POV-Ray : Newsgroups : povray.off-topic : Haskell vs Java: Building a ray tracer Server Time
25 Feb 2026 19:13:39 EST (-0500)
  Haskell vs Java: Building a ray tracer (Message 1 to 10 of 18)
Subject: Haskell vs Java: Building a ray tracer
Date: 28 Jun 2012 06:07:18
Message: <4fec2cd6@news.povray.org>
OK, so here's an application program which, I presume, I don't need to
explain to you guys. ;-)
How do you do this in Java? Well, first you're going to do something like
   public class Vector3
     public final double X, Y, Z;
     public Vector3(double x, double y, double z) {X = x; Y = y; Z = z;}
     public Vector3 Add(Vector3 other) {...}
Now we have vector arithmetic. Next you'll probably do something similar
for RGB colour values as well. OK, so that's the basics covered. Next,
you probably want something like
   public class Ray
     public final Vector3 Start, Direction;
     public Ray(Vector3 s, Vector3 d) {Start = s; Direction = d;}
     public Vector3 Point(double t)
       return Start.Add(Direction.Scale(t));
Now you'll probably sit down and do
   public abstract class Shape
     public abstract boolean TestIsect(Ray r);
     public abstract double FirstIsect(Ray r);
     public abstract double[] AllIsect(Ray r);
     public abstract Vector3 Normal(Vector3 p);
     public abstract boolean Inside(Vector3 p);
The most fundamental thing you need to do to a shape is ray intersection
tests. Most of the time, you just want the nearest intersection, so
that's FirstIsect(). However, to implement CSG, you need to obtain /all/
ray intersections, hence AllIsect(). You also need to know if the points
of intersection on one shape are inside or outside some other shape,
hence Inside(). Lighting calculations invariably require the surface
normal at a given point [approximately] on the surface, so Normal(). You
also sometimes use a Shape as a bounding volume, hence TestIsect(),
which tests for an intersection without bothering to compute where it
actually is.
So far, so good. We can now write out a whole bunch of Shape subclasses
- planes, spheres, cones, etc. I won't bore you with the details. Next,
let's have a camera:
   public abstract class Camera
     public abstract Ray Shoot(double x, double y);
Given a point on the image plane, generate a camera ray. Nice and easy.
We can now do things like
   public class Perspective extends Camera
     public final Vector3 V0, Vx, Vy, Vz;
     public Camera(Vector3 v0, Vector3 x, Vector3 y, Vector3 z)
     {V0 = v0; Vx = x; Vy = y; Vz = z;}
     public Ray Shoot(double x, double y)
       Vector3 v1 = Vx.Scale(x);
       Vector3 v2 = Vy.Scale(y);
       Vector3 v3 = Vx.Add(Vy).Add(vz).Normalise();
       return new Ray(V0, v3);
OK, so far, we have shapes. In the ray tracer I designed way, way back
in 1998 or whenever it was, an "object" had a "shape" and a "texture",
and a texture maps every point in space to a "surface", which describes
the rendering properties of the object. So we have:
   public abstract class Texture
     public abstract Surface GetSurface(Vector3 p);
   public abstract class Surface
     public abstract Colour ProcessIsect(Scene s, Vector3 hit, Vector3 in);
What I then did was to define several Surface subclasses:
- AmbientSurface always returns a user-defined Colour.
- DiffuseSurface uses Lambert's cosine rule to scale a user-defined
Colour according to the cosien of the angle of light from all the light
sources in the Scene. (It also performs shadow tests.)
- ReflectSurface implements perfect specular reflection.
- SumSurface computes the sum of several surfaces. In this way, an
object can have both reflection /and/ diffuse terms.
When I got to textures, I really had a party. First, there is obviously
ConstantTexture, which always returns a user-defined Surface for every
point in space. But then I defined various kinds of "map" classes:
- PointScalar maps every point in space to a scalar.
- PointVector maps every point in space to a unital vector.
- ColourMap maps scalars to colours.
- PointColour combines a PointScalar and a ColourMap to map every point
in space to a colour.
I had basically planar and spherical maps. Then I had various classes
that transform the coordinates being input to a map. For example, if you
take a spherical map and "slice" it through the middle, it becomes a
conical map. I also had an elaborate system whereby you could use a
PointScalar to scale a PointVector and use that to displace the
coordinates being fed to some other mapping. In this way, you could take
a simple planar map and sine-modulate it on multiple axes to generate
complicated swirly patterns.
You then have things like DiffuseTexture, which uses a PointColour to
assign a colour to every point in space, and produce a DiffuseSurface
with that colour. (Ditto for AmbientTexture, ReflectTexture, etc.) And,
obviously, CheckerTexture, which takes two Texture objects and picks
which one to return for different points in space. Or a Texture that
linearly interpolates between several subordinary Textures based on a
ScalarMap. Or...
