POV-Ray : Newsgroups : povray.off-topic : I giggled a bunch at this. Server Time
14 May 2026 02:37:51 EDT (-0400)
  I giggled a bunch at this. (Message 22 to 31 of 41)
Subject: Re: I giggled a bunch at this.
Date: 30 Sep 2011 08:11:50
Message: <4e85b206$1@news.povray.org>
On 30/09/2011 12:01 PM, Invisible wrote:
>>> What I actually /said/ was that computers (by which I mean fully
>>> autonomous computational devices)
>> What do you mean by "fully autonomous computational devices"?
> Well, that's the killer, isn't it?
AI, I suppose.
> An abacus can add. But only if an intelligent human is operating it. All
> the smarts are in the operator; the abacus is just a memory tool, really.
> A pocket calculator can add. Even if it's operated by raindrops getting
> the keys. The smarts are in the device.
> Now, how the heck you formulate that into some kind of coherent
> definition......
When you do, submit it as a PHD thesis. ;-)
Actually I don't think that I agree with your comparison between the
abacus and pocket calculator. I think that the latter is just a better
type of the former.
>> I am not familiar with ...
> The number of steps required to find what you want is proportional to
> the logarithm of the size of the thing you're searching.
> If you search for a definition by looking at every page in the book
> until you find what you're after, the amount of work is obviously
> directly proportional to the size of the book. On the other hand, if you
> look it up in the index and then go straight to that page, the amount of
> time is proportional to the logarithm of the number of pages.
> In the former case, if you double the number of pages, you double the
> time required to find anything. In the latter case, doubling the number
> of pages has little effect on the lookup time. (Assuming the book was
> already large to start with, of course.)
Well put, that completely reverses what I thought you meant.
> I wasn't trying to be funny. I was trying to phrase a definition which
> would encompass things that don't look like modern hardback "books".
> Things like rolls of parchment or stone tablets, etc.
Fair point considering. :-)
> I'm well aware that there have been many computers that used decimal
> instead of binary. (A few even used other number systems.)
I've worked on at least one system that used BCD (Binary Coded Decimal)
> Now, you need to be a little bit careful here: There is a distinction to
> be made between devices that can "calculate" things, and devices which
> are considered to be "computers". As far as I'm aware, none of the old
> "analogue computers" were actually Turing-complete, and so strictly they
> are /calculators/ rather than /computers/.
alter its input or operating instructions or what?
for each problem they needed to solve. But it could be done.
> The history of /calculators/ obviously goes back far, far beyond the
> history of /computers/. (Again, depending on how general your
> definitions are.)
Indeed.
Regards
Date: 30 Sep 2011 09:25:14
Message: <4e85c33a@news.povray.org>
>> definition......
Thanks. I'll pass.
> type of the former.
In order to work an abacus, /you/ have to know that ten beans on one
line is worth one bean on the next line. With a pocket calculator, this
kind of thing is automatic. You don't have to understand it.
I will conceed that automation is a kind of "shades of grey" thing.
There are greater and lesser degrees of automation, rather than just
"manual" and "automatic".
Yes, but generally you use BCD if you have a /binary/ system and you
specifically want to do exact /decimal/ arithmetic. (It's a well-known
fact that 1/10 is not representable as an exact binary fraction. In some
settings, that might be a problem.)
The formal definition of Turing-completeness is abstract and technical.
Essentially Alan Turing proved two main things:
1. It is possible to build *one* machine that can perform *any* possible
calculation.
2. Some calculations are impossible.
[Simplifying wildly, of course.]
You would think that a more complex, more sophisticated machine would be
able to calculate more things than a simpler machine. In fact, it turns
out that if they are both Turing-complete, they can both calculate
exactly the same stuff. (The more sophisticated machine is probably much
/faster/, of course...)
Consider an analogue computer, for a moment. It might have circuits that
can add numbers together. But if I want to add up one million operands,
I need to wire together [at least] one million adder circuits.
Now consider a simple digital computer. It might have only one binary
adder circuit, and yet it can add up an unlimited number of operands,
with unlimited precision.
Analogue computer: More steps = more hardware.
Digital computer: More steps = more time.
That's a fundamental difference. If I have an analogue computer with ten
adder circuits, I cannot add up eleven numbers. But if I have a
Turing-complete machine, I can add up an /unlimited/ number of operands.
You never need more hardware. It just takes more time.
This difference comes about mainly because a digital computer has a
/memory/. It can /store/ operands and feed them through its arithmetic
circuits one at a time. An analogue computer can't do that, so it has to
have one dedicated circuit for each step of the process. A digital
computer can /reuse/ the same circuits again and again for different
steps, because the steps won't happen all at once.
Also, you can often "program" an analogue computer. But you basically do
that by rewiring it. The machine can't rewire itself. But a
Turing-complete machine can have self-modifying code.
Actually /proving/ that something is Turing-complete is usually not
simple at all. But probing that something /isn't/ Turing-complete just
requires you to find one thing that it can't do [and a Turing-complete
machine can].
You could say it's a calculator if it only calculates one thing (e.g., a
mechanical tide predictor), it's a calculator construction kit if it can
calculate many things (e.g., a typical "programmable" analogue
"computer"), and it's a computer if it's Turing-complete (i.e., it has a
stored program, decision-making capabilities, etc.)
Date: 30 Sep 2011 09:52:19
Message: <4e85c993@news.povray.org>
>>> definition......
