POV-Ray : Newsgroups : povray.off-topic : Pauseless GC now available Server Time
13 May 2026 14:36:26 EDT (-0400)
  Pauseless GC now available (Message 1 to 10 of 23)
Subject: Pauseless GC now available
Date: 11 Aug 2012 20:40:18
Message: <5026fb72$1@news.povray.org>
http://www.infoq.com/news/2012/08/azul-zing-free
I am pretty sure this means it's real-time GC.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Subject: Re: Pauseless GC now available
Date: 12 Aug 2012 02:23:12
Message: <50274bd0$1@news.povray.org>
Le 12/08/2012 02:40, Darren New nous fit lire :
there was already the trick of serial GC vs parallel GC (or how to get a
java application out of trouble when GC kick in, since JVM 5.0)
(GC: garbage collector)
Date: 12 Aug 2012 05:23:39
Message: <5027761b$1@news.povray.org>
Oh thank God. They've had this magical silver bullet all along, and now
they've /finally/ released it to the rest of the world. How did we ever
manage without it? :-P
I like how the algorithm description is sufficiently vague that you
can't tell how it actually works. It claims to be able to mark
concurrently "without live objects escaping the collector's reach", but
doesn't explain how. It says it can delete a page after all objects have
been relocated, and it "detects" any attempt to access a moved object,
but again doesn't say how. (It sure /sounds/ like they're saying they do
some O(n) operation on every single pointer read, which is of course
absurd.) Come to think of it, they say they use page features to
implement some of this stuff - which is interesting, since only the OS
can do that...
Also,
   "Initial in-memory tests on the full Wikipedia English-language site
index show Zing is truly pauseless while managing a heap in excess of
140 GB."
Since it's impossible to have a machine with 140GB of RAM, what's the
point of having a heap that large? It'll just spend forever swapping.
Surely you'd get far better performance by implementing some explicit
file handling yourself?
Date: 12 Aug 2012 12:27:52
Message: <5027d988$1@news.povray.org>
On 8/12/2012 2:23, Orchid Win7 v1 wrote:
> I like how the algorithm description is sufficiently vague that you can't
It was four clicks away, with the previous three clicks giving successively
more detailed descriptions.
http://labs.oracle.com/jtech/pubs/04-g1-paper-ismm.pdf
You're welcome.
> it "detects" any attempt to access a moved object, but again doesn't say
> how.
Memory mapping. It traps on reading the memory that hasn't been fixed yet,
then fixed up the entire page worth of references, then marks the memory as
readable.
Since when is it impossible? We had 128G of RAM on the Sparcstation we used
back in 1995 or so. And that wasn't even a mainframe.
    in the cabinet."
Date: 12 Aug 2012 13:25:01
Message: <web.5027e625dbb2278e9726a3c10@news.povray.org>
I'm don't know why you might think that.
http://www.tacc.utexas.edu/user-services/user-guides/lonestar-user-guide#overview:upgrade:largemem
Date: 12 Aug 2012 16:35:19
Message: <50281387@news.povray.org>
> successively more detailed descriptions.
> You're welcome.
No.
This is the GC from Sun, the GC that the Azul one is supposed to be
superior to.
>> how.
> yet, then fixed up the entire page worth of references, then marks the
> memory as readable.
So you mean it relocates an entire page of live objects, and then uses
page faults to detect access to the non-existent page and lookup where
the data has gone?
The only problem with that, of course, is that paging is controlled by
the operating system, not by a user-level application program.
> used back in 1995 or so. And that wasn't even a mainframe.
That's interesting. Because in 1998, I did some work experience with BT.
One day I was showed into their main datacenter, and their most powerful
server was running off a RAID-5 array containing not one, not two, not
three, but SEVEN 4.2 GB drives. I remember feeling slightly giddy trying
to work out how many multiple gigabytes of data that thing must be able
to hold in total.
And you're claiming you had 100x more than that IN RAM? Somehow, I doubt it.
Date: 13 Aug 2012 05:47:30
Message: <5028cd32$1@news.povray.org>
Am 12.08.2012 11:23, schrieb Orchid Win7 v1:
> can do that...
"Three successive generations of Azul's Vega series systems relied on
custom multi-core processors and a custom OS kernel to deliver both the
scale and features needed to support Pauseless GC. In 2010, Azul
released its first software-only commercial implementation of C4 for
modern commodity X86 hardware, using Linux kernel enhancements to
support the required feature set."
Virtualization features maybe, dunno.
Date: 13 Aug 2012 05:48:37
Message: <5028cd75$1@news.povray.org>
>> can do that...
Oh, wait - you have to run a customised OS kernel for it to work? Yeah,
OK, that explains it then...
Date: 13 Aug 2012 06:01:39
Message: <5028d083$1@news.povray.org>
Am 12.08.2012 22:35, schrieb Orchid Win7 v1:
> the data has gone?
Yes, of course. That's also why virtual machines are mind-bogglingly
slow and/or rely on specially patched OSes. Rrrright.
Andy, wake up.
Date: 13 Aug 2012 06:05:06
Message: <5028d152$1@news.povray.org>
Am 13.08.2012 11:48, schrieb Invisible:
>>> can do that...
You HAD to run a customised OS kernel for it to work.
If I understand it correctly, modern CPUs and modern Linux kernels
already include all the necessary "customizations".