Implementing light sources is fiddly. It depends on whether you just
want point lights, or whether you want area lights. But let's keep it
simple and stick to point lights only.
   public class Light
     public final Vector3 Position;
     public final Colour  Colour;
     public Light(Vector3 p, Colour c) {Position = p; Colour = c;}
Now a Scene is fairly simple; it holds lights, camera, and action. It
also seems like a reasonable place to stick things like the TraceRay()
function:
   public class Scene
     public final Camera   Camera;
     public final Object[] Objects;
     public final Light[]  Lights;
     public Scene(...)
     public Colour TraceRay(Ray r)
       double[][] ts = new double[Objects.length];
       for (int lp=0; lp<ts.length; lp++)
         ts = Objects[lp].FirstIsect(ray);
       Object o;
       double t = 1e100;
       for (int x=0; x<ts.length; x++)
         for (int y=0; y<ts[x].length; y++)
           if (ts[x][y] > 0 && ts[x][y] < t)
             {t = ts[x][y]; o = Objects[x];}
       Vector3 p = o.GetShape.Point(t);
       Surface s = o.GetTexture().GetSurface(p);
       return s.ProcessIsect(this, p, r.Direction);
Now just add some classes that implement mapping pixel coordinates to
image plane coordinates (taking care to invert Y), generating camera
rays, feeding them to TraceRay(), maybe antialiasing, and writing the
results to disk and/or screen. And there, that's your ray tracer.
My original ray tracer actually included slightly more code, because it
let you inspect the scene at run-time and get human-readable
descriptions for various things. (E.g., Shape had a GetName() function,
and ShapeSphere.GetName() returns "Sphere".) I never actually got as far
as /using/ any of this infrastructure, however. And actually, I didn't
build many scenes, because... well, look at it:
   Scene out = new Scene();
   Shape   sh = new ShapeSphere(new Vector3(0, 0, 0), 1);
   Surface su = new DiffuseSurface(Colour.RED);
   Object  ob = new Object(sh, new ConstantTexture(su));
   out.AddObject(ob);
   Shape   sh = new ShapePlane(new Vector3(0, 1, 0), -2);
   Surface su = new DiffuseSurface(Colour.GREEN);
   out.AddObject(ob);
   Shape   sh = new ShapePlane(new Vector3(0, -1, 0), -2);
   Surface su = new DiffuseSurface(Colour.BLUE);
   out.AddObject(ob);
   out.SetCamera(new PerspectiveCamera(Vector3(0, 0, -5), Vector3(1, 0,
0), Vector3(0, 1, 0), Vector3(0, 0, 2.5));
   out.AddLight(new Vector3(0, 0, -5), Colour.WHITE);
This places a piffling three objects and one light source. YUCK! You can
see why I didn't write many test scenes...
So how does all this look in Haskell?
First of all, we need vectors.
   data Vector3 = Vector3 !Double !Double !Double
   class Num Vector3 where
     (Vector3 x1 y1 z1) + (Vector3 x2 y2 z2) = Vector3 (x1+x2) (y1+y2)
(z1+z2)
Similarly, we need colours. Unlike Java, we can actually use real
grown-up operator names, so we don't have to write monstrosities like
   return v1.Add(v2).Add(v3).Normalise();
Instead we can simply say
   normalise (v1 + v2 + v3)
which is far easier to read. It also means stackloads of existing
numeric functions automatically work with vectors (e.g., the sum
function can sum a list of vectors - or a list a colours, which turns
out to be more useful).
Note, also, that we don't need to do this stupid
and then write
   new Vector3(1, 2, 3)
every time we want a vector. Instead, you can simply do
   Vector3 1 2 3
to create a vector.
Similarly, look back at the Java Ray class. See how much boilerplate
code there is for declaring that the fields are public and constant, and
for constructing a new object, and so forth. Now look at Haskell:
   data Ray = Ray {ray_start, ray_direction :: Vector3}
   ray_point :: Ray -> Double -> Vector3
   ray_point (Ray s d) t = s + d |* t
Much more compact, and yet much more /readable/ at the same time.
These, of course, are mere trifles. Let us get to the real meat of the
problem. Now, we need to implement shapes somehow. The /obvious/ thing
to do is copy the Java version; define a class for shapes, and then
create various data structures representing concrete shapes:
   class Shape s where
     isect  :: s -> Ray     -> [Double]
     normal :: s -> Vector3 -> Vector3
     inside :: s -> Vector3 -> Bool
   data Sphere = Sphere {center :: Vector3, radius :: Double}
   instance Shape Sphere where
     isect (Ray s d) (Sphere c r) = ...
   data Plane = Plane {normal :: Vector3, offset :: Double}
   instance Shape Plane where
     isect (Ray s d) (Plane n o) = ...
Notice the isect function. In Java, we have /three/ functions for
efficiency; one function only bothers to compute /whether/ there are any
intersections, another that only bothers to compute the /first/
intersection, and another which computes /all/ intersections.
Haskell's lazy evaluation makes this quite unnecessary. All we need is
/one/ function which returns all intersections in a lazy list.
