POV-Ray : Newsgroups : povray.off-topic : Lost Server Time
11 Oct 2024 17:45:08 EDT (-0400)
  Lost (Message 1 to 3 of 3)
Subject: Lost
Date: 15 Nov 2011 11:56:39
Message: <4ec299c7$1@news.povray.org>
Native Instruments. I have a bunch of their stuff. But I fear they have
lost their way...
Way back when, NI used to produce various award-winning synthesizer
software. Most famously, Absynth is a semi-modular synthesizer with
ludicrous amounts of modulation options. It excels at creating bizarre
evolving soundscapes. (And somewhat sucks at producing sounds that you
can actually play a tune with.) They also produced FM7, a frequency
modulation synthesizer with some unusual features. It has the obligatory
DX7 file support and lots of other bells and whistles. More recently,
FM8 is the latest version of this product.
The also made an award-winning drum machine called Battery. And they
made strange effects processors like Spektral Delay. And then they came
out with a thing called Reaktor.
Think about what MS Access does for databases; as well as creating
tables and queries, it lets you built primitive user interfaces and run
automation and so forth, to create psuedo "applications". Reaktor lets
you take DSP modules and interactively wire them together to make
sounds, and then interactively stick a GUI on top of that to control the
parameters. In this way, you can "build synthesizers".
Reaktor comes with a small library of such instruments, and you can
build your own and share them in an online forum. (Obviously, nothing on
this forum even remotely compares to the quality of the standard
library.) You have things like Carbon 2 and Green Matrix, which are
fairly standard subtractive synthesizers. You have Skrewell and Space
Drone which spew forth randomly-generated sonic mayhem. And you have the
excellent Steam Pipe, which does waveguide synthesis. Plus Rectory (a
drum sample masher), Space Master (reverb unit), Travelizer and Grain
States (granular resynthesis), and so on.
In later versions of Reaktor, they added the "Reaktor Core" technology,
which allows you to build new DSP elements down to the sample level.
Whereas before you had filters and amplifiers and oscillators, now you
have individual ring buffers and numerical operators and signal routers,
so you can *design* filters and such.
NI also had a few other products that I was never really very interested
in. Things like Akoustik Piano, Elektrik Piano, a tonewheel organ
simulator, and so on.
Eventually, NI came up with Kontakt, a generalised high-tech sample
player. Akoustik Piano and so forth all became mere instruments that run
inside Kontakt. When you buy Kontakt, you get something absurd like 12
DVDs of sample data, covering everything from an entire orchestral
string section, right down to bagpipes and sitars.
When I first got to play with Kontakt, I was pretty amazed. It's not
that it's an especially brilliant sample player; it's more that the
samples are astonishing. Load up the "violin ensemble" instrument, and
each time you press a key, it plays back a recording of 12 professional
violinists playing expensive antique violins. I can sit here playing
1-finger melodies and it sounds insane. I don't even *need* to play big
chords; the sound on its own is already so rich.
And then of course, not only do we have sustained violin, we have
staccato, pizzicato, tremolo, sforzando, and so on. And not just violin,
but viola, cello and double-bass as well. And then you've got horns and
harps and flutes and... And you can change the sonic space they sit in;
from recording studio to concert hall to cathedral.
Perhaps most impressive of all, there are three pipe organ sounds. Call
up one of these, and when you play Bach organ toccatas it *sounds* like
you're playing a cathedral organ.
In the latest version of Kontact, they promised even more organ sounds.
Actually they delivered a piffling two. They also promised a choir; the
choir sounds are utterly astonishing. Every key brings forth a recording
of a professional choir of 25 voices. Press a 3-note triad and that's 75
singers calling at you. Major chords sound like pure liquefied joy.
Minor chords sound so hauntingly laden with sorrow as to rend your
heart-strings asunder. The other night I played Bright Eyes, and
actually made myself physically cry. (My God, I'm such a pussy...)
The only problem, of course, is that the thing that makes strings and
voices sound so expressive is the way the sound delicately swells and
diminishes in intensity. All these Kontakt sounds have at least a dozen
velocity layers. (And their tone actually changes from layer to layer,
not just the volume.) But only the key-down velocity affects this. Once
a note is struck, it is apparently /impossible/ to raise or lower the
velocity. I've tried every MIDI message I can think of; none of them let
you get dynamics. That's a pretty big limitation, right there.
