline the right calls, doing type-specific generic expansions. C#
> doesn't do that, so I think you get far fewer versions of the code.
> Especially for generics that are anchored, i.e., that are generic over
And Haskell generates one version of the code, and lets you request
specific versions if you want them.
Oh, wait...
Date: 29 Sep 2012 19:34:44
Message: <50678594$1@news.povray.org>
On 9/29/2012 14:17, Orchid Win7 v1 wrote:
> In short, writing a correct destructor is a nightmare.
Not really. Writing a complicated class that also has a destructor is a
nightmare. If you have a destructor on a class that has anything more than a
reference to the object you want to destruct, you're probably doing it
wrong. If you're doing more than wrapping the non-GCed resource, you're
doing too much work in that class.
That said, no, destructors aren't especially useful except for logging that
you you forgot to explicitly free your resource. :-)
Personally, I find that sort of thing terribly confusing. I suppose you get
used to having variable declarations actually being control flow statements,
but I find it rather bizarre.
I prefer the Sing# method, wherein if you have a variable that needs to be
tracked, and you let it go out of scope without disposing it, the code
doesn't compile. You can still get resource leaks with the C++ method, if
your structures are complicated enough.
Date: 29 Sep 2012 19:40:47
Message: <506786ff@news.povray.org>
I said you'd be worried about it. I didn't necessarily say the worries were
justified. :-)
I think if you have the code for several different pointer types, and you
deal with them all the same way, you might have multiple copies of the same
code getting compiled, right?
I mean, if you instantiate it over int* and float* and MyClass* and
YourClass* and ThisWidget* and ThatWidget*, you're going to wind up with six
copies of that code, right? And if your linker is stupid enough, you're
going to wind up with copies in every place you use that code.
I'm saying that if you have a collection class instantiated for multiple
types of pointers, C++ has no choice but to expand each, because you don't
declare the type in the template. The compiler and linker would need to be
fairly smart, I'd think, to recognize that myblah.implement(&myBlah) and
yourblah.implement(yourBlah) both generate identical code because the
"implement" function doesn't do anything type-specific with the blahs.