Inspecting whether the list is empty evaluates just enough of isect to
answer this question, and no more. And obviously, accessing only the
first solution does not cause any further solutions to be computed. Note
we're actually doing /better/ than Java: If our CSG happens, at
run-time, to need the first /three/ intersections but no further, then
only these are computed.
(In fairness, we could use an Iterator in Java to achieve the self-same
thing. The hasNext() function would enable intersection tests without
computing the actual location, and next() would compute one additional
intersection. It would be really quite a lot of work to set up this much
lazy evaluation manually, though. Haskell gives it to us for free!)
You can certainly do things this way. There is a snag, however. If you
stick to Haskell 2010 (the currently published official language
specification), you cannot easily make a list of shapes. Because all the
elements of a list have to be of identical types. And (for example)
Sphere is not the same type as Plane, even if they do both implement the
Shape class (and possibly other classes like Eq or Show). There is no
way to say "a list of everything that has these methods".
GHC adds such a way. It's called
   {-# LANGUAGE ExistentialQuantification #-}
It could more accurately be called "existential /type/ quantification",
or better yet "hidden type variables". But whatever. It lets you write
   data AnyShape = forall s. Shape s => Wrap s
With this incantation, Sphere is still a different type from Plane, but
if you take a Sphere object and apply Wrap to it (or any other type that
implements Shape), it becomes an AnyShape type. So you cannot write
   [sphere 0 1, plane 1 0]
but you /can/ write
   [Wrap (sphere 0 1), Wrap (plane 1 0)]
and this is valid. Notice, however, that it is impossible to write an
"unwrap" function. Because once you "wrap" something, its original type
information is lost forever, so there's no way in hell to know what type
to cast it back to.
(More precisely, all type information is lost at compile-time, just like
in C or Pascal. It's called "type erasure".)
You can't write an unwrap function, but what you /can/ do is make
AnyShape itself an instance of the Shape class:
   instance Shape AnyShape where
     isect (AnyShape s) r = isect s r
Now we still can't unwrap an AnyShape, but we don't need to. We can just
treat AnyShape like a normal Shape instance.
You can't do any of this in Haskell 2010. "forall" is not a valid
keyword there. The best you can do in Haskell 2010 is to define
   data AnyShape =
     AS_Sphere Sphere |
     AS_Plane  Plane  |
Every time you define a new Shape instance, you need to update this
giant monolithic data declaration. Yuck!
But wait... Actually, there is a simpler way. What do we want to /do/
with our list of shapes? All we /actually/ want to do is execute shape
methods. But because functions are first-class in Haskell, we can
actually solve this in an unusual way. Rather than storing a data
structure representing the shape and providing a way to statically look
up the correct ray-intersection function, we can just STORE THE
INTERSECTION FUNCTION!
Well, actually we've got /three/ functions. But we can make a data
structure which stores all three:
   data Shape =
     Shape
       shape_isect  :: Ray -> [Double]
       shape_normal :: Vector3 -> Vector3
       shape_inside :: Vector3 -> Bool
   sphere :: Vector3 -> Double -> Shape
   sphere center radius =
     Shape
       shape_isect  = (\ ray   -> ...),
       shape_normal = (\ point -> vnormalise (point - center)),
       shape_inside = (\ point -> vmag (point - center) < radius)
   plane :: Vector3 -> Double -> Shape
   plane normal offset =
     Shape
       shape_normal = (\ _     -> normal),
       shape_inside = (\ point -> normal `vdot` point < offset)
Now a "shape" is simply an ordinary data structure, which contains some
function pointers. And each sort of shape - a sphere, a cone, whatever -
is an ordinary /function/ which fills out this data structure with the
right function pointers. In particular, every type of shape now has the
same type signature. There is no Sphere type, no Plane type, no Cone
type, there is only a Shape type. So now we can write
and have it be well-typed. (It's [Shape].)
One thing about this transformation: It is now impossible to "look at" a
shape and know anything about it. Before, when each shape was
represented as a data structure, you could look at (say) a sphere and
see where its center is or what its radius is. Now you can't do that.
After the shape is created, it is impossible to do anything with it
except ray intersection tests.
That might be a problem if, for example, you wanted to construct a
bounding volume or something. OTOH, you could just add some more fields
containing function pointers for supporting such volume construction. In
general, whatever abilities you need shapes to have, you add more fields
to Shape to support that.
Notice that with our fancy AnyShape wrapping technique, you /also/ lose
the ability to do anything except what the Shape class provides. In
fact, GHC internally implements that particular trick by doing exactly
what we're manually doing here - storing a dictionary of function
pointers. But doing it by hand means you don't need any unofficial
language extensions.
OK, so we can solve the shape problem. Now how about a camera?
