POV-Ray : Newsgroups : povray.off-topic : I'm in the mood for monads Server Time
10 Sep 2025 12:10:42 EDT (-0400)
  I'm in the mood for monads (Message 1 to 10 of 93)
Subject: I'm in the mood for monads
Date: 20 Apr 2012 09:41:03
Message: <4f91676f$1@news.povray.org>
One Haskell VFAQ is "What is a monad?"
Well, that's kind of like asking "What is a number?" Imagine you're in
the steamy jungles of some distant land, when you meet a wild tribe of
natives, who you are inexplicably able to communicate with. Suppose
these people don't know anything at all about numbers, and one of them
asks you "what is a number?"
Now, we use numbers all the time, right? *Everybody* knows what a number
is. But if you meet somebody who has never encountered this concept,
where would you even *start*? How can you explain what a number is? How
can you even begin to explain why that's useful?
Now try explaining what a number is *briefly*.
Hard, isn't it? You either end up saying something so abstract that it's
utterly cryptic, or you end up writing a huge long complex-sounding
example. Either way, numbers sound like an amazingly complicated idea...
but they aren't.
A similar thing can be said about monads. A quick Google search will
reveal an entire cottage industry of people trying to explain them. If
anything, this makes it seems like they *are* hard to understand. But
really, they aren't. It's just that they're not "like" anything else
familiar that I can easily point at. They are a really abstract concept,
which makes them kind of hard to grasp.
The short version: A monad is one specific way of chaining operations
together.
When all the fuss and the hype and the endless tutorials are over,
that's all monads really come down to. They're just a particular way of
linking operations together.
(Some people incorrectly think that a monad is for /sequencing/
operations. This is not correct. They /can/ be used for that, but that's
not what they're "for", as such. Other people think that monads are for
managing mutable state. Again, you /can/ use them to do that, but that's
not all they do. It isn't their fundamental purpose.)
The medium version:
A monad is something that has a "bind function" which links calculation
steps together. (In Haskell it's named ">>=", but I'm going to call it
"the bind function", because that's a damned-site easier to read.) All
the bind function actually does is to extract the result from the
previous step, and feed it into the next step.
Pretty simple, eh?
Now, if the bind function /just/ does that, the result isn't very
interesting. In fact, you could achieve exactly the same thing yourself
without bothering with all this monad malarkey. And that brings me to a
very important point:
   Merely BEING A MONAD isn't especially useful.
   Every USEFUL monad does something else IN ADDITION to just being a monad.
(A monad that "does nothing" is called the identity monad. Rather like
the identity function, this /sounds/ completely pointless, yet turns out
not to be...)
In "normal code", you might call one function, pass its result to
another function, and then pass the result of that to a third function.
In "monadic code", instead of each function returning a "result", it
returns some sort of construct which /contains/ a result. And between
each pair of functions, you insert this bind function, which fetches the
result out of one construct and squirts it into the next function.
In Haskell, you can explicitly write out the bind function, such as
   foo x >>= bar >>= baz
Or you can write a so-called "do block", such as
   do
     y <- foo x
     z <- bar y
     baz z
Here the compiler automatically inserts all the ">>=" calls for you
behind the scenes. So the two examples are actually identical. All a
do-block does is insert these extra function calls for you, so you don't
have to do it manually.
Like I said, if the bind function just passed the result along, nothing
especially interesting would happen. The *interesting* part is that you
can write a bind function so that it does hoopy processing between
statements. That's where the fun begins.
The long version:
As you know, in Haskell all variables are immutable. For the moment,
we'll pretend that all data structures are immutable too. Basically,
once you create something, it becomes read-only.
Suppose I'm writing a "solve" function, which takes an equation, and
returns a bool indicating whether the function can be solved or not.
   solve :: Equation -> Bool
Suppose that I've got two equations, and I want to check whether /both/
of them are solvable. That's pretty easy:
   (solve eq1) & (solve eq2)
Suppose that in addition to the equation to solve, you also need to pass
some kind of table containing the equation's context (e.g., the
definitions of any variables it mentions, or whatever). That's still
pretty easy:
   solve :: State -> Equation -> Bool
   (solve s eq1) & (solve s eq2)
[Assuming that "s" holds whatever state it is that the "solve" function
requires as input.]
