POV-Ray : Newsgroups : povray.off-topic : Death of a harddrive Server Time
2 Sep 2024 09:23:07 EDT (-0400)
  Death of a harddrive (Message 1 to 10 of 15)
Subject: Death of a harddrive
Date: 17 Aug 2012 10:25:25
Message: <502e5455$1@news.povray.org>
So, we put an old Maxtor harddrive in a glass measuring beaker, and
stood it in one of our fume cupboards.
We poured nitric acid on it. Nothing.
The guy opened a bottle of sulphuric acid, which was smoking slightly.
Pour some of that in... a tiny amount of fizzing. That's about it.
So we stand at look at it for a moment. And then my college decides to
add a little hydrochloric acid.
Woah... I'm not sure what the chemistry of this is, but now it's foaming
like hell, and there's huge clouds of dark brown smoke coming off it.
Uh, yeah, I think we close the fume hood now...
After a few minutes it eventually stopped fizzing. There's still some
kind of brown vapour issuing from it though. And the black paint is
slowly falling off, revealing the dully silver metal beneath.
It will be interesting to see if there's anything left by Monday. My
college thinks it will have been reduced to sludge by then. I suspect
it'll still be in once piece, just slightly corroded around the outside.
Subject: Re: Death of a harddrive
Date: 18 Aug 2012 00:37:22
Message: <502f1c02$1@news.povray.org>
Flashbacks to Breaking Bad.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 18 Aug 2012 04:05:51
Message: <502f4cdf$1@news.povray.org>
Le 17/08/2012 16:25, Invisible nous fit lire :
Red alert. Mixing Nitric acid with Sulphuric acid is a cocktail to make
nitroglycerin from glycerine. The smallest part of grease might turn
dangerous once dried.
Great, now the cocktail is a mix of Sulphuric acid and Aqua regia, the
solvent for gold & platinum.
(for gold, the proportion are 2/3 Nitric, 1/3 Chloridric; it goes to 7/9
and 2/9 for platinum, IIRC)
All the water generated by Aqua regia attacking the metal will get
captured by the Sulphuric acid.
Notice that Aqua regia is unstable: it will generate chlorine gaz and
nitric oxyd (Cl2 and NO) with water.
Adding water to Sulphuric acid is exothermic. (it generates heat)
Date: 18 Aug 2012 04:19:36
Message: <502f5018$1@news.povray.org>
Le 18/08/2012 10:05, Le_Forgeron nous fit lire :
Nah, it's the opposite proportion! More Chlore, less Nitro!
Date: 18 Aug 2012 05:48:34
Message: <502f64f2$1@news.povray.org>
Am 18.08.2012 10:05, schrieb Le_Forgeron:
If the aim is to destroy the drive, nitroglycerine would definitely help
 >_<.
Fine, so gold parts won't escape either :-P
Date: 18 Aug 2012 06:06:52
Message: <502f693c$1@news.povray.org>
Interesting. I thought aqua regia was sulfuric and nitric... oh well!
Date: 18 Aug 2012 06:13:16
Message: <502f6abc$1@news.povray.org>
How about all the metal irons now floating around? Will that affect
anything?
> solvent for gold&  platinum.
Well, yeah, we /are/ trying to dissolve metal...
Apparently it also evolves NOCl, which might explain the dark brown fumes.
Yeah, I gathered at least one of them is. Good thing we didn't add any
water, eh? (Might explain the fizzing though... it certainly didn't seem
to remove any metal!)
Date: 21 Aug 2012 05:02:42
Message: <50334eb2@news.povray.org>
Well, the results are in:
The drive is now somewhat corroded, and most of the paint is missing.
The circuit board probably won't work again. But other than that, the
drive is more or less completely unharmed. Apparently soaking it in a
vat of acid for 4 days is /not/ sufficient to dissolve the entire thing
down to the platters. :-P
Date: 21 Aug 2012 07:30:01
Message: <50337139@news.povray.org>
I told you: boiling hydrochloric acid. No fancy mix, just plain Hcl,
enough HCl.
Now, rinse it, dry it and to the boiler...
Or if you have some liquid nitrogen and a hammer... it can be fun too.
Date: 21 Aug 2012 07:47:36
Message: <50337558@news.povray.org>
> enough HCl.
I don't have any way of heating the acid. Also, we have now run out of acid.
We have a 2 tonne liquid nitrogen tank. However, the nitrogen can only
be withdrawn in gaseous form.
