POV-Ray : Newsgroups : povray.off-topic : Erasure Server Time
14 May 2025 18:23:09 EDT (-0400)
  Erasure (Message 1 to 7 of 7)
Subject: Erasure
Date: 21 Aug 2012 09:15:29
Message: <503389f1$1@news.povray.org>
Erasing a 8.6 GB HD:
It takes about the same time as erasing a 3 TB HD.
Irony?
Subject: Re: Erasure
Date: 21 Aug 2012 09:25:33
Message: <50338c4d$1@news.povray.org>
> Irony?
Same technology ? Interface ?
What do you mean by "erasing" ?
 * removing the partition table
 * overwriting the first few sectors with "dd if=/dev/null of=/dev/.. "
 * formatting again the partiton
 * overwriting the whole drive ?
Writing the whole 3 TB drive would take a few hours (at 50 to 100 MB/s,
I let you compute), if I trust the raid5 synchronisation on partitions
of 2TB that I observed.
The three former method are rather quick and might not have too much
impact by the disk size. (at worst, a few extra superblock to be written
along the disk)
Date: 21 Aug 2012 09:26:52
Message: <50338c9c$1@news.povray.org>
True, they both get crashed in few seconds/minutes, depending on
available equipment.
Date: 21 Aug 2012 10:06:53
Message: <503395fd$1@news.povray.org>
Both IDE. Vastly different manufacture dates, though.
And that's the thing. Newer drives are much faster, but also much
larger. So the erase time remains roughly constant.
That takes milliseconds on any system.
This.
Date: 24 Aug 2012 03:53:23
Message: <503732f3@news.povray.org>
I take it back. The 8.6 GB drive is /still/ erasing...
I'm pretty sure that means I just have selected a non-optimal block size
or something, because there's no way it should be taking this long.
Date: 24 Aug 2012 05:48:25
Message: <50374de9$1@news.povray.org>
It might have bad blocks, and enters a retry loop... with I/O timeout.
My best erasor: unix "dd bs=32kB if=/dev/zero of=/dev/<drive> "
If you really bother, provide a count= (but it's in block...)
If SMART is available on the drive, check it.
Date: 24 Aug 2012 06:03:11
Message: <5037515f$1@news.povray.org>
No, I think it's just ancient. (The OS still loads, after all...)
Yeah, that's what I'm using. But with a 0.5 KB block size. For some
reason, each block takes about 10 seconds...
I just tried changing it to 8 KB. Let's see if that makes any difference
at all...
The drive is 8.6 GB. How ancient must that thing be? I doubt SMART was
even invented back then...
