POV-Ray : Newsgroups : povray.off-topic : Today's quest Server Time
13 May 2026 22:12:26 EDT (-0400)
  Today's quest (Message 13 to 22 of 22)
Subject: Re: Today's quest
Date: 29 Feb 2012 03:58:32
Message: <4f4de8b8@news.povray.org>
On 29/02/2012 03:02 AM, Darren New wrote:
> On 2/27/2012 12:15, Orchid Win7 v1 wrote:
>> So, uh, anyway... Can I literally just do a block-level copy from the ISO
> Do *not* do a block-level copy to a USB stick if you ever want that
> stick to ever work again.
Any specific reason?
I mean, I gather it's fairly easy to utterly screw up the filesystem in
this way - but you can always just format the drive again. It's not hard.
Subject: The next quest
Date: 29 Feb 2012 05:52:45
Message: <4f4e037d$1@news.povray.org>
On 27/02/2012 01:35 PM, Invisible wrote:
> I wonder... would copying the CD image to a USB drive actually work? I
> rather suspect not. I've never actually seen any PC boot from a flash
> drive, ever - although I keep hearing that it's supposed to work...
OK, well... It turns out that writing my CD image to a flash drive
doesn't work at all. But if I write a Linux live CD image to it instead,
then it boots just fine. (At least, with the one PC that I tested with.)
Weird thing #1: For this to work, you have to write the image over the
top of the entire drive, not just one partition of it. Which is strange,
because I'm pretty sure that an ISO-9660 file system doesn't contain a
valid IBM BIOS partition table at the start.
Weird thing #2: Once you've done this, it boots just fine, but Windows
becomes awfully confused. It seems to see that only part of the drive is
partitioned, but it utterly refuses to allow you to repartition it. So
it is now impossible to use the whole capacity of the drive...
...from Windows. A quick trip to Linux land and it's a trivial operation
to edit the partition table and get your drive back. :-P
I did try booting Linux from the flash drive. It did seem a bit quicker,
but not that much. (Then again, I was testing with OpenSUSE, arguably
the slowest distro ever made.) I might actually make a habit of booting
Linux install disks in this way in future. As for my original CD... well
it's a damned site quicker than a floppy disk! :-P That's good enough
for me.
Subject: Re: The next quest
Date: 29 Feb 2012 06:24:50
Message: <4f4e0b02$1@news.povray.org>
OK, so I did some digging. It turns out that for a Linux CD image to be
usable for booting from a flash drive, 1) it must use isolinux as the
boot loader, and 2) once the CD image has been created, you must run
isohybrid over it, which edits the file a bit.
But what exactly does isohybrid /do/ to the file that makes it work on a
USB flash drive?
Well, it turns out that isohybrid is just a Perl script. [That sound you
just heard was me being sick in the corner.] Since Perl only supports
textual manipulation, all of the "real" work must be being done by some
external tool. So if I can just find out what it is...
...oh dear God. You know what? It turns out you /can/ perform binary
manipulations in Perl. The world is not safe any more. >_<
So what does this script actually do? Well, since it's written in Perl,
I can only take guesses based on the comments in the source code. But it
/appears/ that it searches the ISO image to figure out where isolinux is
stored, and then it creates a valid IBM BIOS partition table at the
front of the CD image, and generates a boot block that runs isolinux.
Quite how it's possible to insert a partition table into a ISO-9660 file
system without breaking it, I'm not sure. But that appears to be what
the trick amounts to. I can imagine it being possible to modify a CD
image to make a bootable flash image. But I'm quite surprised that a
single image can simultaneously be both at once.
It /looks/ like it might even be possible to set up the partition table
so that the rest of the flash drive can be mounted read/write. (But that
presumably would stop the image working on a CD any more.)
In summary, being able to boot a CD image from a flash drive isn't
automatic; the image has to be specially set up with this in mind. (So
it might not work with /every/ Linux distro, for example.) In
particular, if I wanted /my/ CD image to boot this way, I'd have to
figure out how to make it boot with isolinux, and then configure it with
this cursed Perl script.