Well, this is where the fun /really/ starts. A camera simply maps an
image plane coordinate to a ray. So in Haskell, a camera is /just a
function/!
   type Camera = Vector2 -> Ray
Similarly, a Texture becomes utterly trivial:
   type Texture = Vector3 -> Surface
In general, and Java class that has "just one method" can be turned into
a plain vanilla Haskell function. That means that Surface is just a
function, although we need to think carefully about what arguments it
needs. As it turns out, Surface needs quite a few items of data, all of
similar types. Since function arguments are unnamed in Haskell, it's
probably a good idea to define a data structure. (Otherwise we'll
forever be supplying the arguments in the wrong order and causing weird
bugs that the compiler can't catch.)
   data RayIsect =
     RayIsect
       isect_point     :: Vector3,
       isect_direction :: Vector3,
       isect_normal    :: Vector3
   type Surface = Scene -> RayIsect -> Colour
Notice, again, that we can fill out /all/ fields, and then lazy
evaluation will skip any calculations we don't need. In particular,
Surface types that don't depend on the surface normal can skip the
surface normal calculation.
With the definitions above, a "constant texture" becomes so trivial it's
barely worth defining a name for it. You can just write "const s" and
you're done. Let's look at some simple instances:
   cam_orthographic :: Vector3 -> Vector3 -> Vector3 -> Vector3 -> Camera
   cam_orthographic v0 vx vy vz =
      \ (Vector2 x y) = Ray {start = v0 + x *| vx + y *| vy, direction = vz}
   cam_perspective :: Vector3 -> Vector3 -> Vector3 -> Camera
   cam_perspective vx vy vz =
      \ (Vector2 x y) = Ray {start = v0, direction = vnormalise (x *| vx
+ y *| vy + vz)}
   sur_ambient :: Colour -> Surface
   sur_ambient c = \ _ _ -> c
   sur_diffuse :: Colour -> Surface
   sur_diffuse c =
     \ scene isect ->
       let
         fn light =
           if shadow_test scene light isect
             then cBlack
             else c *| (light_point light `vdot` isect_point isect)
         colours = map fn (scene_lights scene)
       in sum colours
   sur_reflect :: Colour -> Surface
   sur_reflect c =
     \ scene isect ->
       let
         v_in   = isect_direction isect
         v_norm = isect_normal isect
         v_out  = v_in - 2 * (v_in `vdot` v_norm) *| v_norm
       in trace_ray scene (Ray {start = isect_point isect, direction =
v_out})
Recall that in Java, ever single one of these things would be an entire
class, with the "public class Woo extends Wah" and the field declaration
and the constructor declaration, and only THEN do we get to writing the
bit of code that actually does something useful.
In Haskell, we just write the useful bit. All of the stuff about is
useful code, and no filler. It's all stuff implementing actual maths,
not micromanaging object construction or field initialisation or whatever.
So if you can't access object internals, how can you implement spatial
transformations? Easy: You transform the coordinates before input.
   transform_texture :: Transform -> Texture -> Texture
   transform_texture transform texture =
     \ point -> texture (transform point)
Now wasn't that easy? Compare Java:
   public class TransformTexture extends Texture
     public final Transform Trans;
     public final Texture   Text;
     public TransformTexture(Transform t1, Texture t2)
     {Trans = t1; Text = t2;}
     public Surface GetSurface(Vector3 p)
       return Text.GetSurface(Trans.Apply(p));
What a load of waffle! Especially when you consider that a typical
Haskeller would probably write
   transform_texture = flip (.)
and be done with it!
(This works because this convoluted-sounding concept of "apply a
coordinate transformation to the input before passing it to the texture"
is really nothing other than /function composition/, which is a
well-known concept in Haskell. A coordinate transformation maps a point
to a point, a texture maps a point to a Surface. Combining these steps
is clearly function composition. When you think about it like that...
suddenly it's /obvious/ that this is a trivial thing.)
When you start thinking of (say) a coordinate transformation as a
trivial function rather than as some complex active "object" which has
"behaviour", "state" and "identity" which needs "constructors" and
"destructors" and "gettters" and "setters" and "reflection" and... Well,
suddenly all your problems start to look a hell of a lot simpler.
Take a look back at all those "map" classes I had. In Haskell, each of
these is merely a function. It's hardly worth assigning names to them.
Indeed, in Java I had trouble picking suitably descriptive names for all
the combinations and variations I could come up with. In Haskell, I
don't need to bother. If I want to deal with functions that map points
to scalars, I can just /call/ them "functions that map points to
scalars". Which is actually less confusing then naming them ScalarMap or
whatever. It more succinctly conveys what they do.
What have I just said? The short summary is that Haskell, the finest
functional programming language in the land, is superior to Java, one of
the more sucky OOP languages. Not exactly a revelation, is it? I think
I'm going to go outside for a while...
Subject: Re: Haskell vs Java: Building a ray tracer
Date: 28 Jun 2012 11:04:39
Message: <4fec7287$1@news.povray.org>
Am 28.06.2012 12:07, schrieb Invisible:
You're wrong there.
