POV-Ray : Newsgroups : povray.off-topic : Trouble with large directory in Linux Server Time
13 May 2026 22:11:46 EDT (-0400)
  Trouble with large directory in Linux (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Trouble with large directory in Linux
Date: 28 Feb 2012 15:01:25
Message: <4f4d3295$1@news.povray.org>
It's probably shell expansion of the wildcard, as others have indicated.
Break it down into smaller deletions.  For example:
rm a*
rm b*
rm c*
etc.
Or use one of the other suggested ideas.
Jim
Date: 28 Feb 2012 15:04:29
Message: <4f4d334d$1@news.povray.org>
On 2/28/2012 11:47 AM, Warp wrote:
>    A webpage suggests this:
> find<dir>  -exec rm {} \;
>    (I think that the idea is that this executes the 'rm' command individually
> on each file as it traverses the directory, rather than first gathering all
> the file names into RAM and then trying to do something to them.)
I saw that too, and tried some pretty similar things.  For whatever
reason I wasn't able to get find to do anything successful, and all
attempts met the same fate as other approaches.  Fortunately I
remembered that I had access to a machine with enough ram to actually
run find, and something like your suggestion did work.  I appreciate you
taking the time to look for an answer though.
Date: 28 Feb 2012 15:06:38
Message: <4f4d33ce$1@news.povray.org>
> Thanks for your help! I will remember everything you suggested in case
> something like this comes up again.
Also, I still don't know how I could have deleted things without SSHing
to the bigger machine, so if you have some ideas there I'd still be very
interested in hearing them.
Date: 28 Feb 2012 21:53:22
Message: <4f4d9322@news.povray.org>
For the future, just try "find <dir>" and see what you get. That should
print all the file names to the screen without having to actually load them
into memory. (The shell and ls both try to sort the list of files before
printing/using them, so that's part of your problem.)
Also, be aware that once the directory is empty, it may take several minutes
to rmdir it, because (depending on the underlying file system) it has to
read the entire directory before it will ack that the directory is
sufficiently empty to delete.
   People tell me I am the counter-example.
Date: 28 Feb 2012 22:30:38
Message: <4f4d9bde@news.povray.org>
> them into memory. (The shell and ls both try to sort the list of files
> before printing/using them, so that's part of your problem.)
I did try exactly this actually, it printed "." and nothing else before
it used up 8GB of ram, 15.5GB of swap, and ground to a halt.  It worked
on the 64GB ram computer though, which is basically how I managed to
delete the files.  If I did "find ." in the superdirectory by the way,
it successfully printed files as normal until it got the the problematic
subdirectory, at which point it ground to a halt just as before.
Date: 2 Mar 2012 00:42:10
Message: <4f505db2$1@news.povray.org>
Hmmm. There's a flag you can pass to find to turn off the optimization of
counting the number of links on "." and not recursing afterwards, or
something. I wonder if that would have helped. I wasn't aware find tried
loading things into memory, but maybe you wound up with a hard link to
itself in the directory (other than ".") or some such. I suspect file system
corruption.
Date: 2 Mar 2012 13:42:34
Message: <4f51149a$1@news.povray.org>
Le 02/03/2012 06:42, Darren New nous fit lire :
> of counting the number of links on "." and not recursing afterwards, or
> system corruption.
I'm more thinking about it: by default, it (ls) will try to sort the
filenames in alphabetical order... find the switch to disable that!
Date: 2 Mar 2012 22:10:40
Message: <4f518bb0$1@news.povray.org>
This is an excellent point, although I did at least check that find
wasn't trying to sort things when I ran it (it wasn't).  Totally forgot
that ls would do that though.
Date: 2 Mar 2012 22:12:57
Message: <4f518c39$1@news.povray.org>
> I suspect file system corruption.
This has been a worry of mine too, although everything else seems to be
fine, and deleting the files did eventually work.  I also am starting to
wonder if there's something with the particular Linux distro I was
using, since the more I think about it the more I feel that it ran a
little *too* well on the big machine, I'll poke around a bit more when I
get back from vacation and see if i can figure out anything else.
Date: 2 Mar 2012 23:50:24
Message: <4f51a310$1@news.povray.org>
That's why I sugested just "find . -print". "find" doesn't try to sort the
output. (glob sorts the output also.)
