POV-Ray : Newsgroups : povray.off-topic : Complex numbers Server Time
25 Feb 2026 20:56:50 EST (-0500)
  Complex numbers (Message 1 to 10 of 18)
Subject: Complex numbers
Date: 7 May 2012 17:09:14
Message: <4fa839fa$1@news.povray.org>
Question: Why can't you extend the complex numbers to 3D space?
Answer: Because the hairy ball theorem says so.
Yes, that's right. There really is a theorem called "the hairy ball
theorem". Isn't that wonderful? :-D
Perhaps even more satisfyingly, what this theorem /says/ isn't some
obscure exotic thing that only a mathematician could understand.
Actually, it just says you can't comb the hair on a ball flat. You
always end up with at least one tufty bit. (You /can/ comb the hair flat
on a flat plane, a torus, or a number of other 3D shapes. Just not a
sphere.)
Subject: Re: Complex numbers
Date: 7 May 2012 17:28:10
Message: <4fa83e6a$1@news.povray.org>
Le 07/05/2012 23:09, Orchid Win7 v1 nous fit lire :
> sphere.)
It's even more deeper. The theorem says you cannot comb a sphere of odd
dimension, but that even dimension is ok.
(2D sphere == circle, 4D sphere is left as an exercise)
That's also why, even if complex cannot be extended in 3D, they can in
4D. (look at quaternion...
Notice that there is a meteorological application of the theorem: there
is always on earth at least one place where the horizontal speed of wind
is null.
Date: 7 May 2012 17:33:02
Message: <4fa83f8e@news.povray.org>
Orchid Win7 v1 escreveu:
is it so hairy that numbers got scared to death and complexed? :p
a game sig: http://tinyurl.com/d3rxz9
Date: 7 May 2012 21:53:24
Message: <4fa87c94@news.povray.org>
Someone also figured out that you can do probability with 1D numbers and 2D
numbers, but not any higher dimensions. The speculation is that's why
quantum effects have the same math as waves and not something either "common
sense" or more baroque than they are.
I.e., you can do math on "the probability that X happens given that Y
happens" and deal with "and" and "or" and Bayesian probabilities, using
either real numbers or complex numbers, but not 3D numbers.
I don't understand the proof myself, but so I'm told.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 8 May 2012 03:29:43
Message: <4fa8cb67$1@news.povray.org>
Le 08/05/2012 03:53, Darren New nous fit lire :
> 2D numbers, but not any higher dimensions.
Are you talking about random movement having a non-null (aka about 100%)
probability of returning to your starting point (sort of) ?
In 1D (moving along a line), with whatever balanced distribution, it
seems rather obvious.
In 2D (moving in a plane), it's less obvious but you will cross your
previous path at a moment or another.
but once in 3D, you're lost and would quasi-never cross any points from
your previous path.
Date: 8 May 2012 03:36:20
Message: <4fa8ccf4$1@news.povray.org>
Le 08/05/2012 09:29, Le_Forgeron nous fit lire :
> your previous path.
Oh, I forgot also a difference as dimensions are raised:
1D & 2D: you can evaluate the length/surface of any grid-aligned
line/polygon by counting the number of element of the grid inside the
limit. (you need to count twice: one for grid's nodes fully inside, and
another for grid's node also on the perimeter)
That computation fails once in 3D or more!
Date: 8 May 2012 04:31:47
Message: <4fa8d9f3$1@news.povray.org>
>> sphere.)
Indeed.
> 4D. (look at quaternion...)
No. Quaternions do not form a field. Neither do the hypercomplex
numbers, nor any of the other 4D generalisations.
> is null.
Interesting...
Date: 8 May 2012 10:15:14
Message: <4fa92a72$1@news.povray.org>
That's irreverent to Le_Forgeron's point. The application of the hairy
ball theorem here does not depend on the numbers forming a field.
Date: 8 May 2012 10:26:12
Message: <4fa92d04$1@news.povray.org>
I should clarify, I took the fact that the extension wouldn't be a field
to be implicit in Le_Forgeron's point, since the Hairy ball theorem's
use doesn't depend on the numbers forming a field.  Not saying your
reading was technically incorrect.
Date: 8 May 2012 10:34:02
Message: <4fa92eda$1@news.povray.org>
Do you happen to remember the name of this theorem?  I'm curious how
fierce a devil is in the details.
