POV-Ray : Newsgroups : povray.off-topic : Epic failure Server Time
14 Dec 2025 09:04:36 EST (-0500)
  Epic failure (Message 1 to 10 of 55)
Subject: Epic failure
Date: 15 Mar 2012 20:00:02
Message: <4f628282@news.povray.org>
Since we already have "Random failure" post I thought I add an "Epic
failure" one ... turns out it may be an "Epic Success" (for some)
depending on how you look at it of course. One thing's for sure is that
there's at the very least 26,000 very stupid people in this world.
http://www.bbc.co.uk/news/technology-17381214
Holy Crap ... makes my head hurt!
Subject: Re: Epic failure
Date: 16 Mar 2012 08:54:42
Message: <4f633812@news.povray.org>
Yup, a bunch of 14 year olds in their mom's basements who want to be
hackers without knowing the first thing about it.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 16 Mar 2012 09:35:48
Message: <4f6341b4$1@news.povray.org>
Required CAD quote: http://www.cad-comic.com/cad/20030606
(You have no idea how long I've waited to use that...)
Date: 16 Mar 2012 09:49:40
Message: <4f6344f4@news.povray.org>
  OTOH, how do you define "hacking"?
  Is, for example, reverse-engineering a proprietary file format and writing
a reader library for it "hacking"?
  Is disassembling an executable and making a modification to it "hacking"?
  Is running a port scanner and finding a security vulnerability in a
remote system (but without actually knowing how the scanner is doing it)
"hacking"?
  Is deciphering the data transfer format of a poorly programmed browser
game in order to send bogus high scores "hacking"?
  Is configuring a unix system to support an obscure device "hacking"?
  Is fixing someone's PC by running scandisk "hacking"?
Date: 16 Mar 2012 10:38:03
Message: <4f63504b$1@news.povray.org>
I think the necessary criterion is that it's any activity requiring
technical knowledge and skill.
Once time I fed a program into my GPU which made it render volumetric
fog, with realtime computed gas motion. That's very technical and
impressive. However, since I didn't actually /write/ that code, nor have
any comprehension for how it even works, that doesn't count as hacking.
All I did was download a file and run it. That requires little to no
technical skill on my part.
I suppose it's a bit like saying what counts as "writing a book"? Does
the book actually have to be /published/? Does it still count if the
book doesn't get published? How big does the document have to be to
count as a "book"? Because, hey, I've written lengthy discussions on
stuff. But does that count as "writing a book"?
And then of course, in everyday culture "hacking" refers only to
technical activities which are in some way /illegal/. :-P
Date: 16 Mar 2012 10:45:08
Message: <4f6351f4@news.povray.org>
  It may be necessary, but not sufficient. I can write a program that
calculates the mandelbrot set, but that's not usually considered hacking.
Date: 16 Mar 2012 10:57:34
Message: <4f6354de$1@news.povray.org>
I will go with that definition ;-)
Regards
Date: 16 Mar 2012 11:29:40
Message: <4f635c64$1@news.povray.org>
Well, I would consider that hacking. But I guess the fundamental point
is that the word lacks a coherent definition...
Date: 16 Mar 2012 11:42:48
Message: <4f635f78@news.povray.org>
  One rather usual characteristic is figuring out how something works
(usually something related to computers, and usually more specifically
something related to software) and using it or modifying it in an unusual
and unintended way.
  "Hacking into" a system usually means figuring out how to get past
security measurements by studying how it works and what its weaknesses
are. However, that's only one of the many things that are considered
hacking.
  Writing a program that does something mundane isn't usually considered
"hacking".
Date: 16 Mar 2012 12:01:32
Message: <4f6363dc$1@news.povray.org>
> "hacking".
I don't know. People seem to use the phrase "I was hacking on XYZ" to
mean the same thing is "I was working on the source code for XYZ",
without any particular requirement that the code or the coding activity
is anything remarkable.