But I spoke of NI becoming "lost". What did I mean by that?
Well, once upon a time, NI used to sell new products. New synthesizers,
new effects, whatever. With the arrival of Kontakt, they started selling
"sound packs". A Kontakt sound pack isn't just a box of samples. There's
programming in there so that, for example, if you have a harpsichord
instrument, there are multiple samples for different notes, different
articulations, different velocity layers, attack samples, sustain
samples, release samples. (Harpsichord in particular has a
characteristic sound when the keys are released.) When you use the
soundpack, you see "harpsichord". It's actually made up of a bazillion
samples, with lots of scripting to tell the sampling engine (i.e.,
Kontakt) what samples to play when. But that's all set up for you. You
just play stuff.
There are sound packs for Absynth or FM8 as well, of course. For a while
NI had a product called Kore, which was supposed to be some kind of
sound library manager or something... it was their flagship product, but
now they have discontinued it, which is a bit of an abrupt U-turn.
With the stage now set, it seems an awfully long time since any "new
products" came out. Instead, we have sound packs. Reaktor in particular
allows fairly radical "new instruments" to be produced without doing any
"actual coding", as such. (I.e., without needing a C++ compiler.) For
example, recently we had The Mouth:
http://www.youtube.com/watch?v=zzyr66QhrOw
We also had Reaktor Prism, a really lovely waveguide synthesizer that
picks up where Steam Pipe left off. And then there's Razor, an additive
synthesizer which produces "unheard of filter effects" [which all sound
exactly like normal filter effects, BTW].
For a while NI went on producing things like the Trip to West India
soundpack, or the Urban Arsenal pack, and so on. Things started to look
slightly iffy when they tried to sell Reflektor, which is basically an
Remember Akoustik Piano? You get 4 different piano recordings - one is a
Steinway concert grand, the other is a Bechstein, another is a
Boesendorfer, and finally there's an upright piano if you want that
imperfect "this is somebody's house" sound.
Well, guess what? These are now 4 separate, full-price product. The
Steinway has become "Concert Grand", the Boesendorfer has become
"Concert Vienna", and so on. No new content, just a new higher price.
But the thing that *really* makes me think that NI have lost their way?
They now sell compressors as full-price products.
Literally, they now sell VC-76, VC-2A and VC-160 as three separate
every pro-audio application ever made already includes a compressor,
right? And who *wouldn't* want an authentic emulation of 30-year old
studio equipment which by definition doesn't colour the sound it's
processing?
Better yet, now there is the Solid Mix Series, consisting of Solid Bus
bundle. WTF?
And to top it all out, there's Transient Master. The product blurb even
Who in the hell actually needs no less than 7 different audio
compressors? What are they smoking?!
Just to be fair, I sat down and listened to some of the audio demos for
the compressors. I was very, very hard-pressed to actually tell the
difference between the compressed and uncompressed sounds. It was even
harder to tell the difference between different compression settings.
(There isn't an option to compare different compressor products on the
same input.)
It's also entertaining watching some of the product videos. One of the
more useful products lately is Studio Drummer. The idea is that not only
do you get drum samples and software to play them, you also get software
that supposedly auto-generates lively and organic drum rhythms for you -
useful if you're not a professional drummer yourself. In the product
video, you see the crazy German guy who designed this thing
demonstrating how he buys brand new cymbals, and then bends and distorts
them, and finally buries them in his garden to give them a more "gritty"
sound. Weirdo...
Perhaps more hilarious are the Traktor and Maschine videos. There's one
where some Hip-Hop producer is in his personal home studio. He's sitting
there at a 100-track mixing console that probably cost tens of thousands
of dollars, and he's all pretending that he totally uses Maschine (a 599
****ING RIGHT! :-P Yep, I completely believe that...
Subject: Re: Lost
Date: 15 Nov 2011 22:50:51
Message: <4ec3331b$1@news.povray.org>
On 11/15/2011 8:56, Invisible wrote:
> It's actually made up of a bazillion samples, with lots of scripting to
 tell
That's pretty cool.
