Take the company's mission-critical server. Take a disk image of the OS
partition. Boot from a Linux live CD. Reformat the system partition.
Restore the system partition from the image file, and pay to God
almighty that it actually boots up again.
Sure, there's no reason why it *shouldn't* work... But let me tell you,
that had my hands shaking for a few minutes there! o_O
Invisible <voi### [at] dev null> wrote:
> ... pay to God ...
Freud was right. ;-)
On 25/10/2011 02:06 PM, Mike the Elder wrote:
> Invisible<voi### [at] dev null> wrote:
>> ... pay to God ...
"Too right! After all, the Bible does say 'God helps those who help
themselves', right?"
"Actually, no, that's Aesop's Fables. The Bible says quite the opposite,
in fact..."
Said the shoplifter.
<boom-tish>
Jim
Why would you do such a thing to begin with?
You have to look busy or else management will start doubting your
necessity.
The server is persistently experiencing NTFS corruption errors, and I
just can't get rid of them. Which is strange, because if I restore the
image file to a virtual machine, it runs completely without issue...
You won't be surprised to learn that the elaborate procedure above
utterly failed to fix the problem. But hey, it was worth a shot.
http://blog.orphi.me.uk/
I assume you have checked the disk for errors. Thoroughly.
1. Would a physical disk error actually affect a logical RAID-1 volume?
(And shouldn't that affect *all* the partitions, not just one?)
2. Yes, I asked CHKDSK to do a full surface scan. It found nothing wrong.
I've seen fleeting references that say that CHKDSK doesn't fix all
possible filesystem errors, so perhaps that's the problem I'm seeing
here... Still doesn't tell me how to fix it though.
When you write "logical RAID-1 volume", are you referring to a volume
created by mirroring two drives in the Windows OS, or is it a volume
created via the adapter hardware+software? Also, what Windows OS,
drives and adapter(s) are you using?