When querying the "first" intersection, you're not querying for "the
first intersection that our algorithm cranks out", but "the intersection
that is closest to the camera, of all the intersections cranked out by
our algorithm".
In many cases, to get this answer you'll need to compute /all/
intersections and sort them by spatial distance, which will necessarily
trigger evaluation.
Heh. So standard Haskell obviously sucks as much as Java without generics.
While that may sound nice, intersection computations might already have
involved computation of interim results that would come in handy for
normal computation as well; how do you address that?
Date: 28 Jun 2012 12:18:53
Message: <4fec83ed$1@news.povray.org>
>> efficiency;
> You're wrong there.
> our algorithm".
In my implementation, it is an (unchecked) requirement that the result
list is always returned sorted in depth order. For planes and spheres,
this is trivial to arrange. For some more general shape where you can't
easily determine ahead of time which intersection is nearest, that
particular shape would have to perform explicit sorting. (This,
naturally, destroys most of the laziness properties.)
...unless you scroll down to the bit where I show you exactly how to
easily do this in standard Haskell. :-P
Hmm, that's an interesting idea. I hadn't thought of that. None of the
ray tracers I've ever implemented has had any shapes that complicated,
so none of them would handle this duplication of work. It ought to be
fairly straightforward (in Haskell or Java) to rectify that, however...
Date: 28 Jun 2012 12:34:16
Message: <4fec8788@news.povray.org>
[SNIP Tolstoi novell about java]
> (Vector3 x1 y1 z1) + (Vector3 x2 y2 z2) = Vector3 (x1+x2) (y1+y2) (z1+z2)
Don't you still have to define how the sum fonction handles this Vector3
object?
> and then write
> Vector3 1 2 3
> to create a vector.
Slight correction, in Java, you only define the constructor once, not at
every call.
Then,
vs.
Vector3 1 2 3
Is only a matter of language syntax.  You save 7 characters.  Whooptidoo!
Not quite.  Since I don't speak Haskell, I wouldn't even know what two
lines of codes actually mean.  I knind of figure that the :: specifies
that data type (ray_point is of type ray), but I have no idea why you
have the "-> Double -> Vector3" added at the end.  Likewise, not knowing
what "!*" means makes the second line hard to follow.
> class Shape s where
You mean like AllIsect() does in Java.
You already do it for AllIsect().  There's no additional work necessary.
Also, bug report time:  AllIsect() returns an array of doubles, yet you
don't specify the size of the array in question.  How would the caller
know how the size of the array?  (Disclaimer: I'm not very fluent in
Java, so if there's some embedded mechanism to prevent your from falling
off the edge of an array, nevermind)
[more snippage]
So a simple language syntax is a good thing, except when it isn't! :P
> data RayIsect =
> RayIsect
> \ (Vector2 x y) = Ray {start = v0, direction = vnormalise (x *| vx + y
> *| vy + vz)}
I don't know why you name your camera parameters vx, vy, vz.  I guess
I'm used to POV's location, up, right and look_at...
> sur_diffuse c =
> \ scene isect ->
> let
> fn light =
> then cBlack
> in sum colours
> sur_reflect c =
> \ scene isect ->
> let
> in trace_ray scene (Ray {start = isect_point isect, direction = v_out})
No, you'd have one camera class, and have different calculations based
on the value of the camera.type member, or two dereived classes that
inherit from a generic camera class, if you prefer.
Likewise, you'd have only one surface class with ambient, diffuse and
reflect being member methods, with another method called FinalColour
that combines the colour of those three and returns the overall colour
obf the surface at that point.
You don't need to micromanage object construction and field
initialisation in Java or C++ either, but if you don't you better be
sure that no one will ever try to access an uninitialized member!!!
By the way, what happens in Haskell if you try to access an unitialised
member?
I think you have the whole idea backwards.  Each object should know how
it is being transformed (think about it, how else can you determine
which face is being intersected by a ray?), therefore can take care of
those transformations internally when computing the object.FinalColour
value, so the transformation computations will have access to those
private members, you don't need to do any of the gymnastics you just did.
No, you've just showed that trying to use one language in a way that is
best suited for another language gets ugly.
I remember a discussion a long, long time ago, in a compl.lang.lisp far,
far away of number-crunching speed comparisons (IIRC, positions of the
planets around the sun for a command-line spcified date) between Lisp
and C, where the Lisp programmers had to write all kinds of additional
code to turn off all kinds of bounds, checking, automatic type
conversions, etc... just to come with comparable speeds.
If you _know_ that you will never run out of bounds with a double or an
int, then the C porgrammer will cliam victory.  However, If you aren't
absolutely sure that you can't end up with a negative orbit radius, or a
heartrate larger than MAX_INT, then Lisp's automatic bounds checking
will save you some time-consuming assert() calls and test cases.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 28 Jun 2012 13:18:59
Message: <4fec9203@news.povray.org>
> Don't you still have to define how the sum function handles this Vector3
> object?