(Random fact: There's also a C translation of the same program. No, I
couldn't really read that either...)
Date: 29 Feb 2012 09:00:45
Message: <4f4e2f8d$1@news.povray.org>
Le 2012-02-28 08:01, Invisible a écrit :
> On 28/02/2012 10:02 AM, Patrick Elliott wrote:
>> Or, just a search on, "make usb flash drive bootable". Pages and pages
>> of ways to do it, most of them Linux based, but some others.
> Someone probably has a ready-made script to boot Linux from a flash
> drive, probably using Grub. But I'm trying to boot MS-DOS. I imagine
> that's going to be harder. (USB didn't /exist/ when MS-DOS was written,
> after all...)
This should be extremely simple.  MS-DOS talks to the BIOS, not the
hardware directly.  If your BIOS can boot from USB, it'll provide the
necessary functionality to run MS-DOS from a USB device.
The problem is that MS-DOS only understands FAT8 and FAT16, so you'll
have to format your USB drive using those - which means using a thumb
drive of 2GB or less.
- Format your USB drive to make sure it is completely empty.
- Copy IO.SYS from a bootable MS-DOS diskette to the USB drive.  FIRST.
  As it has to be on sector 1.
- Copy MSDOS.SYS from the diskette to the USB drive.
- Copy COMMAND.COM from the diskette to the USB drive.
- ATTRIB +H +S *.SYS
- Voilà!
- You may now copy the rest of the DOS utilities to your USB drive.
Alternate way of doing it.
- Muck with your BIOS to make the USB drive look like C:
- Boot form the diskette
- FORMAT C: /S
- Tada!
Note:
IO.SYS, MSDOS.SYS, COMMAND.COM, FORMAT.EXE and ATTRIB.EXE should to be
of the same vintage for best results.
DISCLAIMER: I haven't tried it, but it should work.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 29 Feb 2012 13:34:01
Message: <4f4e6f99$1@news.povray.org>
On Wed, 29 Feb 2012 08:57:41 +0000, Invisible wrote:
> On 28/02/2012 05:14 PM, Jim Henderson wrote:
>> Did you read the *isohybrid* info like I've suggested *twice* now?
> Yeah, I did.
So then you must've seen:
http://www.syslinux.org/wiki/index.php/
ISOLINUX#Can_I_boot_other_operating_systems_with_ISOLINUX.3F
Which explains exactly how to do what you're trying to do?
Jim
Date: 29 Feb 2012 21:50:54
Message: <4f4ee40e@news.povray.org>
>>> ISO
One issue may be that some are specially designed, including security
locking, and other secondary partitions, and they may simply stop
working at all, if things go missing that needs to be there. But, yeah,
would be kind of interesting to know why.
Date: 29 Feb 2012 22:10:40
Message: <4f4ee8b0$1@news.povray.org>
Sure, but that's not what Darren's implication is - his implication is
that you should never, ever, under any circumstances do a block-level
copy to a USB device.
That's just flat incorrect, unless he means something different than I do
when he says "block level copy".
Jim
Date: 1 Mar 2012 15:13:04
Message: <4f4fd850$1@news.povray.org>
>> Yeah, I did.
I think "explains" would be exaggerating a bit... More like "vaguely
hints at what the necessary commands might perhaps be".
Date: 1 Mar 2012 15:40:49
Message: <4f4fded1$1@news.povray.org>
Well, the documentation does explain how the thing works - it doesn't
make sense (and no documentation ever does) to duplicate information for
every specific task being described.
Jim
Date: 2 Mar 2012 00:57:36
Message: <4f506150$1@news.povray.org>
I've occasionally done this, and it screws up the chip to the point where
it's no longer recognized as anything when you plug it in. Perhaps I was
using something that actually overwrote the control information, tho, and
perhaps the Linux block devices start the writing after that point. I'm not
sure why.
   People tell me I am the counter-example.
