POV-Ray : Newsgroups : povray.off-topic : Hyperthreading Server Time
13 May 2026 20:55:12 EDT (-0400)
  Hyperthreading (Message 31 to 40 of 48)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Hyperthreading
Date: 19 Jul 2012 19:45:03
Message: <50089bff$1@news.povray.org>
On 7/5/2012 11:22, Orchid Win7 v1 wrote:
> (In spite of the fact that I'm actually using ALL the cores available.)
You're not, tho. Hyperthreading means you have like 1.5 cores for every
"core". I assume you know what hyperthreading does. You could probably see a
speed-up by running 5 copies of pov-ray instead of 4.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 20 Jul 2012 04:03:09
Message: <500910bd$1@news.povray.org>
> see a speed-up by running 5 copies of pov-ray instead of 4.
As I understand it, hyperthreading allows you to schedule 2 threads on
each core. The first thread gets all available resources. If any are
unused, they are assigned to the second thread.
This means that if, say, one thread is using floating-point arithmetic
and the other is using integer arithmetic, both threads run at nearly
full speed. On the other hand, if both threads are using integer
arithmetic, only one thread runs, and the other makes no progress. (At
least, until the OS reschedules.)
Thus, I can believe that running two different applications might see a
benefit. If they're performing different tasks, they probably use
different execution unit types. But running two copies of the same
application is highly unlikely to see any benefit - unless the
application uses a really variable mix of instruction types...
Date: 20 Jul 2012 05:58:17
Message: <50092bb9$1@news.povray.org>
Well, personal measures about hyperthreading and povray 3.7 seems to
indicate that a HT core is rather between 1.2 and 1.25 core for povray
(see details and graph in povray.benchmarking). at least for the
benchmark scene.
HT is: a second set of registers. Nothing more. No additional FPU or
fancy integer units.
Well, it's more subtle, due to the Intel pipeline, but globally correct:
if they want the same resources at the same time, there is a contention
and the pipeline will rearrange them. The OS is usually unaware of such
issue: the granularity of the OS is far bigger than the small cycle in
the pipeline.
At best, operation of time 1 + another of time 1 could be done in 1 if
they do not use the same units at the same time... At worst it could be
2. Due to the pipeline splitting an instruction in multiple steps, it's
possible to interleave some steps in the empty slots of the first
thread-core.
Guess what, povray is not a single instruction!
Date: 20 Jul 2012 12:15:24
Message: <5009841c$1@news.povray.org>
On 20/07/2012 12:20 AM, Darren New wrote:
> On 7/6/2012 10:36, clipka wrote:
>> Better yet, overwrite it with pseudorandom nonsense.
> On modern hard disks, this is useless. And by "modern" I mean pretty
> much anything that passed the 1GB boundary.
Care to elaborate on that?
Date: 20 Jul 2012 13:31:45
Message: <50099601$1@news.povray.org>
Le 20/07/2012 18:15, Orchid Win7 v1 nous fit lire :
Old fact: reading a hard disk by direct access to the disk, with some
electronic beam device... fine until the density and encoding on the
disk went into modern era.
Nowadays (and since most 1GB hard drive... quite old), its not possible
anymore. Writing 0 or random number is the same: the old data is not
recoverable.
Date: 20 Jul 2012 13:46:20
Message: <5009996c$1@news.povray.org>
Am 20.07.2012 19:31, schrieb Le_Forgeron:
> recoverable.
Quiz: If you had highly sensitive data on your hard drive, and needed to
erase it for sure - would you rather trust this alleged fact, or have
the erasing software write random numbers just in case?
Date: 20 Jul 2012 14:54:06
Message: <5009a94e$1@news.povray.org>
Le 20/07/2012 19:46, clipka nous fit lire :
If the data on drive was so sensitive, I would use chemistry first. Then
a bit of heavy hammer physic, and finally a good heat with partial
ionisation, at temperature far above the curie point.
Boiling HCl is probably enough, as a starter. (get ride of most iron &
steel). Wear a protective mask and operate under well vented condition.
Date: 20 Jul 2012 16:22:23
Message: <5009bdff@news.povray.org>
Am 20.07.2012 20:54, schrieb Le_Forgeron:
Not recommended if you want to continue to use the hard drive though.
Date: 20 Jul 2012 16:28:31
Message: <5009bf6f@news.povray.org>
> recoverable.
This. Plus, if it's an SSD or has flash backup, you can write it all you
want and unless you rewrite the entire drive multiple times, you're not
guaranteed to get rid of the junk.
    in the cabinet."
Date: 20 Jul 2012 16:29:28
Message: <5009bfa8$1@news.povray.org>
If it's not sensitive enough to pay to replace the drive, it's not sensitive
enough to worry about whether you're erased with zeros or with random data.
    in the cabinet."