No. The sum function just calls the (+) function, so as long as (+) has
been defined, sum will work.
(Actually, that's not completely true. sum also uses zero, so you have
to define what a zero vector is. That's the rest of the Num instance
that I left out with "...")
> every call.
Well, yes. You have to write a constructor once per class, which means
if you need a lot of classes, you end up writing a heck of a lot of
constructors.
> Then,
> vs.
> Vector3 1 2 3
Sure. I'll give you that one.
> lines of codes actually mean. I kind of figure that the :: specifies
Given that the equation of a straight line is f(t) = S + Dt, I would
have imagined that s + d |* t would relatively stright-forward. (Oh, the
puns...)
Do you not think that, once you've learned a little syntax, having to
read just two lines of code is easier than having to wade through 12? (I
guess that one isn't all that easy to answer objectively...)
In Java, calling AllIsect() causes all intersections to be computed. In
Haskell, calling the isect function does /not/ necessarily cause all
intersections to be computed. Only the ones you actually "look at".
That's the point I'm making.
> How would the caller know how the size of the array?
Java stores the size of all arrays and lets you query it at run-time. It
also throws exceptions on all array bounds violations. Java is
supposedly a "safe" language, remember? (It also throws exceptions on
all null pointer accesses, for example.)
>> In general, any Java class that has "just one method" can be turned into
Haskell doesn't have named arguments, so you can trivially define a data
structure and solve the problem that way. It's no big deal.
Java doesn't let you mention arguments by name when invoking a function
either. But if you have an IDE, it will at least show you what the
argument names are in the function definition, which can be good
enough... You're still likely to get it wrong, though. Java doesn't let
you explicitly assign values to names at all, unless you start making
public fields writable or manually writing lots of getter and setter
methods.
> I don't know why you name your camera parameters vx, vy, vz. I guess I'm
More like location, up, right and forward. If this wasn't example code,
you would probably write down documentation for what all these
parameters are actually supposed to mean, the assumptions about them
(e.g., the code is assuming that some of these are /unit/ vectors, and
others aren't), and so on.
This is about as anti-OO as you can get.
Which would be... one class per camera type, as I asserted. :-P
Well, yeah, you could write one Surface class which implements every
possible rendering model all at once. It's more modular to make a
separate class for each term, but you could go down the monolithic route
if you want.
>> whatever.
In Haskell, you write down the name of the thing, what fields it should
have, and what their types are. The end.
In Java or C++, you have to write whether each field is public or
private, whether it's constant or not, you have to manually write the
function that takes all the values and assigns them to each of the
fields, and in general you have to write a whole /bunch/ of code to get
the job done.
Then again, if you're working in Java or C++ (more so Java, since C++
isn't pure-OO), you shouldn't be writing too many classes which just
passively hold on to some data. Objects are supposed to "do" stuff.
> member?
It throws an exception saying "this field is uninitialised". It also
generates a compiler warning.
Composing two functions is hardly "gymnastics".
Essentially, there are two ways you can implement a coordinate space
transformation:
- Transform the object and leave the coordinates alone.
- Transform the coordinates and leave the object alone.
Both of these are equivalent, and equally valid, ways to solve the
problem. The latter has the advantage that you don't have to reimplement
the transformation code for every object; you can write it just once.
Ray tracing is all about mathematical operations. Vector
transformations, set unions, spatial subdivisions, etc. And Haskell
makes it really, really easy to write that code. Java is completely
capable of doing everything Haskell is doing. It just makes it much more
work.
...which is why I use a programming language that defaults to safe
rather than fast?
(It still amuses me when Oracle claims that Java is a "safe language".
Compared to Haskell, it's pretty damned weak, actually...)
Date: 28 Jun 2012 14:31:18
Message: <4feca2f6@news.povray.org>
LOL :-D
Regards
Date: 28 Jun 2012 15:37:43
Message: <4fecb287$1@news.povray.org>
>>> (z1+z2)
>> object?
Makes sense.
> puns...)
Ok.  I Still don't know what the -> thingamadoodle does.
My point was that you don't have to wade through the constructor(s) and
member function definition to understand what
does either. [as long as your method names aren't too obfuscated, of course]
Besides a lot of people gripe about Java not supporting operator
overloading.  You are not the only one.
As Clipka pointed out, you need to calculate all intersections anyway to
find the nearest one.
Thanks.  That's why I asked if there was automatic bounds-checking.
> methods.
[macho programmer mode=on]
IDEs are for sissies.  In my days, we programmed in vi and we liked it.
  If we weren't sure about the order of parameters, we'd open the .h in
another buffer and search for the function, or look at the man page for
standard stuff.
[macho programmer mode=off]
Actually, we'd burn out the SHIFT-F1, or CTRL-F1, or whatever the hotkey
was in Borland's Turbo IDE!
