POV-Ray : Newsgroups : povray.off-topic : Java Server Time
14 May 2026 01:06:53 EDT (-0400)
  Java (Message 14 to 23 of 23)
Subject: Re: Java
Date: 26 Sep 2011 18:34:05
Message: <4e80fddd@news.povray.org>
Le 2011/09/26 04:44, Invisible a écrit :
>>> Was it you that said something about "committing to backwards
>>> compatibility way too early"?
>> Yep. That was the fundamental failure, caused by the whole "write once"
>> marketing campaign.
> I wouldn't mind, but it didn't even /work/.
> Like I said, I wrote an applet. It worked fine in IE. When I tried it
> with Netscape, it crashed with a null pointer exception. And, since it's
> an applet, I have no idea /where/ it crashed. You don't get a stack trace.
> I suspect this is probably related to the vagueness of the
> documentation. That means that others don't really know how to implement
> it correctly. Or, hell, maybe the documentation just doesn't actually
> match what Sun implemented...
It may be that some bug in the implementation under IE is effectively
hiding another bug...
It may be that you get the crash on the correct implementation and you
did something wrong that made it work on a faulty implementation.
Remember the imfamous "it's not a bug, it's a feature" that Microsoft
spun to cover actual IE bugs instead of correcting them.
>>> I notice Office no longer comes with any documentation at all, just a
>>> link to an online forum.
>> It has documentation. It just mixes it in with the online forum. I think
>> you have to chose to install it locally, tho, which is what you might be
>> seeing.
> Oh well. Almost never non-trivial Office task usually involves finding
> an Office MVP anyway...
>> I've lost track of closing braces....
> ...which is why every open bracket should always start a new indentation
> level...
Subject: Re: Java
Date: 26 Sep 2011 20:11:33
Message: <4e8114b5@news.povray.org>
On 9/26/2011 15:34, Alain wrote:
> It may be that some bug in the implementation under IE is effectively hiding
> another bug...
 From experience in exactly this field (java applets in the early days) I
can pretty much guarantee f'ups were Mozilla and not Microsoft.
   How come I never get only one kudo?
Subject: Re: Java
Date: 27 Sep 2011 04:04:59
Message: <4e8183ab$1@news.povray.org>
>> hiding
>> another bug...
> I can pretty much guarantee f'ups were Mozilla and not Microsoft.
Considering the applet only makes a handful of AWT calls before doing
lots of compute-bound stuff to generate a fractal... I'm pretty sure it
was just some unimplemented library call returning null or something
like that.
Subject: Re: Java
Date: 17 Nov 2011 04:26:57
Message: <4ec4d361$1@news.povray.org>
On 24/09/2011 04:37 PM, Darren New wrote:
> What would be in C#
> var z = from y select z where z.id = myID
> in java becomes
> List<OrganizationIndividualRelationshipEntity> z =
> Lists.ImmutableCopyOf(
> Lists.filter(y, new
> Predicate<List<OrganizationIndividualRelationshipEntity>() {
> @override boolean apply(OrganizationIndividualRelationshipEntity x) {
> return x.id = myID;
Haskell has crazy type signatures too.
Haskell also has mechanisms for defining shortcuts. :-P
Subject: Re: Java
Date: 17 Nov 2011 22:25:41
Message: <4ec5d035$1@news.povray.org>
>> What would be in C#
>> in java becomes
>> Lists.filter(y, new
>> return x.id = myID;
You don't understand. Those *are* the shortcuts in Java.
No, I am not exaggerating.  For example, "Lists" is nothing but a static
class full of static routines that are shortcuts for actually shortcuts for
the more full-bodied declarations including all the generic types.
   People tell me I am the counter-example.
Subject: Re: Java
Date: 18 Nov 2011 04:21:43
Message: <4ec623a7@news.povray.org>
IT BURNS!! >_<
Subject: Re: Java
Date: 18 Nov 2011 10:55:29
Message: <4ec67ff1$1@news.povray.org>
Darren New escreveu:
>>> What would be in C#
>>> in java becomes
>>> Lists.filter(y, new
>>> return x.id = myID;
> for the more full-bodied declarations including all the generic types.
problem is that you're trying to make java look worse than it is (and I
agree it is bad) by programming it in a functional style it simply is
not meant to.  Java is all about imperative programming at its worse,
but at least it makes some sense when programmed that way.
I'm not quite natural to java, but I guess the correct way to program:
in it would be something like:
List<OrganizationIndividualRelationshipEntity> y, z;
for (OrganizationIndividualRelationshipEntity x : y)
   if (x.id = myID) z.add(x);
that doesn't look half as bad as trying to program C in Object-Oriented
fashion.  Still, not as fun as without type declarations.  I suppose if
the code snippet was inside some generics method you could call
"OrganizationIndividualRelationshipEntity" "T" and have:
List<T> y, z;
for (T x : y)
Subject: Re: Java
Date: 19 Nov 2011 01:08:08
Message: <4ec747c8@news.povray.org>
Well, it's the way this particular project at google was written. But yes,
making Java functional without lambdas is messy.
I went thru something like 300 classes in this particular hugely
overengineered project and didn't find a single noun in the bunch of them.
They were all stuff like "CustomerUpdater" and "StorageManagerImplementor"
and such.  I think it comes from doing too much networking, since networks
don't do a real good job of shipping objects around. I've been trying to
introduce the team to the wonders of actually having the code and the data
in the same class. :-)
Yep.
Subject: Re: Java
Date: 19 Nov 2011 04:33:52
Message: <4ec77800$1@news.povray.org>
Le 19/11/2011 07:07, Darren New nous fit lire :
> I've been trying to introduce the team to the wonders of actually having
> the code and the data in the same class. :-)
Well, from the old relational database experience... they shouldn't.
At least, they shouldn't be too tighly coupled until the code is
specific to the data and the data are usable only by the code.
Have a SQL schema (data) and only stored procedures usually ends up in
nightmare.
Data should have their invariants and rules.
Code should be in charge of transforming the data with respect to the
rules and adding new pieces of data which also match the rules.
But you're right, having data in very distant classes from the ones
which have the code is also a PITA. (and from an isolation point of
view, the code classes should not be friend of data class, so no ugly
shortcuts...)
Subject: Re: Java
Date: 19 Nov 2011 12:20:15
Message: <4ec7e54f@news.povray.org>
Well, the data in the database shouldn't be exposed to the user at all, any
more than if your web site is stored in a database the browser should need
to know that.
What I'm saying is that if you have a routine that (for example) marks a
video as having been watched by the current user, it shouldn't be in some
third class called "VideoWatcherRecorder" taking an integer video number and
a long user ID. It should be in the video class and take a reference to a
user object, or vice versa. Otherwise, you're just writing procedural code
in Java.
Yep. And that's very hard to do without doing OO programming. Or relational
programming. And if you're using an OO language like Java, it should be
enforced in the objects that interface to the database (along with the
database, if possible, which it isn't in this case).
Sure. But the difference is where that code live. Is it in some other
package or compilation unit, or is it in the same class that reads and
writes the database?