So far, so good. Now assume that the "solve" function /changes/ the
state as it processes each equation... Ah. OK, now we've got a bit of a
problem.
Basically, the way to handle this is that the "solve" function needs to
return the new, updated state back to the caller, /as well as/ the
actual result it's trying to calculate.
   solve :: State -> Equation -> (State, Bool)
The function where I'm trying to solve both equations also presumably
needs to return the latest version of the state to its own caller, so we
end up writing something like this:
   let
     (s1, b1) = solve s0 eq1
     (s2, b2) = solve s2 eq2
   in (s2, b1 & b2)
On the one hand, this is all simple, straight-forward code, with nothing
particularly complicated happening.
On the other hand... yuck! Our simple 1-line expression has degenerated
into 4 lines of code. And imagine if I wanted to make a dozen calls to
"solve"; I'd end up with a dozen "s"-variables. And in each function
call, I need to make sure I use the correct "s"-variable. You just
/know/ that at some point I'm going to make a typo, or copy-paste
something from somewhere else and forget to tweak the variable numbers...
In short, this is a mess. (I can almost hear the Java programmers at the
back of the room muttering "told you so".) Surely we can do better.
Well, it turns out we can. We can write a monad where the bind function
feeds the /result/ from one function to the next, but /also/
automatically feeds the latest version of the state across too. So now
our functions don't need to /explicitly/ take the state as a parameter,
and don't need to /explicitly/ return it as a result. The monad hides
the plumbing. With that done, I can now write
   do
     b1 <- solve eq1
     b2 <- solve eq2
     return (b1 & b2)
It's still three lines instead of one. But at least I don't have lots of
little "s"-variables scattered all over the place now. I can't possibly
muddle them up and introduce strange bugs because my code is looking at
an out-of-date version of the state. The bind function takes care of
passing along the correct version of the state at each step.
It's still more text than the original. But notice, if "solve"
*modifies* the state, then it potentially *matters* which call happens
first - whether we solve eq1 first or eq2 first. The original
expression, where the state doesn't get altered, didn't specify an
order. Heck, you could solve both equations /in parallel/ if you want.
But if solving the second equation /depends on/ information gleaned from
solving the first one, then it is no longer logically possible to do
that. So the code above is longer because it specifies an execution order.
Right now, I can just hear the Java guys sneering at me.
"So let me get this straight. You had to modify your compiler to accept
a special new syntax which you then convert into a bunch of extra calls
to this complicated new function you wrote... just so you can have
mutable state?... The same mutable state that every REAL programming
language automatically supports out-of-the-box? HAHAHA! Haskell sucks, man!"
In Java of course, you can simply do
   bool b1 = solve(s, eq1);
   bool b2 = solve(s, eq2);
   return (b1 && b2);
and be done with it. Since Java passes everything by reference, solve()
is quite capable of altering "s" just as it is. It doesn't need any
special "monad" to do that. Heck, Java will even let you do
   return solve(s, eq1) && solve(s, eq2);
although now the execution order (I believe) isn't guaranteed any more.
But hey, that's a hell of a lot simpler and easier, right? You know,
using ACTUAL MUTABLE DATA to implement mutable data. :-P
Well, stick this in your pipe and smoke it: Suppose that "solve" can
return MULTIPLE SOLUTIONS. What now? Well, every time you call solve(),
you're going to have to loop over all of the solutions it returns,
right? So the Java code is now going to look something like
   Solution[] s = solve(in, eq1);
   ArrayList<Solution> out = new ArrayList<Solution>();
   for (int lp=0; lp<s.length; lp++)
     out.addAll(solve(s[lp], eq2));
   return out;
Clear as mud, right?
And the Haskell version...? Well, you know what? If you put the
foreach-loop into the bind function itself, the Haskell code remains
EXACTLY THE SAME. All of the existing code still compiles, still runs,
AND DOES THE RIGHT THING. Boom, head shot.
