POV-Ray : Newsgroups : povray.off-topic : Today's quest Server Time
11 Oct 2024 15:20:47 EDT (-0400)
  Today's quest (Message 1 to 10 of 22)
Subject: Today's quest
Date: 27 Feb 2012 08:35:23
Message: <4f4b869b$1@news.povray.org>
OK, so I've been given a USB floppy drive with a disk in it containing
some BIOS utilities. Which works - after you enable booting from it in
the BIOS. But it's not exactly "fast".
My plan? To convert this into a bootable CD or maybe a USB drive. But how?
After much Googling, I discovered that there's an option to mkisofs
which makes it to El Torito floppy emulation. So I can basically take a
raw disk image of the floppy (which is only half full anyway) and make
an ISO-9660 CD image out of it.
So I booted up a VM running Debian Squeeze, and... mkisofs isn't a
recognised command? Seriously? OK, well maybe I just need to install it.
Er, no, the package manager claims to have no knowledge of any such
program. Wuh?! There /must/ be a way to install this, surely? Don't tell
me the mighty Debian doesn't support something as common as CD burning...
Well, Squeeze has /nothing/. But checking Lenny, I find a package that
at least /contains/ the binary. Except it isn't a binary, it's just a
symlink. The package documentation says "This is for compatibility only.
Please use genisofs instead."
OK, so for some reason they've renamed a standard Unix tool to another
name. But with identical functionality. Um, whatever. (Isn't this from
the guys who bought us Iceweasel, which is identical to Firefox?)
So, I ask genisofs to build me a CD image. First it complains that I
haven't added any files. Which is fair enough, I suppose. So I create an
empty folder, and tell it to use that. But now it complains that it
can't find the floppy image - even though it's /right there/!
Eventually I hunt through the manpage, and in the small print I discover
that the floppy image has to be /in/ the folder that you're making a CD
out of. (Presumably it shows up as a regular file on the disk, in
addition to being the boot code. Or something.) Once I moved the floppy
image, everything worked fine. And you know what? The CD boots and works
perfectly.
So now the guys from the USA can have their USB floppy drive back. I've
got a CD. ;-)
I wonder... would copying the CD image to a USB drive actually work? I
rather suspect not. I've never actually seen any PC boot from a flash
drive, ever - although I keep hearing that it's supposed to work...
Subject: Re: Today's quest
Date: 27 Feb 2012 11:53:30
Message: <4f4bb50a$1@news.povray.org>
Yep.  Use isohybrid to get it working.
I do this quite regularly with openSUSE ISO images in order to boot from
a USB flash drive instead.  Installs are *much* quicker.
Jim
Date: 27 Feb 2012 15:15:13
Message: <4f4be451$1@news.povray.org>
The seek time on a CD drive /is/ rather poor. I find that when I install
stuff onto a VM, using an ISO image on a networked file server, it runs
/way/ faster than if I really did put the physical CD into the local
machine's drive and run it without any VM overhead.
So, uh, anyway... Can I literally just do a block-level copy from the
ISO image to the flash drive? Or do I have to /do/ stuff to it first to
make it work?
Also, is there a quick way to test whether a particular PC even
/supports/ booting from flash? Like I say, I've never seen it actually
work IRL. Is there some easily available image I can test with?
Date: 27 Feb 2012 17:01:05
Message: <4f4bfd21$1@news.povray.org>
> make it work?
You have to use isohybrid to make it work.  Try a google search as that
should tell you what it does and how to use it.
Jim
Date: 28 Feb 2012 04:50:59
Message: <4f4ca383$1@news.povray.org>
Had to do precisely that to install a new copy of the Linux for the EePC
I installed a new, bigger, SSD drive into it. So, yeah, you can, but not
all of them can be formatted to be booted, and the BIOS needs to support
the ability to boot from USB devices.
Date: 28 Feb 2012 05:02:05
Message: <4f4ca61d@news.povray.org>
>> make it work?
> Jim
Or, just a search on, "make usb flash drive bootable". Pages and pages
of ways to do it, most of them Linux based, but some others.
Looking over one of those pages, you are actually doing:
1. Format
2. Partition
3. Copy over the needed files (or install to it, I supposed).
4. Make it bootable (presumably the same way you do an HDD, but marking
the partition as "live".
This makes it looks like a normal HDD to the system, as long as the
system recognizes USB as a boot option.
Date: 28 Feb 2012 08:01:03
Message: <4f4cd00f@news.povray.org>
Someone probably has a ready-made script to boot Linux from a flash
drive, probably using Grub. But I'm trying to boot MS-DOS. I imagine
that's going to be harder. (USB didn't /exist/ when MS-DOS was written,
after all...)
Date: 28 Feb 2012 12:14:18
Message: <4f4d0b6a$1@news.povray.org>
> after all...)
Did you read the *isohybrid* info like I've suggested *twice* now?
Jim
Date: 28 Feb 2012 16:40:38
Message: <4f4d49d6$1@news.povray.org>
> after all...)
http://www.bootdisk.com/pendrive.htm
Gives a number of examples, some of which are "basically" what I said
before. But, no, its exactly the same process. As long as the stick has
been formatted, and set up, to be bootable, it doesn't care, any more
than the system does, that its a flash drive, instead of an HDD.
Date: 28 Feb 2012 22:02:20
Message: <4f4d953c$1@news.povray.org>
On 2/27/2012 12:15, Orchid Win7 v1 wrote:
> So, uh, anyway... Can I literally just do a block-level copy from the ISO
Do *not* do a block-level copy to a USB stick if you ever want that stick to
ever work again.
   People tell me I am the counter-example.
