Thursday I interviewed with a company in the Houston, Texas area.
One of the interviewers had me examine two pieces of buggy code and try
to identify the bugs. I don't remember all of the details. Here is the
first one:
function() {
// some stuff
if (whatever) {
// code here to get a mutex lock
// other stuff
// code here to release the mutex lock
// the rest of the function code
The way I simplified it makes it easier to spot the bug.
The second one was issued with the warning that very few people can id
the bug:
char* some_function() {
char yada[100];
char* p=yada;
// some stuff that fills the array with data
// and more stuff
// and more stuff
return p;
When I saw the return statement, and looked back to what the pointer was
set to, I said, "I wouldn't do that."
"Do what?" the interviewer asked.
"Return a pointer to a local variable."
This provoked a laugh from the interviewer.
Seriously? Not many people catch that?
Evidently not. In chatting with the interviewers that day, they all
confirmed that most bugs are stupid things like this.
Anyway, the job prospect is still a going affair, so I suppose I did
okay in the interview.
John
Break a leg, John. :-D
Regards
Nicely done! I have to imagine that finding the interview questions to
be too easy is certainly a good sign for your employment prospects.
Come to think of it, as simple as that second question is it seems to be
a pretty good way to test what level of "mental model" a person uses
when coding, and since lots of people apparently botch it, it seems to
be a pretty necessary test too.
Sadly, the vast majority of people programming in C (or C++) professionally
out there don't actually know the language enough to avoid such trivial ways
to shoot yourself in the foot. It may be something that you and me can spot
in a second, but I'm certain the average professional C programmer can't see
it. It's no wonder programs are so buggy. A sad state of affairs.
In C++ in particular this is another situation were the majority of C++
programmers out there have no idea what's wrong:
template<typename Value_t>
class Array
Value_t* mData;
std::size_t mSize;
public:
Array(std::size_t size):
mData(new Value_t[size]),
mSize(size)
~Array() { delete[] mData; }
Value_t& operator[](std::size_t index)
assert(index < mSize);
return mData[index];
const Value_t& operator[](std::size_t index) const
It's quite a pity too, seeing as how C++ provides so many intricate and
sophisticated ways to shoot yourself in the foot.
Yep ... I'd say you did pretty darn good. Fingers crossed ... Keep us
posted.
Le 04/03/2012 23:33, Warp nous fit lire :
* you used a template ? (nop, just a red herring for you! but a single
uppercase letter is usually preferred to Value_t)
* you have the [] checks the upper range (whereas usually it's at()
which check, and [] do not)
* you checked upper range, but not lower one
* you should have stated index in [] with const
* using assert is not the right way to handle the issue.
* you did not test in creator the value of size ( 0 ?)
* copy-constructor... you're in trouble with mData
* you did not disable automatic conversion of "number" into Array<>, so
if you have some different signature for some methods using either
number or Array<>, you're in for surprise (explicit)
With actual compiler:
* you forget the include needed for size_t (cstring)
* you forget the declaration of assert() (assert.h)
of C++
Are you just referring to the lack of copy constructor and assignment
operator, or is there something more subtle here?
- Slime
Given the previous discussion, I'm betting this is the error Warp was
talking about - returning the address of a variable that gets disposed when
this object gets disposed. It's basically the same bug - scopes exceeding
lifetimes. I'm amused that Ada actually prevents this bug unless you
explicitly say "Yes, yes, I'm intentionally assigning a value to a pointer
whose lifetime is shorter than that of the pointer."
People tell me I am the counter-example.
> when this object gets disposed. It's basically the same bug - scopes
> exceeding lifetimes. I'm amused that Ada actually prevents this bug
> unless you explicitly say "Yes, yes, I'm intentionally assigning a value
> to a pointer whose lifetime is shorter than that of the pointer."
I doubt it a bit. It would be at worst an issue with the
copy-constructor of Value_t (if any), but I would think (maybe wrongly)
that due to the prototype of the function (returning a reference to
Value_t), the mData[index] is actually the real reference (compiler
handling the issue of &/* for us here).
One real bug is when used with the following code:
int foobar()
Array<int> foo(3);
foo[0] = 3;
foo[1] = 7;
foo[2] = 0;
Array<int> bar(foo); // get a copy of foo
bar[2] = bar[1] + bar[0]; // no problem, it's 3+7
foo[2] += foo[1] * foo[0]; // you might crash here already
return foo[2]; // these result is going to be surprising sometime
} // you definitely have a problem with glibc here!
Same kind of issue might happen if you provide Array<> to methods by
values without const (hence needed some copy-constructor... and the call
to the destructor for the intermediate objects)
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
