POV-Ray : Newsgroups : povray.off-topic : Finding a good VM Server Time
22 Jun 2025 21:45:24 EDT (-0400)
  Finding a good VM (Message 1 to 10 of 37)
Subject: Finding a good VM
Date: 27 Aug 2012 06:24:05
Message: <503b4ac5@news.povray.org>
OK, so I'm currently looking for some VM software I can run on my home PC.
At work, I use VMware Workstation. Which works vastly better than
anything else I've seen, but it's expensive. Really expensive. I just
There is VMware Player, of course. That's free. But being free it's also
crippled with all sorts of artificial limitations; no linked clones, no
snapshots, no teams. Basically it lets you run another OS, but without
any of the benefits of a VM.
In the past, I've tried BOCHS and QEMU. The interface is CLI-only. You
have to manually manage all the files involved. You end up having to
write elaborate scripts to fire up a VM. It works, but it's extremely
complicated. Plus this stuff runs very, very slowly.
I also tried Virtual Box. This offers a familiar GUI interface. (And I
particularly like the way each VM has its own window, so you can SEE
multiple VMs at the same time. On the other hand, it lacks activity
lights...) However, there are two main problems with it. The first is
that you still have to manually manage disks and VMs separately. But the
big, big problem is IT'S TOTALLY UNRELIABLE! It just will NOT do what
you tell it to. The number of times it's crashed on me, or a particular
VM has become unusable is utterly unacceptable.
Are there any other VM products with investigating? (Clearly there are
other VM products; I'm asking whether any of them are any good.)
Subject: Re: Finding a good VM
Date: 27 Aug 2012 08:23:41
Message: <503b66cd@news.povray.org>
Have you tried VirtualBox?
Date: 27 Aug 2012 10:06:59
Message: <503b7f03$1@news.povray.org>
Am 27.08.2012 14:23, schrieb Warp:
If "VirtualBox" == "Virtual Box" then yes, he did mention it.
Date: 27 Aug 2012 14:37:47
Message: <503bbe7b$1@news.povray.org>
On 8/27/2012 3:24, Orchid Win7 v1 wrote:
> Are there any other VM products with investigating? (Clearly there are other
If you're talking about Windows, Microsoft makes a Virtual PC that comes
with certain versions of Windows that works well.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 27 Aug 2012 15:42:51
Message: <503bcdbb$1@news.povray.org>
FWIW, I use VirtualBox on Linux pretty much daily, never have stability
problems at all.
I'm also not sure what you  mean by "manag[ing] disks and VMs separately"
- the GUI that I use (which is the default GUI AFAIK) doesn't do that.
Jim
Date: 27 Aug 2012 16:52:50
Message: <503bde22$1@news.povray.org>
>> other
I thought that was limited to only running one single instance of
Windows XP for backwards compatibility.
Date: 27 Aug 2012 16:56:24
Message: <503bdef8$1@news.povray.org>
>> comes with certain versions of Windows that works well.
No, you're thinking of "compatibility mode", not Virtual PC.
There's also Hyper-V if you have Windows Server.
Jim
Date: 27 Aug 2012 16:59:09
Message: <503bdf9d$1@news.povray.org>
> problems at all.
You never had it pop up and say "This process has performed an illegal
operation and must be terminated. Do you wish to send an error report"?
(Oh, well, I guess you wouldn't be seeing a Windows-specific error
message on Linux... But you get what I'm saying.)
You never had a VM working perfectly, and then the next day VirtualBox
utterly /refuses/ to start that VM? (Like, you click "start", and either
nothing happens or VirtualBox instantly crashes.)
You never had it refuse to delete a snapshot for no defined reason?
(E.g., you have a VM powered down, you take a snapshot, realise you
wanted to do something first, go to delete the snapshot you just made,
and it says "sorry, I can't do that Dave".)
When you create a VM, it asks to create a virtual disk. (Which isn't
surprising; VMware does this also.) But it seems to want to put all the
VM files in one place, and all the virtual disk files in another place.
And it asks me if I want to reuse one of my existing disk files. (Why
would I *ever* want to do that??) And when I delete a VM, this does
/not/ delete the disk image files with it. I have to manually do that
from the disk management window.
Maybe the GUI is completely different on Linux or something. But on
Windows, you can't even edit a snapshot description while the VM it
belongs to is running. (I can understand, from a technical perspective,
how that could end up not working. What I can't figure out is why the
heck nobody has fixed this. It can't be that damned hard...)
Date: 27 Aug 2012 17:15:53
Message: <503be389$1@news.povray.org>
>> problems at all.
Nope, never.
Nope, never.  I've even had my entire Linux DE crash on me and I've been
able to restart the VM when it came back up.
What version are you running?  Sounds like an old version maybe, or just
that the Windows version is garbage and you should use the Linux
version.  I've had nothing but good luck with the Linux version - enough
so that I stopped using even VMware Player.
Nope, never had it do that, either.
>> separately"
All of my VMs' disk files are with the configuration, but this actually
makes sense on a couple different levels, because you can do 'linked
cloning', in which case deleting the disk file would affect multiple VMs
(ie, it would break them).  But in the Linux GUI, you do have the option
when deleting a VM to also delete the disk files at the same time if
they're not linked/in use by another VM.
That works just fine on Linux.
Jim
Date: 27 Aug 2012 21:43:27
Message: <503c223f@news.povray.org>
On 8/27/2012 13:59, Orchid Win7 v1 wrote:
> asks me if I want to reuse one of my existing disk files. (Why would I
> *ever* want to do that??) And when I delete a VM, this does /not/ delete the
I think you just answered your own question.
    in the cabinet."
