POV-Ray : Newsgroups : povray.off-topic : Today's quest Server Time
13 May 2026 22:57:51 EDT (-0400)
  Today's quest (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Today's quest
Date: 27 Feb 2012 15:15:13
Message: <4f4be451$1@news.povray.org>
On 27/02/2012 16:53, Jim Henderson wrote:
> On Mon, 27 Feb 2012 13:35:22 +0000, Invisible wrote:
>> I wonder... would copying the CD image to a USB drive actually work?
> Yep.  Use isohybrid to get it working.
> I do this quite regularly with openSUSE ISO images in order to boot from
> a USB flash drive instead.  Installs are *much* quicker.
The seek time on a CD drive /is/ rather poor. I find that when I install
stuff onto a VM, using an ISO image on a networked file server, it runs
/way/ faster than if I really did put the physical CD into the local
machine's drive and run it without any VM overhead.
So, uh, anyway... Can I literally just do a block-level copy from the
ISO image to the flash drive? Or do I have to /do/ stuff to it first to
make it work?
Also, is there a quick way to test whether a particular PC even
/supports/ booting from flash? Like I say, I've never seen it actually
work IRL. Is there some easily available image I can test with?
Date: 27 Feb 2012 17:01:05
Message: <4f4bfd21$1@news.povray.org>
> make it work?
You have to use isohybrid to make it work.  Try a google search as that
should tell you what it does and how to use it.
Jim
Date: 28 Feb 2012 04:50:59
Message: <4f4ca383$1@news.povray.org>
On 2/27/2012 6:35 AM, Invisible wrote:
> I wonder... would copying the CD image to a USB drive actually work? I
> rather suspect not. I've never actually seen any PC boot from a flash
> drive, ever - although I keep hearing that it's supposed to work...
Had to do precisely that to install a new copy of the Linux for the EePC
I installed a new, bigger, SSD drive into it. So, yeah, you can, but not
all of them can be formatted to be booted, and the BIOS needs to support
the ability to boot from USB devices.
Date: 28 Feb 2012 05:02:05
Message: <4f4ca61d@news.povray.org>
>> make it work?
> Jim
Or, just a search on, "make usb flash drive bootable". Pages and pages
of ways to do it, most of them Linux based, but some others.
Looking over one of those pages, you are actually doing:
1. Format
2. Partition
3. Copy over the needed files (or install to it, I supposed).
4. Make it bootable (presumably the same way you do an HDD, but marking
the partition as "live".
This makes it looks like a normal HDD to the system, as long as the
system recognizes USB as a boot option.
Date: 28 Feb 2012 08:01:03
Message: <4f4cd00f@news.povray.org>
Someone probably has a ready-made script to boot Linux from a flash
drive, probably using Grub. But I'm trying to boot MS-DOS. I imagine
that's going to be harder. (USB didn't /exist/ when MS-DOS was written,
after all...)
Date: 28 Feb 2012 12:14:18
Message: <4f4d0b6a$1@news.povray.org>
> after all...)
Did you read the *isohybrid* info like I've suggested *twice* now?
Jim
Date: 28 Feb 2012 16:40:38
Message: <4f4d49d6$1@news.povray.org>
> after all...)
http://www.bootdisk.com/pendrive.htm
Gives a number of examples, some of which are "basically" what I said
before. But, no, its exactly the same process. As long as the stick has
been formatted, and set up, to be bootable, it doesn't care, any more
than the system does, that its a flash drive, instead of an HDD.
Date: 28 Feb 2012 22:02:20
Message: <4f4d953c$1@news.povray.org>
On 2/27/2012 12:15, Orchid Win7 v1 wrote:
> So, uh, anyway... Can I literally just do a block-level copy from the ISO
Do *not* do a block-level copy to a USB stick if you ever want that stick to
ever work again.
   People tell me I am the counter-example.
Date: 29 Feb 2012 01:48:22
Message: <4f4dca36@news.povray.org>
>> ISO
> stick to ever work again.
Unless I'm misunderstanding what you mean by this, no, this isn't correct
- you can do:
dd if=/path/to/iso/dvd.iso of=/dev/sdg
And create a bootable USB flash drive if the iso is prepped with
isohybrid.
And when done, you can reformat the device very easily:
dd if=/dev/zero of=/dev/sdg
fdisk /dev/sdg
Piece of cake.
Jim
Date: 29 Feb 2012 03:57:15
Message: <4f4de86b@news.povray.org>
Yeah, I did.
As best as I can tell, there's a thing called isolinux which lets you
boot Linux from a CD-ROM. And then isohybrid allows you to modify such
an image so it can be booted from any block device [that the BIOS
supports]. I'm not immediately seeing how this relates to booting
another OS.
I did, however, see several references which seem to suggest that just
grabbing a random Linux live CD and dumping it onto a flash drive will
probably work, so I might just try that to see if my BIOS even
/supports/ such a thing...