If that doesn't sound like a big deal, try cascading a dozen solve()
calls in Java. Not funny any more, is it? Manually writing a brand new
loop for every individual call. Oh, you could probably do something with
the reflection API to allow you to write the code containing the
foreach-loop just once, and pass it the name of the function you're
trying to call next. But it's still a fair bit of work.
The Haskell code, on the other hand, remains unchanged. Because "going
from step A to step B" has been abstracted out into this "bind
function", we can change how it happens in just one place - the bind
function! So all our code still works the same, we just need to change
the implementation of the monad.
Here's an interesting thing: We can now represent an unsolvable equation
by just RETURNING ZERO SOLUTIONS. You know what happens if you iterate
over an empty container? It means you run the loop body ZERO TIMES.
Running something zero times means NOT RUNNING IT.
In other words, if one of the solve() calls returns zero solutions, the
remaining calls get AUTOMATICALLY SKIPPED.
We can actually extend this a bit. If we make it so the monad can hold a
failure description, we can have bind check the previous result, and run
the next step if and only if the previous one succeeded. In other words,
WE CAN IMPLEMENT EXCEPTION THROWING AS A LIBRARY.
We can also write a function which runs one block of code, checks
whether the result was a success or failure, and runs another block of
code if it was a failure. In other words, WE CAN IMPLEMENT EXCEPTION
CATCHING AS A LIBRARY.
Now C++ and Java already /have/ exception handling. But you know what?
If /you/ implement the exception handling, then /you/ can decide how it
should work.
For example, if solve() throws an exception, does that abort /all/ the
solutions being computed, or just the one that threw an exception? Well,
YOU DECIDE. You can implement it the first way, or you can implement it
the second way. Heck, you can have DIFFERENT SORTS OF EXCEPTIONS and
implement each one differently.
You can also do things like make the first four exceptions non-fatal,
but the fifth exception aborts the thread and returns all five
exceptions to the caller.
You can write a function that "decorates" exceptions as they go past,
and in this way you can ADD A CALL STACK to your exceptions.
You can make it so that there is one monad that allows you to throw
exceptions. Or you can make it so that all the types of exceptions that
can be thrown show up in the type signature. In other words, you can
implement UNCHECKED EXCEPTIONS, or you can implement CHECKED EXCEPTIONS.
You can choose which style you fancy.
It's not just exceptions either. You can write code that emits warnings,
and gather these up and log them at the end. (Why not just write the
warnings directly to a log file? Well, because then if you decide you
wanted to do something else with them, you'd have to change your solve()
code. It's better to abstract that out.) Going the opposite way, there
are parsing monads which feed a stream of INput INto a computation,
rather than collecting output from it.
Using a monad allows us to simulate destructive updates in Haskell
without actually *doing* destructive updates. People often sneer and say
"what's the point?" Well you know what? Because it doesn't /really/ do
destructive updates, it makes it trivial to implement features like...
reverting to an older version of the state, without explicitly storing
it and passing it around.
I can take my solve() code, tweak the monad a bit, and now I can insert
a "go back to an older state" command into one branch of my function,
without having to modify the whole damned thing to pass the old state
around. Try doing *that* in a language were destructive updates /really
are/ destructive updates. :-P
Writing some code that can solve an equation is one thing. Writing some
code where you can pause the program half way through and see what it's
doing is much, much more complicated.
But you know what? You can tweak the bind function to make a monad which
supports PAUSING AND RESUMING.
Literally. You can tweak the monad a little, and not alter the main
program at all, and now you can pause the main program at any point and
have a nose around inside to see what's happening. Or even alter its
internal data, and then resume it. And it's all in a library!
(Also: Holy ****, I just discovered coroutines! o_O Who knew it was this
useful?!)
Now, to be clear: Everything I have done in Haskell with my monads can
also be done in normal languages using other techniques. (They call it
"Turing completeness".) The difference, IMHO, is that monads make a lot
of this stuff DRASTICALLY EASIER TO DO than it would be in other languages.
If you have a large Java codebase and you suddenly decide that every
time you call a certain function you want to iterate over the multiple
results it returns... good luck with that. In Haskell, on the other
hand, it's pretty simple. I don't even need to alter my existing code,
because I've already factored out the sequencing.
