POV-Ray : Newsgroups : povray.off-topic : Sky Server Time
14 May 2025 22:26:18 EDT (-0400)
  Sky (Message 1 to 10 of 28)
Subject: Sky
Date: 15 Jun 2012 08:13:41
Message: <4fdb26f5$1@news.povray.org>
I looked outside a little while ago, and observed that the sky was blue.
But when I asked POV-Ray to do some radiosity with a blue sky, the
entire scene came out blue. Which, logically speaking, isn't surprising.
If the sky is blue, clearly it's emitting blue light, which would result
in everything being illuminated blue.
And yet, when I look outside, the world is /not/ tinged blue. So... WTH?
Subject: Re: Sky
Date: 15 Jun 2012 08:50:00
Message: <web.4fdb2f65fb965d0d5b7d07940@news.povray.org>
Your visual cortex is good at correcting for it. Also, the sun casts a lot more
light than the sky, so in direct sunlight the effect is muted. And of course,
cloud cover will hide blue sky-light and replace it with diffuse sunlight.
On a cloudless day, I think the blue tinge to shadows is quite obvious.
Subject: Re: Sky
Date: 15 Jun 2012 08:52:07
Message: <4fdb2ff7$1@news.povray.org>
Le 15/06/2012 14:13, Invisible nous fit lire :
If the sky is "blue", why do you see a yellow sun ?
What happened to the sky at night so that the moon is white ?
IIRC, the blue of the sky is due to the variant IOR (vs void) of the
atmosphere for the "white" light: the blue is turned more toward the
earth (well, sooner: it might explains a bit the redish-moon eclipse).
It's not like the sky is rgb(0,0,1) (or even rgb(0,0.8,1)) but rather
more alike hsl(240, ??, 1000000) (outside the traditional rgb cube)
or in povray term, more like blue with a very high transmit colour of
white, maybe with a subtle tinct of blue inside... (which cannot be
expressed so far in the current SDL)
Strictly speaking, the sky does not emit light. It's a dispersing media
at best. Faint media, of large dimensions.
Also, do not forget the capability of the eyes to accomodate to various
intensity of light. The white-balance done with camera is needed in
professional production: the light is not always the same.
Subject: Re: Sky
Date: 15 Jun 2012 09:14:52
Message: <4fdb354c$1@news.povray.org>
Am 15.06.2012 14:52, schrieb Le_Forgeron:
Not really; the dispersion (wavelength-dependency of IOR) of the
atmosphere in the visible light spectrum is rather low. But the gases in
the atmosphere scatter a certain portion of the sunlight's photons, and
at the blue end of the visible spectrum this portion is bigger than at
the red end.
Subject: Re: Sky
Date: 15 Jun 2012 09:38:20
Message: <4fdb3acc$1@news.povray.org>
Because there's usually a light_source{ <0,0,0> color Yellow*6500 } in
the scene.
Look at shadows on snow or on a beach, they'll be blue.
http://www.free-desktop-backgrounds.net/free-desktop-wallpapers-backgrounds/free-hd-desktop-wallpapers-backgrounds/122079702.jpg
http://www.amandapair.com/wp-content/uploads/2009/09/shadows-in-sand.jpg
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Subject: Re: Sky
Date: 15 Jun 2012 11:14:10
Message: <4fdb5142@news.povray.org>
  The sun is not yellow. It's white.
Subject: Re: Sky
Date: 15 Jun 2012 11:28:32
Message: <4fdb54a0@news.povray.org>
  Actually it is. Consider this rendering, for example:
http://www.ignorancia.org/uploads/images/rocky-desert/rocky-desert-09-sbtf.jpg
  Everything's tinted blue. Does it look unrealistic? No.
Subject: Re: Sky
Date: 15 Jun 2012 12:04:31
Message: <4fdb5d0f$1@news.povray.org>
I had always assumed that the actual sunlight is white, and the Earth's
atmosphere scatters the blue end of the spectrum more than the red, thus
resulting in a sky that looks blue and a sun that looks comparatively
yellow.
Then again, on some evenings, the sky actually appears to show a (very
unsaturated) rainbow gradient, with a discernible green band...
Subject: Re: Sky
Date: 15 Jun 2012 12:05:45
Message: <4fdb5d59$1@news.povray.org>
> the scene.
So I just need to turn up the Sun a bit higher and make it more yellow?
Those are some neat images. They both look like the Sun is quite low in
the sky though; and we all know that when that happens, you can get
strange colours happening.
Subject: Re: Sky
Date: 15 Jun 2012 12:06:12
Message: <4fdb5d74$1@news.povray.org>
Uh... doesn't actually look all that blue to me.