> products" came out.
I found Melodyne to be an amazing-seeming program. Not that I've played w
ith
them.
http://www.youtube.com/watch?v=jFCjv4_jqAY
http://www.youtube.com/watch?v=1oQn66gvwKA
 the
> compressors. I was very, very hard-pressed to actually tell the differe
nce
Maybe I'm confused, but isn't that the goal of an audio compressor?
Sadly, that is the way of the software these days.
   People tell me I am the counter-example.
Subject: Re: Lost
Date: 16 Nov 2011 06:31:28
Message: <4ec39f10$1@news.povray.org>
>> to tell
> That's pretty cool.
Yeah.
In the old days, you'd have a sample of one note, and change the
playback speed to get different notes. If you were really flash, you'd
have samples of several different notes, so you don't have to bend the
pitch too far. Trouble is, then as you run up or down the scale, you can
hear where the software switches from one sample to another.
Of course, those days are long gone. Each Kontakt instrument has at
least one sample for every single individual note. For something like a
piano, where every single note naturally sounds very slightly different
(and has a different stereo location), the result is very impressive.
In addition to that, you have "velocity layers"; rather than just
adjusting the sample playback volume in response to harder or software
keypresses, you actually play a different sample. (Of course, MIDI
allows 127 different velocities, while a typical instrument has only
perhaps 6 different velocity samples for each note, so some volume
mapping is still used to go between. Personally I would have thought
cross-mixing would be more accurate, but what do I know?)
Then of course some instruments have a characteristic attack, or even
release (harpsichord). And some have infinite sustain (generally wind
instruments), so you have a looping sample in the middle. Rather than
have text boxes to type in sample names, Kontakt has some sort of
scripting language to control what the sample engine plays. This
obviously allows a lot more flexibility.
As if all that wasn't enough, for some instruments they record them with
4 sets of microphones, placed at different distances from the sound
source. So you can hear a piano up-close and personal, where you can
hear the sound of the keys, the muffled clunk of the dampers, and
everything. Or you can hear a distant piano, where the notes are as
clear as day, but not the mechanics. Again, this isn't filtering, this
is multiple sets of samples.
On top of *that*, you can have the piano lid open, half-open or closed,
which obviously radically alters the sound.
So for the piano instrument, you have: 3 lid positions * 4 microphone
distances * 12 key velocities * 88 notes on the keyboard, yielding a
total of 12,672 individual samples. (Can you *imagine* how boring it
must have been to record all of those??) No wonder each piano comes on
its own DVD! (There are 4 different pianos, remember...)
The pianos also support different tunings - but *that* is done in
software. (E.g., you can have a piano with Pythagorean tuning if you so
desire. In solemn truth, it makes scant difference to the sound.)
A similar thing happens with, say, violin. 4 sets of microphones. The
players play each possible note, as softly as they can. They play them
all again, slightly louder. And so on, until they're playing as loud as
they can. Then they play again, tremolo style. Then again, pizzicato
style. Then again, sforzando style. And so on.
For harp, there is "normal" and "flageolet" (slightly muted). Some of
the instruments have just one articulation. Some (e.g., harpsichord)
have only one velocity layer.
>> products" came out.
> with them.
I'll take a look when I go somewhere with sound capabilities.
>> for the
>> difference
The goal of a compressor is to very subtly enhance the sound. Which
makes it all the more amusing to see a "fully authentic emulation of the
iconic sound of this vintage compressor". If the compressor is any good,
it doesn't *have* a recognisable sound! :-P
Also, I suspect that if all of your sound sources are algorithmically
generated, you probably don't *need* a compressor in the first place.
You can just change the volume envelope of the sound source directly. A
compressor is more useful if you're trying to record live real-world sounds.
>> Bizarrely, there is now an iPhone version of Maschine. It costs 4.99 €.
So I can pay a hundred pounds for the software on my PC, or 1/20th of
that for the exact same program on my phone?
Either one product is vastly overpriced, or the other is an absolute
bargain. :-P
(Then again, given that an iPhone presumably costs more than even the
most expensive PC in the first place... maybe not.)
