POV-Ray : Newsgroups : povray.off-topic : Just ask Google Server Time
13 May 2026 17:38:07 EDT (-0400)
  Just ask Google (Message 38 to 47 of 47)
Subject: Re: Just ask Unix
Date: 19 Jul 2012 14:14:39
Message: <50084e8f@news.povray.org>
On Thu, 19 Jul 2012 18:57:24 +0100, Orchid Win7 v1 wrote:
> By default, GHC statically links all *Haskell* libraries. However, it
> usually does not statically link *external* libraries, as far as I can
> tell. Perhaps there's a switch somewhere to make it do that...
Maybe, I don't know. :)
> (And then, of course, we get into the fun of deciding which libraries
> should or should not be statically linked. E.g., apparently statically
> linking glibc is a bad idea.)
Well, glibc is a big library, but if the library you compile against has
what you need, then it's not really any worse an idea than any other
library.
Jim
Date: 19 Jul 2012 14:39:37
Message: <50085469$1@news.povray.org>
Neither do I. But I know who to ask...
> library.
According to the research I've done, you really don't want to statically
link glibc, because it intimately depends on half the low-level stuff in
the entire system. Just taking one version of glibc and trying to run it
against the support files for another version tends to break spectacularly.
Similarly, you wouldn't want to statically link the OpenGL libraries,
because they are specific to your GPU. Similar remarks apply to ALSA,
apparently. And X11. And a few other things.
Let me see if I can figure out where I read all this... Ah yes, here we go:
http://freegamedev.net/wiki/Portable_binaries
Basically, it seems this stuff is pretty complicated. I suppose package
managers were invented for a reason, eh? Pity I can't use one to solve
my problem...
Subject: Re: Just ask Google
Date: 19 Jul 2012 15:09:11
Message: <50085b57@news.povray.org>
On a related note, back in grad school in the early 90's, I once spent 2 or
3 days tracking down a technical paper from 1985 that I needed to read. I
had the reference and everything, and I just had to find where it was in the
library.
The other day, I ran across someone mentioning "it makes error recovery in
distributed systems easier" and remembered this paper. All I remembered was
one author's name and the name of the programming language (NIL) in which it
was being tested.
It took me about 10 minutes to find the complete text through google search,
just by following through half a dozen references, tracking down the full
title that way, and then googling for the full title.
I thought that was pretty cool.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 19 Jul 2012 15:31:35
Message: <50086097$1@news.povray.org>
> go:
> my problem...
Well, on the flip side, glibc is common to Linux systems, so it shouldn't
be necessary to link to it.
But the simplest solution is to create a VM that has what the hosting
provider has in it - same distro and everything - and use that as the
development base for what you're working on.
Jim
Date: 19 Jul 2012 15:35:58
Message: <5008619e$1@news.povray.org>
>> go:
>> my problem...
Indeed. It seems you want to /not/ link anything that's ubiquitous to
all Linux systems, and to only link unusual stuff that probably won't be
there.
Yep, that would be the simplest.
I mean, if I knew what distro they're using, what packages they've
installed, and so forth...
Date: 19 Jul 2012 15:41:26
Message: <500862e6$1@news.povray.org>
On 17/07/2012 09:03 AM, Invisible wrote:
> - Finding a web hosting company that allows arbitrary CGI /binaries/ is
> seemingly impossible.
The other possibility is to use Amazon's EC2. But it's *really* expensive!
And then I stumble on this:
http://www.heroku.com/
I've never heard of it before, but it sounds interesting. (I rather
suspect it too will end up being far too expensive...)
Subject: Re: Just ask PHP
Date: 20 Jul 2012 06:14:27
Message: <50092f83@news.povray.org>
>>    System: Linux infong 2.4 #1 SMP Tue Jan 17 02:58:41 UTC 2012 i686
>> GNU/Linux
> Strange, a 2.4 serie kernel compiled at the beginning of 2012.
> 2.6 is more mainstream, and kernel has now entered the 3.2 serie
According to some of the stuff I've read, the build system needs to be
running the same kernel as the target system (or older).
What are my chances of finding a Linux distro that still works and
offers the 2.4 kernel?
Date: 20 Jul 2012 10:37:58
Message: <50096d46$1@news.povray.org>
>>> GNU/Linux
Not really. As an application (unless you dive into kernel structure
with root access), you practically have to have the same libc major version.
Now the itchy part: they moved from libc-5 to libc-6 during the 2.6
series (and there is a major glitch around 2.6.19 for some aspects I
just cannot remember)
It's just that compatibility of libraries is usually ascending: features
get added, so compiling against version 1.3 allows to still run on
version 1.44
Yet, major revision are allowed to break everything... sort of.
For instance, there is a certain gap between libxerces-c.2.8 and
libxerces-c.3.0 (not sure about the exact name). Some features get
dropped and some functions are gone, for real: the dynamic linker at
runtime will never find them if the new system is only installed with 3.0;
An old CD-set of slackware ?
Date: 20 Jul 2012 12:21:25
Message: <50098585$1@news.povray.org>
>>>> GNU/Linux
It's all Greek to me.
> version 1.44
Yeah. So basically, if I build my stuff on a system that's /older/ than
the target platform, it ought to work.
A better question: What are my chances of getting GHC, with it's vast
list of complex dependencies, to work on an ancient copy of Linux?
Yeah, exactly.
Date: 20 Jul 2012 13:35:27
Message: <500996df@news.povray.org>
Le 20/07/2012 18:21, Orchid Win7 v1 nous fit lire :
>> version 1.44
Maybe... or it can fails too. What are the chance of finding libc4
library on todays system ?