I was just pulling your leg.  You can call your variables Fred, Pebbles
and Bambam if you want to.  Just don't go about making readability
claims, if you do, though. :)
So if I want to desing a red/black binary tree, I'd have to define a red
class and a black class, instead of having colour as a member value of
my node class?
The type of projection, be it isometric, orthographic, perspective,
wall-eye, etc... only affects the direction the rays shot.  It's a lot
simpler to have a switch{ } statement in one method than to reinvent
five or six classes just because one of the methods is different (cf.
you earlier comment about "one-method-classes").
If you are going to publish your stuff as a libray and expect people to
build on it, then, of course, it makes sense to create new classes for
each camera type derived from a common one, making it easier for someone
to come along and add new camera types (e.g.: red/green stereoscopic)
Agreed. However, you don't need to rewrite the constructor(s) and other
methods, unless you really need to.  So, in the end, it just amounts to
the syntactic differences between the two languages.
> if you want.
I fail to see in which circumstance, you'd need to know anything other
than the final colour of an object, so I don't see the advantage fo
computing the ambient, diffuse and reflective components of a point
outside of the object itself.  Again, feel free to correct me if I'm
overlooking something obvious, such as radiosity.  I'm not an algoritm
expert.
>>> whatever.
> the job done.
public/private/protected is important when you make libraries that are
intended to be reused.  This is to prevent other programmers from
mucking around with the internals of your objects and potentially
creating all kinds of problems at runtime, such as memory leakage, or
buffer overflows.  My OO theory is very rusty, but back in the day,
objects were supposed to be treated as black boxes and you only
interacted with them via public or protected methods.  Leaving
everything wide open means you can either shoot yourself in the foot, or
the compiler needs to add a lot of baby-sitting code that will prevent
you from doing it at run-time (cf. my earlier anecdote about Lisp).
This may not be all that important on a Win/Mac/*NIX machine with 8GB of
ram, but in the mobile app area, the added bloat is a constraint.
>> member?
> transformation:
Huh?  While you are right that in both instances, the transform method
or function needs to be called for each point calculation, a cylinder,
an array light and a marble texture don't have the same parameters, so
you _do_ have to rewrite the transformation code for each one anyway.
To me it seems a lot more obvious to have an object call its internal
transform() method while computing the color of a point on its surface,
than to to have to externally figure out which transform function to
call based on the type of object we're dealing with.
> work.
> rather than fast?
Huh.... Earlier you were complaining about having to specify public,
private and const in Java.  _That_, along with garbage collection, is
the safety they're talking about.
Date: 28 Jun 2012 16:27:23
Message: <4fecbe2b@news.povray.org>
>> puns...)
Valid point is accepted.
> course]
With a class, there's lots more code to write, and lots more to read.
With this function, you're only writing the actual "functional parts",
if you will. You don't have to perform a bunch of extra busy-work every
time you want to do something.
Oh, no. I don't claim that any of my remarks are /original/. ;-)
And as I pointed out, this is not the case for many objects. E.g., a
sphere has two points of intersection. These are the solutions to a
quadratic equation. And we all know that the way to solve that is
   x = -b +/- Sqrt(b^2 - 4ac) / 2a
To find the "nearest" intersection, you merely pick the "-" rather than
the "+". Done.
There are shapes where the procedure is not so simple. But that doesn't
mean we can't have the benefit from the cases where it /is/ this simple.
Is it wrong that I actually know who those people are? o_O
>>>> class.
> my node class?
No. Because nodes need to change colour, and in Java [and most other OO
languages] objects can't dynamically change class.
More to the point, red/black is just a boolean switch that controls
which way a node is processed. Much like a priority on a job object, or
whatever. However...
...the camera type completely changes the entire algorithm. Writing a
giant switch{} statement to cover every possible camera type is
1. the exact problem that OOP was supposed to get rid of
2. prevents anybody adding new camera types
One of the fun things about Java is that it supports dynamic loading.
You can throw a Jar file in a folder, and have the ray tracer load new
code and immediately use it, without recompiling.
Or at least, you can if you /don't/ code your application using giant
switch{} statements everywhere. :-P
Actually, yes you do.
Because Java is retarded, you're not allowed to inherit constructors.
You can inherit regular methods, but not constructors. You have to
explicitly write out the new constructor and make it explicitly call the
old one, or it won't compile.
How's that for stupid?
>> if you want.
> than the final colour of an object, so I don't see the advantage for
> expert.
It's the same thing as with cameras. If you implement each surface
property as a separate class, then you can add more later. But if you
implement one giant class that has every possible surface characteristic
hard-coded into it, you can't do that any more. It's less modular in
that way.
>> the job done.