There is one obvious potential problem: If monad X lets me throw
exceptions, and monad Y lets me produce multiple results, how the heck
do I combine those together? Well, the answer is that you can't. You can
write a NEW monad that has both of these features, but you can't combine
the two existing monads.
That sounds like a pretty epic failure of code reuse, right?
However, while you can't combine two *monads* together, what you *can*
do is write "monad transformers". A transformer takes an existing monad
and adds an extra feature to it. And this is where the identity monad
comes in: You can start with the identity monad, which does nothing. You
can implement everything else as transformers rather than monads. You
can then "stack" the monads one on top of the other to implement all the
features you want.
So, for example, you can take the identity monad, apply an exception
transformer to it, and them apply a list transformer to that. You can
now return multiple results, and throw exceptions.
Notice very carefully: If you throw an exception, it terminates ONE
THREADS OF COMPUTATION. That's because the list transformer is running
on top of the exception transformer. If you swap them around, then
throwing an exception terminates ALL THREADS OF COMPUTATION. So it
*matters* which order you stack the transformers in. Different orderings
produce different behaviour, and you need to check that you're stacking
them in the order that produces the feature set you actually want.
There are a couple of problems with transformers. First, they require
unusual Haskell features. (If you want the code to be flexible enough to
be worth making into a reusable library, you need some fairly advanced
type system features.)
Second, if you want to access a command at level 3 in the transformer
stack, you have to "lift" it from level 1 to level 2, and then from
level 2 to level 3. You end up having to remember what level each
command is at, and therefore how many times you need to "lift" it. All
of which is very tedious, and breaks horribly as soon as you change the
transformer stack.
The solution is to define classes which do the lifting automatically.
This requires yet /more/ advanced type trickery. (It also doesn't work
if you've got the same transformer at two different levels in the stack
- which is sometimes useful.) It also means a combinatorial explosion of
class instances as you define more transformers. (!)
And finally... monad transformers just make people's brains explode. So
it's not really surprising that actually, most people seem to just end
up implementing every monad they need from scratch again. It's easier
that way.
Of course, sometimes you don't need a whole monad. Sometimes just an
"applicative" is sufficient. Or sometimes you can use an "arrow". Or...
Wait! Come back!! >_<
Subject: Re: I'm in the mood for monads
Date: 20 Apr 2012 10:21:03
Message: <4f9170cf@news.povray.org>
  Would it be extremely wrong to say that a monad is like a barrier?
(http://en.wikipedia.org/wiki/Barrier_%28computer_science%29)
Date: 20 Apr 2012 11:03:21
Message: <4f917ab9$1@news.povray.org>
Not really. Monads aren't particularly related to threading.
More like... I can write this in C:
     foo();
     bar();
     baz();
Obviously, this calls three functions, one after the other.
In Haskell, I can write this:
   do
     foo
     bar
     baz
What /this/ does is that between each of the function calls you can see,
it invisibly inserts a new call to this magical "bind function" that I
keep talking about. So it's like writing
     foo();
     bind();
     bar();
     bind();
     baz();
In fact, it's not even like that, because each time bind() is called,
the entire rest of the code block is passed to it as an argument. And
that means that bind() can decide to /not run it/, or to /run it
multiple times/ or whatever else it feels like doing.
So, it's actually something like this:
   foo();
   bind(
     bar();
     bind(
       baz();
[Obviously, if that were actually valid syntax in some known programming
language.]
Actually, it's even more complicated than that, because each call to
bind() gets the result from the previous function call as an argument
too. So it's more like
   ResultInfo i1 = foo();
   bind(i1,
     ResultInfo i2 = bar();
     bind(i2,
       baz();
Each function, even if it doesn't "return anything", is actually
returning some kind of data structure representing the actions that the
function took. And bind() can look at that data and decide whether or
not it feels like running the rest of the code block.
So when I say that "a monad is a programmable semicolon", what I /mean/
is that everywhere there's a semicolon, the compiler is calling a
user-defined function, which can make the code do quirky, unexpected things.
