POV-Ray : Newsgroups : povray.off-topic : Finding a good VM Server Time
13 May 2026 16:14:58 EDT (-0400)
  Finding a good VM (Message 11 to 20 of 37)
Subject: Re: Finding a good VM
Date: 28 Aug 2012 04:32:04
Message: <503c8204$1@news.povray.org>
>> asks me if I want to reuse one of my existing disk files. (Why would I
>> *ever* want to do that??) And when I delete a VM, this does /not/
>> delete the disk image files with it.
> I think you just answered your own question.
How so?
If you put the disks from one VM into another VM, then the other VM
*becomes* the first VM. All VMs are essentially identical; the disks are
the only thing that makes them different. Either you want to delete a
VM, or you don't. So deleting the settings file and then still using the
existing disks is a nonsensical thing to do.
Date: 28 Aug 2012 11:18:36
Message: <503ce14c$1@news.povray.org>
> How so?
Not if the disk is a data disk, or is used as something other than the
boot disk.
Or if it's a base for multiple linked clones where you started from a
common base, but the clones are different.  It's not unusual at all, for
example, when testing networked setups of identical OSes to create a
common base image and then customize multiple linked clones.
Jim
Date: 28 Aug 2012 12:03:19
Message: <503cebc7$1@news.povray.org>
> boot disk.
Wouldn't you just clone the disk for something like that? (Otherwise
only one VM can access it at a time.)
Then wouldn't each clone have its own local cloned disk image?
Date: 28 Aug 2012 13:22:55
Message: <503cfe6f$1@news.povray.org>
Am 28.08.2012 18:03, schrieb Orchid Win7 v1:
>> boot disk.
Virtual Box is pretty smart when it comes to saving disk space: When you
clone a disk image, it "freezes" the original disk's state into a save
point, and the clone will actually be a reference to that save point
plus a delta tracking any changes.
Likewise, the original disk will further on be managed as that "frozen"
state plus another delta tracking any changes made by /that/ VM.
(Note that a "frozen" state itself may already be a reference to an
earlier save point plus a delta.)
Date: 28 Aug 2012 13:56:53
Message: <503d0665$1@news.povray.org>
>>> are the only thing that makes them different. Either you want to
>>> delete a VM, or you don't. So deleting the settings file and then
>>> still using the existing disks is a nonsensical thing to do.
>> boot disk.
No, and no.
Linking the clone means that you don't waste the disk space with
duplicate data.
And no, only one VM can *write* to it at a time, but multiple VMs can
*read* from it at the same time.  Changes get written to a secondary file
that contains the differences between the combined images and the base
image - just like a snapshot.
Again, no.  That's not what a linked clone is.
I might be inclined to suggest "RTFM", as the VirtualBox and VMware
documentation both describe what a linked clone is.  Rather than assume
what it is and then make statements based on those assumptions, you could
actually learn what the idea is behind it.
Jim
Date: 29 Aug 2012 03:49:23
Message: <503dc983$1@news.povray.org>
Isn't this how /all/ VM products work?
Date: 29 Aug 2012 03:53:51
Message: <503dca8f$1@news.povray.org>
Oh, so now you're claiming that I don't know how VMware works?
When you create a VM, it starts with one file for the disk image. Each
time you take a snapshot, it stops writing to the current image file,
and creates a new file which is a delta against the previous one. When
you make a "full clone", it copies all the data. When you create a
"linked clone", it creates a new VM, but it's base disk image is just a
delta against the linked VM, just like a snapshot.
I don't know off the top of my head how Virtual Box does it.
I'm still not seeing why you would want to transfer a disk from one VM
to another - except perhaps, as you say, for data transfer (if you can't
get a more sane method to work).
Date: 29 Aug 2012 06:26:42
Message: <503dee62$1@news.povray.org>
Am 29.08.2012 09:49, schrieb Invisible:
Don't know; if that's the case, how come you didn't seem to know about
that concept?
Date: 29 Aug 2012 11:18:23
Message: <503e32bf$1@news.povray.org>
Well there you go. You have a VM on your desktop machine, and now you want
to run it in the colo facility.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 29 Aug 2012 11:19:15
Message: <503e32f3@news.povray.org>
It depends how you configure them. This is additional space overhead, remember.
    in the cabinet."