> intended to be reused. This is to prevent other programmers from mucking
> around with the internals of your objects and potentially creating all
> kinds of problems at runtime, such as memory leakage, or buffer
> overflows. My OO theory is very rusty, but back in the day, objects were
> supposed to be treated as black boxes and you only interacted with them
> via public or protected methods. Leaving everything wide open means you
> can either shoot yourself in the foot, or the compiler needs to add a
> lot of baby-sitting code that will prevent you from doing it at run-time
> (cf. my earlier anecdote about Lisp). This may not be all that important
> on a Win/Mac/*NIX machine with 8GB of ram, but in the mobile app area,
In the case of a ray tracer, you basically build a big static data
structure (the scene), and then run some complicated algorithms over it
(the ray tracer). On top of that, there are almost no special invariants
which these data structures need to satisfy, meaning that there's almost
no way to break the program. So issues like whether something is
writable or not are pretty much moot in this specific instance.
Obviously in other instances, it's rather important. Critical, even.
In Java, you can declare fields as constant, meaning that even if
they're public, you can't alter them anyway. (But beware: If the field
points to a mutable object, you /can/ still mutate that!) For the
ray-tracer, you could equally declare everything private. You don't
actually need field access at all, except within the object itself. As I
say, in this example, it's all fairly moot either way.
Writing "public" or "private" isn't so bad I guess. But having to define
all the fields, and then manually write a constructor with lists the
same information /again/, and then manually assigns all the arguments to
the fields... that's just tedious. Again, in some other situation, you
might want your constructor to actually perform some real initialisation
work. But in this specific case, there's nothing to initialise.
Haskell doesn't make me write initialisers. If I want one, I can write a
special initialisation function and then do some mojo to prevent people
forgetting to use it. And if I don't need that, I can just leave it.
Either way, I'm not manually writing useless boilerplate code.
>> transformation:
> Huh? While you are right that in both instances, the transform method or
> function needs to be called for each point calculation, a cylinder, an
> array light and a marble texture don't have the same parameters, so you
> _do_ have to rewrite the transformation code for each one anyway. To me
I will try again. Suppose for argument's sake we want to rotate an
object through 13 degrees. You can do this two ways:
- Tell the object "rotate yourself 13 degrees", and have the object
update all its coordinates and so forth. Of course, every type of object
is defined in a different way. For a sphere, you'd rotate just the
center coordinates. For a cube, you'd rotate two corner coordinates. For
a polygon, you'd rotate each corner coordinate. And so forth.
- Wrap the object in a transform object, and replace the original object
with the wrapped one. Now every time you say "what intersections do you
have with this ray?", the wrapper object transforms the ray, and then
asks the original object "what intersections do you have with this
transformed ray?" The original object has no idea that anything has
changed. You can implement the wrapper object once, and use it to
transform any possible object.
On the downside, the first way involves transforming the object once,
whereas the second involves transforming every individual ray...
>> rather than fast?
> private and const in Java. _That_, along with garbage collection, is the
Java is safer than C, that I'll grant you. But that's not the same as
"safe".
Every time a Java program has an int field and a bunch of public static
final int FOO = 0x384 declarations, you just /know/ that somebody,
somewhere is going to put an invalid value into that field. And then the
programmer must explicitly write a manual runtime check for this
condition, and decide what to do about it if it occurs, and test that
this works.
A Haskell programmer can simply write
   data Mode = Foo | Bar | Baz
and rest safe in the knowledge that the Mode field will /always/ be one
of the tree valid possibilities. No need to write code to check this, no
need to write test cases to check for it. No need for the client to
guess what happens if this isn't true. Much. Safer.
Java inherits C's strange conventions of returning an int value for
whatever, unless there's in error, in which case it returns a negative
integer. And if you forget to test whether the result value is negative,
you now have a runtime bug.
(Exhibit A: Reader.read() returns int, not char, because that way it can
return a character code unless EOF is reached in which case it returns
-1. WTF?)
Haskell has Maybe. If an operation can fail, you return Maybe Int
instead of just Int. The API tells you "this operation can fail". You
can't forget this fact. If you don't check for failure, your code does
not compile. (Stick /that/ in your pipe and smoke it, Mr
Checked-Exceptions-Unless-They-Subclass-java.lang.Error :-P ) You can't
just "ignore" failure; you have to actually define what to do about it.
(Although you can sort-of get away with returning a plausible but wrong
default value if you're hell-bent on writing bad code.)
C behaves in undefined ways on a null pointer. Java throws an exception
on a null pointer. Haskell doesn't /have/ pointers, so they can never be
null. :-P
I could go on at length... but I won't. (Mainly because I know nobody
except me cares.)
Date: 28 Jun 2012 18:30:00
Message: <web.4fecda86321519bc773c9a3e0@news.povray.org>
Invisible <voi### [at] devnull> wrote:
[tldr]
> to cast it back to.
what about in heaven?  In Lisp there's no such hellish troubles. :)
So your solution to get away from the complaints of the compiler is to have all
types be the same single type?  Yes, sounds like the Lisp solution too. ;)
you do good. :)
Date: 29 Jun 2012 01:37:54
Message: <4fed3f32@news.povray.org>
Why exactly would you need generics in order to make a list of different
shapes? (Being able to do such a thing is kind of the very definition of
object-oriented programming.)