When you say it like /that/, suddenly it's not so surprising that
monadic code can be configured to run lines multiple times, or pass
secret data around invisibly, or whatever.
Date: 21 Apr 2012 10:18:57
Message: <4f92c1d1@news.povray.org>
Am 20.04.2012 15:41, schrieb Invisible:
Somehow I get the impression that people who have never come across the
term "monad" would be much better suited to explain the conceptual
idea... All I understand is bollocks, but something tells me the concept
is probably so trivial that a handful of well-chosen words could explain
it all, if they just avoided the technical blurb and "Haskellisms".
Date: 21 Apr 2012 16:01:55
Message: <4f931233@news.povray.org>
> it all
When I write Haskell code "in a monad", the compiler is automatically
inserting a bunch of invisible function calls to the "bind function" of
the monad in question.
The bind function gets given two arguments: The result from the previous
statement, and a function representing /all/ of the following
statements. So it gets to decide if and how the rest of the code block
executes.
In short, between every pair of statements, a bunch of user-defined code
is invisibly being executed, allowing it to do totally hoopy things to
how your code runs.
And that's basically /it/.
(Now wasn't that such an anti-climax? Everybody makes such a Big Deal
out of monads, that sometimes when a person finally understands what
they are, it doesn't seem all that impressive, so they go away thinking
they missed something...)
Date: 21 Apr 2012 16:24:07
Message: <4f931767@news.povray.org>
  Most of the mathematical background in Haskell and purely functional
languages reminds me of the theory of electronics: The people in the
know seem to consider many of the topics trivial and self-evident, but
for some reason are usually unable to explain them in an understandable
manner.
  The difference is that in eletronics the concepts feel very complicated
when they try to explain them, while in Haskell they feel pretty trivial,
yet the real understanding of it always escapes the layman. For instance,
I still don't understand what currying *really* is about, and every time
I try to suggest "is like this?" the answer is "not really". It's like
some trivial-sounding but still ethereal concept that's impossible for
a mere mortal to grasp.
  And then they wonder why functional programming isn't mainstream.
Date: 21 Apr 2012 16:57:00
Message: <4f931f1c@news.povray.org>
Well it tells me nothing.
Regards
Date: 21 Apr 2012 17:17:34
Message: <4f9323ee@news.povray.org>
Heh, man... I thought "it inserts user-defined code between each pair of
statements" would a pretty simple idea. I guess not... ;-)
Date: 21 Apr 2012 17:18:53
Message: <4f93243d$1@news.povray.org>
Haskell is like Go: The rules are trivial. The game IS NOT.
As far as I know, the only way to really comprehend how to play Go is to
actually... you know... play Go. Only then do you start to understand
what the strategy and tactics are all about.
Haskell is similar. On the surface it looks pretty easy. The entire
language consists of a handful of simple yet very general concepts. The
way you APPLY those concepts to solve a problem? Well, that's an art. An
art you only really learn by doing. (ESPECIALLY since half this stuff
isn't written down anywhere, unfortunately.)
> For instance,
1. You can take a 5-argument function, pass it 2 argument, and get a
3-argument function as the result.
Examples:
- (+1) takes a number and adds one to it.
- (5 ==) takes a number and returns True if it's 5.
- "map" takes a function and a list. "map abs" takes a list of numbers
and returns a list of positive numbers.
2. Suppose foo is a 1-argument function. If you do "foo x y", then x is
the argument to foo itself, and y is the argument to whatever foo
returns (which must be a function).
Example: "head" takes a list and returns the first element. If you give
it a list OF FUNCTIONS, then obviously the result of calling "head" will
itself be another function. So it is legal to write
   head function_list 7
It looks like we're calling "head" with 2 arguments, yet "head" is a
1-argument function. But what is /really/ happening is that
function_list is the argument to "head", and the 7 is then passed as an
argument to whatever "head" RETURNS.
(Notice how the result of calling "head" would not normally be a
function. There are lots of other examples of where a result wouldn't
usually be a function, but under sufficiently unusual circumstances it is.)
