POV-Ray : Newsgroups : povray.off-topic : Pauseless GC now available Server Time
13 May 2026 19:19:04 EDT (-0400)
  Pauseless GC now available (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Pauseless GC now available
Date: 12 Aug 2012 12:27:52
Message: <5027d988$1@news.povray.org>
On 8/12/2012 2:23, Orchid Win7 v1 wrote:
> I like how the algorithm description is sufficiently vague that you can't
> tell how it actually works.
It was four clicks away, with the previous three clicks giving successively
more detailed descriptions.
http://labs.oracle.com/jtech/pubs/04-g1-paper-ismm.pdf
You're welcome.
> it "detects" any attempt to access a moved object, but again doesn't say
> how.
Memory mapping. It traps on reading the memory that hasn't been fixed yet,
then fixed up the entire page worth of references, then marks the memory as
readable.
> Since it's impossible to have a machine with 140GB of RAM,
Since when is it impossible? We had 128G of RAM on the Sparcstation we used
back in 1995 or so. And that wasn't even a mainframe.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 12 Aug 2012 13:25:01
Message: <web.5027e625dbb2278e9726a3c10@news.povray.org>
> Since it's impossible to have a machine with 140GB of RAM, what's the
> point of having a heap that large? It'll just spend forever swapping.
> Surely you'd get far better performance by implementing some explicit
> file handling yourself?
I'm don't know why you might think that.
http://www.tacc.utexas.edu/user-services/user-guides/lonestar-user-guide#overview:upgrade:largemem
Date: 12 Aug 2012 16:35:19
Message: <50281387@news.povray.org>
> successively more detailed descriptions.
> You're welcome.
No.
This is the GC from Sun, the GC that the Azul one is supposed to be
superior to.
>> how.
> yet, then fixed up the entire page worth of references, then marks the
> memory as readable.
So you mean it relocates an entire page of live objects, and then uses
page faults to detect access to the non-existent page and lookup where
the data has gone?
The only problem with that, of course, is that paging is controlled by
the operating system, not by a user-level application program.
> used back in 1995 or so. And that wasn't even a mainframe.
That's interesting. Because in 1998, I did some work experience with BT.
One day I was showed into their main datacenter, and their most powerful
server was running off a RAID-5 array containing not one, not two, not
three, but SEVEN 4.2 GB drives. I remember feeling slightly giddy trying
to work out how many multiple gigabytes of data that thing must be able
to hold in total.
And you're claiming you had 100x more than that IN RAM? Somehow, I doubt it.
Date: 13 Aug 2012 05:47:30
Message: <5028cd32$1@news.povray.org>
Am 12.08.2012 11:23, schrieb Orchid Win7 v1:
> Come to think of it, they say they use page features to
> implement some of this stuff - which is interesting, since only the OS
> can do that...
"Three successive generations of Azul's Vega series systems relied on
custom multi-core processors and a custom OS kernel to deliver both the
scale and features needed to support Pauseless GC. In 2010, Azul
released its first software-only commercial implementation of C4 for
modern commodity X86 hardware, using Linux kernel enhancements to
support the required feature set."
Virtualization features maybe, dunno.
Date: 13 Aug 2012 05:48:37
Message: <5028cd75$1@news.povray.org>
>> can do that...
Oh, wait - you have to run a customised OS kernel for it to work? Yeah,
OK, that explains it then...
Date: 13 Aug 2012 06:01:39
Message: <5028d083$1@news.povray.org>
Am 12.08.2012 22:35, schrieb Orchid Win7 v1:
> the data has gone?
Yes, of course. That's also why virtual machines are mind-bogglingly
slow and/or rely on specially patched OSes. Rrrright.
Andy, wake up.
Date: 13 Aug 2012 06:05:06
Message: <5028d152$1@news.povray.org>
Am 13.08.2012 11:48, schrieb Invisible:
>>> can do that...
You HAD to run a customised OS kernel for it to work.
If I understand it correctly, modern CPUs and modern Linux kernels
already include all the necessary "customizations".
Date: 13 Aug 2012 06:37:33
Message: <5028d8ed$1@news.povray.org>
> Andy, wake up.
You say that, but last time I tried to do virtualisation on Linux, it
/did/ actually require loading a special kernel module. (Which is
presumably why it didn't work when I tried it...)
No idea how it works in Windows.
Date: 13 Aug 2012 10:54:02
Message: <5029150a@news.povray.org>
On 8/12/2012 13:35, Orchid Win7 v1 wrote:
> The only problem with that, of course, is that paging is controlled by the
Not in this system. I believe Linux now has a hack in it that lets you get
first dibs on page faults.
Yep. And the room the box was in was full of mainframes, including three
tape carousels that held 2.5TB each. You've just never worked for a company
with enough money to buy stuff.
    in the cabinet."
Date: 13 Aug 2012 12:09:22
Message: <502926b2$1@news.povray.org>
>> the
> get first dibs on page faults.
Hmm, OK.
>> doubt it.
> company with enough money to buy stuff.
So you're saying that the fact that British Telecom plc could only
afford 25.2GB of spinning disk for a mission-critical system means that
they're "not big enough" to play with the Big Boys? :-P