> Thanks. I'll pass.
LOL
> calculation.
Thanks
Not so, an analogue machine can have memory. A capacitor will store a
voltage until another arithmetic step is added to it. So that argument
does not hold water.
That makes more sense to me.
> machine can].
Hmm! I don't know. You can do some very intricate and complicated things
with analogue electronics. Consider the brain. O_o
Regards
Date: 30 Sep 2011 10:11:12
Message: <4e85ce00$1@news.povray.org>
>> calculation.
> Thanks
I was under the impression that a capacitor only holds its charge for a
very short period of time.
Regardless, have you ever actually seen an analogue computer with
independently addressable memory cells? I haven't heard of such a thing.
On the other hand, if the connections were controlled by an array of
relays or something, and the computer could control the relays... then
you would be progressing towards a more truly programmable system.
Well, strictly speaking, every digital computer is also an analogue
computer. They're just designed and used differently.
Date: 30 Sep 2011 11:47:22
Message: <4e85e48a$1@news.povray.org>
Depends what you mean by very short period of time. Most circuits that
use large capacitors will have a discharge resistor in parallel to stop
the capacitor holding the charge when the power is off. In domestic
appliances such as radios and TVs, it was recommended that you wait 20
minutes after switching off before working on them.
Also see:
http://en.wikipedia.org/wiki/Regenerative_capacitor_memory
What to answer first? I don't know, the only actual working valve
computer I've ever been in the presence of was at Glasgow University,
over 40 years ago. I've never had hands on experience working with them.
But you would not use addressable memory as you would in digital
computers. Remember that we are talking about voltage levels
representing numbers. Also back in the day, what was being asked of then
was much simpler and less complex so a lot of memory would not have been
required.
And use different principles.
http://en.wikipedia.org/wiki/Analog_computer#Electronic_analog_computers
or
http://www.bookrags.com/research/analog-vs-digital-computing-wcs/
Regards
Date: 30 Sep 2011 12:44:02
Message: <4e85f1d2$1@news.povray.org>
On 9/30/2011 2:48, Stephen wrote:
> An algorithm is an effective method expressed as a finite list of
> well-defined instructions for calculating a function.
So, a cake recipe isn't an algorithm? I'll have to disagree.
> So in English, if possible, what do you mean?
O(lg N) approximately means the number of steps it takes to do something is
roughly proportional to the number of digits in the input. So looking up a
word in the index of a book, then turning to the page number, is
approximately difficult based on the number of letters in the longest word
of the index, the number of digits in the page numbers the index covers, and
the number of digits in the pages of the book.
   How come I never get only one kudo?
Date: 30 Sep 2011 12:53:08
Message: <4e85f3f4@news.povray.org>
On 9/30/2011 6:25, Invisible wrote:
> Now consider a simple digital computer. It might have only one binary adder
> circuit, and yet it can add up an unlimited number of operands, with
Except that a Turing machine has an unbounded amount of memory, so you're
not really comparing apples to oranges here.
The digital computer requires more hardware too, in terms of "tape". All
those numbers you're adding have to be in the input somewhere.
> Turing-complete machine, I can add up an /unlimited/ number of operands. You
You never need more hardware because, by definition, Turing machines have
unbounded amounts of hardware attached. If you had an unlimited number of
analog ALUs, you'd be golden with an analog computer.
> that by rewiring it. The machine can't rewire itself. But a Turing-complete
You do it by rewiring a Turing machine, also. It just so happens that
because you have an unlimited amount of memory, you can wire up one computer
that will simulate whatever other computer you put in the memory units
(i.e., the "tape"). You could do the same with an analog computer as well.
> Actually /proving/ that something is Turing-complete is usually not simple
It's usually not too hard. You just write a turing-machine simulator in
whatever system you're trying to prove is turing complete. If you can
simulate a turing machine with an analog computer, then that analog computer
is turing complete.
Date: 30 Sep 2011 13:05:00
Message: <4e85f6bc@news.povray.org>
>> adder
> you're not really comparing apples to oranges here.
Yeah, one of the details I glossed over.
If I have a normal desktop PC then /in principle/ I can insert an
endless number of disks into it. Obviously, a Turing machine is a
mathematical abstraction. No physical machine can have infinite
anything, because the universe is finite.
> have unbounded amounts of hardware attached. If you had an unlimited
> number of analog ALUs, you'd be golden with an analog computer.
Small difference: ALUs require energy. A storage medium typically doesn't.
>> Turing-complete
> computer that will simulate whatever other computer you put in the
> memory units (i.e., the "tape"). You could do the same with an analog
> computer as well.
If you're saying "you could make an analogue computer that was
Turing-complete" then, yes, of course you could. If you're saying "the
analogue computers what people actually built were Turing-complete"
then, no, not really...
>> simple
Exhibit A: Totallistic cellular automaton number #110.
http://blog.orphi.me.uk/
Date: 30 Sep 2011 13:09:13
Message: <4e85f7b9$1@news.povray.org>
Be my guest.
See if I care :-P
Regards
Date: 30 Sep 2011 14:32:48
Message: <4e860b50@news.povray.org>
ALUs don't require much energy. Look up "reversible computing" some time.
That's what it's all about. And yes, people have actually built computers
that take no energy to run, using quantum effects.
> analogue computers what people actually built were Turing-complete" then,
> no, not really...
Well, sure, and neither are the real digital ones. That's kind of my point.
Exactly.