3. If you write a class which works one way for functions, and another
way for non-functions, then you can polymorphically handle functions
with ANY NUMBER OF ARGUMENTS. If it weren't for currying, you'd have to
write a separate version of the class for every size of function. And
that would violate DRY.
For example, QuickCheck allows you to turn any function into a "test",
provided that
- The function returns true/false values.
- All of the function's arguments support automated test data generation.
In particular, it works for 0-argument functions (i.e., constants),
unary functions, binary functions, ternary functions, etc. Basically
there's a class instance that says "this is how you test a Bool", and
another that says "this is how you test a function that takes one
argument and returns something testable". A Bool is testable, but so is
a 1-argument function. And, by induction, an N-argument function.
Oh, I think that's due to a little bit more than just the ethereal
nature of advanced concepts. It's probably more "man, this stuff is too
different to what I'm used to; I can't be bothered with it". That and
(most especially in the case of Haskell) a supreme lack of quality
documentation.
Subject: Living in a box
Date: 21 Apr 2012 17:37:48
Message: <4f9328ac@news.povray.org>
Just for giggles, what would monads look like in C++?
Well, let's pretend for a minute that C++ has a Function<X, Y> type,
which represents a function that takes an X as input, and produces a Y
as output. (Yes, I realise that isn't the real syntax C++ uses. Just
pretend, for a minute.)
Further, let's pretend that you can create an anonymous function just by
writing
   int function(int x) {return 2*x;}
Again, this obviously doesn't actually work in C++, but it makes the
example code much easier to write.
(Actually, C++ is one of only a few languages where you probably /can/
implement monads "for real". But this made-up syntax makes it easier to
quickly explain what's happening.)
Listing #1:
   Type1 x = foo();
   Type2 y = bar(x);
   Type3 z = baz(y);
   return z;
This code needs little explanation. You can write the same thing in
Haskell as
Listing #2:
   let
     x = foo
     y = bar x
     z = baz y
   in z
Now consider this seemingly identical code:
Listing #3:
   do
     x <- foo
     y <- bar x
     z <- baz y
     return z
It seems like listing #2 and listing #3 should both be identical, right?
Well, no. If I translate listing #3 into C++, you'll see it's
drastically different:
Listing #4:
   Box<Type1> box_x = foo();
   return Bind(box_x,
     Box<Type3> function(Type1 x)
       Box<Type2> box_y = bar(x);
       return Bind(box_y,
         Box<Type3> function(Type2 y)
           Box<Type3> box_z = baz(y);
           return Bind(box_z,
             Box<Type3> function(Type3 z) {return Return(z);}
Clearly, this /looks/ totally different. If you can actually /follow/ it
all, you'll see that every statement is now followed by a call to this
Bind() function, taking the rest of the code block as an argument.
Important things to notice:
* The return type of foo() has changed from Type1 to Box<Type1>. This
means that the implementation of foo() has to be changed.
* The first argument to Bind() is a Box<Type1>, but the input to its
second argument is a Type1.
The Box<> class "forms a monad" if and only if it provides the following
functions:
   template <typename X>
   Box<X> Return(X);
   template <typename X, typename Y>
   Box<Y> Bind(Box<X>, function<X, Box<Y>>);
(In the interests of good OO design, these should probably be /class
methods/ rather than stand-alone functions. After all, their
implementation is completely different for each class that behaves as a
monad. But I will keep them as normal functions for now...)
Notice how what the Return() function does is NOTHING LIKE what a return
statement usually means. (!) Arguably this is a rather bad naming
choice. [You'll also notice how, in this example, Return() is completely
redundant. Taking it out wouldn't change a thing. I only put it there
for completeness.]
It's not hard to figure out how to implement this:
   class Box
     private:
       X Datum;
     public:
       Box(X in) {Datum = in;}
       X GetDatum() {return Datum;}
   Box<X> Return(X in) {return Box<X>(in);}
   Box<Y> Bind(Box<X> in, Function<X, Box<Y>> next)
   {return next(in.GetDatum());}
(I'm guessing my syntax is wonky - even admitting that we're using
pretend language extensions. It probably also contains at least a dozen
incorrect or at least dubious characteristics. But the gist of it should
be clear.)
This is a monad, but it doesn't "do" anything particularly special. With
Box implemented this way, Listing #4 now does exactly the same thing as
Listing #1, but 8x more complicated. Why bother?
This implementation makes Box the "identity monad". Like the identity
function, the identity monad does... nothing. (And, like the identity
function, this sounds like a very useless thing, but actually isn't.)
So let's try another implementation:
   class Box
     private:
       std::vector<X> Data;
     public:
       Box(std::vector<X> in) {Data = in;}
       std::vector<X> GetData() {return Data;}
   Box<X> Return(X in)
     std::vector<X> out;
     out.push_back(in);
     return out;
   Box<Y> Bind(Box<X> box_in, Function<X, Box<Y>> next)
     std::vector<X> in = box_in.GetData();
     std::vector<Y> out, temp;
     std::vector<X>::iterator iti;
     std::vector<Y>::iterator ito;
     for (iti = in.begin(); iti < in.end(); iti++)
       Box<Y> box_out = next(*it);
       temp = box_out.GetData();
       for (ito = temp.begin(); ito < temp.end(); ito++)
       out.push_back(ito*);
     return Box<Y>(out);
Now Box<X> contains a std::vector<X> instead of just one X value. The
Return() function now generates a 1-element vector. And the Bind()
function now executes next() MULTIPLE TIMES, once for each element in
the input. It then collects all the outputs from each call, and gathers
them into a single giant vector.
(Incidentally, I couldn't figure out a direct way to just append the
entire contents of one vector to another. Obviously there /is/ a way,
and I'm just not looking hard enough...)
Notice how the code for foo(), bar() and baz() HAS NOT CHANGED, and the
code that calls them HAS NOT CHANGED. And yet, now each function can
potentially generate multiple results!
(Of course, for foo() to produce more than one output given a single
input, then either foo() itself or some function it calls would have to
be modified to actually make USE of this feature. But, for example, some
function that foo() calls might change, while foo() itself remains
unaffected, and foo() could still use this new feature of having
multiple results.)
This is what Haskellers call the "list monad", basically. (With the
added twist that Haskell lists are lazy, so it's possible for functions
to produce "infinity results".)
It shouldn't be too hard to see that you could alter [the first] Box
implementation such that it contains a success marker, and that Bind()
only runs the next step in the chain if the previous one succeeded. You
could also modify it to contain an error description in the case of
failure. Then, if bar() decides to return an error-in-a-Box rather than
a value-in-a-Box, baz() gets completely skipped. But baz() ITSELF
doesn't need to do any explicit error checking. Bind() does that for you.
In this way, baz() returning an error-in-a-Box aborts the entire Box
computation. A bit like... THROWING AN EXCEPTION. Except it's a library,
not a language feature, so you can change the design of it at will.
(E.g., make it so you have to throw three exceptions before the code
aborts.) This is what Haskellers call the "failure monad", "error monad"
or "exception monad".
You can also design Box to store various other auxiliary information as
it goes along. You could have a table of data, for example, and provide
commands to replace that table with a new one. This is how Haskell
simulates destructive updates without ACTUALLY doing destructive updates.
(This is the difference between the State monad and the ST monad. The
former allows you to simulate destructive updates, in the way described.
The latter ACTUALLY DOES destructive updates, in the manner of C++ or
Java or whatever.)
It's not hard to see how a Box could contain a string buffer and a
character index, and you could write functions that take a Box and
return a new Box after reading data from the string buffer. This is how
you write parser monads.
I could continue at length, but by now you probably get the picture.
User-defined code invisible inserted between the visible statements you
actually wrote leads to all sorts of interesting possibilities.
Incidentally, since C++ REALLY DOES have a function type (or at least,
function POINTER type) which can be passed as an argument, it's one of
the few languages where it ought to be possible to implement a monad
"for real". I might try it if I get the time.
The problem, of course, is that it's going to be so hellishly verbose
that no sane person would ever, EVER write their C++ code like this...
Saying that, I hear C++ lets you override operator(). So perhaps the
simplest way to describe a monad is as "override operator;". ;-)
