POV-Ray : Newsgroups : povray.off-topic : Java Server Time
14 May 2026 01:06:42 EDT (-0400)
  Java (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Java
Date: 26 Sep 2011 04:44:15
Message: <4e803b5f$1@news.povray.org>
>> Was it you that said something about "committing to backwards
>> compatibility way too early"?
> Yep. That was the fundamental failure, caused by the whole "write once"
> marketing campaign.
I wouldn't mind, but it didn't even /work/.
Like I said, I wrote an applet. It worked fine in IE. When I tried it
with Netscape, it crashed with a null pointer exception. And, since it's
an applet, I have no idea /where/ it crashed. You don't get a stack trace.
I suspect this is probably related to the vagueness of the
documentation. That means that others don't really know how to implement
it correctly. Or, hell, maybe the documentation just doesn't actually
match what Sun implemented...
>> I notice Office no longer comes with any documentation at all, just a
>> link to an online forum.
> It has documentation. It just mixes it in with the online forum. I think
> you have to chose to install it locally, tho, which is what you might be
> seeing.
Oh well. Almost never non-trivial Office task usually involves finding
an Office MVP anyway...
> I've lost track of closing braces....
...which is why every open bracket should always start a new indentation
level...
Subject: Re: Java
Date: 26 Sep 2011 14:37:48
Message: <4e80c67c$1@news.povray.org>
On 9/23/2011 12:25 PM, Orchid XP v8 wrote:
> On 23/09/2011 05:43 PM, Mike Raiford wrote:
>> On 9/23/2011 10:28 AM, Invisible wrote:
>>> (I suppose you could argue that C# is the same. You know, if it actually
>>> worked on more than one platform...)
>> Mono.
> Does Mono support more than 0.2% of what .NET supports yet?
Yeah, at least more than 0.2% probably by a substantial amount. But I
can't be bothered to target the Mono framework, honestly, I'll just
stick with MS's CLR.
~Mike
Subject: Re: Java
Date: 26 Sep 2011 14:39:01
Message: <4e80c6c5@news.povray.org>
On 9/24/2011 10:37 AM, Darren New wrote:
>> compatibility
>> way too early"?
> marketing campaign.
>> link
>> to an online forum.
> seeing.
>>> I did some code yesterday where I had to break one type name over
>>> multiple lines to keep within the 80-character line limit standard. It
>>> doesn't help when you have stuff like
>>> FastPersistentLinearCollection<OrganizationIndividualRelationshipEntity>
>>> I kid you not.
>> That's just silly...
> It makes perfect sense in context. It's just absurdly verbose.
> What would be in C#
> var z = from y select z where z.id = myID
> in java becomes
> List<OrganizationIndividualRelationshipEntity> z =
> Lists.ImmutableCopyOf(
> Lists.filter(y, new
> Predicate<List<OrganizationIndividualRelationshipEntity>() {
> @override boolean apply(OrganizationIndividualRelationshipEntity x) {
> return x.id = myID;
Java: It's like pounding your head against a brick wall. Repeatedly.
~Mike
Subject: Re: Java
Date: 26 Sep 2011 18:34:05
Message: <4e80fddd@news.povray.org>
>> marketing campaign.
It may be that some bug in the implementation under IE is effectively
hiding another bug...
It may be that you get the crash on the correct implementation and you
did something wrong that made it work on a faulty implementation.
Remember the imfamous "it's not a bug, it's a feature" that Microsoft
spun to cover actual IE bugs instead of correcting them.
>> seeing.
> level...
Subject: Re: Java
Date: 26 Sep 2011 20:11:33
Message: <4e8114b5@news.povray.org>
On 9/26/2011 15:34, Alain wrote:
> It may be that some bug in the implementation under IE is effectively hiding
> another bug...
 From experience in exactly this field (java applets in the early days) I
can pretty much guarantee f'ups were Mozilla and not Microsoft.
   How come I never get only one kudo?
Subject: Re: Java
Date: 27 Sep 2011 04:04:59
Message: <4e8183ab$1@news.povray.org>
>> hiding
>> another bug...
> I can pretty much guarantee f'ups were Mozilla and not Microsoft.
Considering the applet only makes a handful of AWT calls before doing
lots of compute-bound stuff to generate a fractal... I'm pretty sure it
was just some unimplemented library call returning null or something
like that.
Subject: Re: Java
Date: 17 Nov 2011 04:26:57
Message: <4ec4d361$1@news.povray.org>
On 24/09/2011 04:37 PM, Darren New wrote:
> What would be in C#
> in java becomes
> Lists.filter(y, new
> return x.id = myID;
Haskell has crazy type signatures too.
Haskell also has mechanisms for defining shortcuts. :-P
Subject: Re: Java
Date: 17 Nov 2011 22:25:41
Message: <4ec5d035$1@news.povray.org>
>> What would be in C#
>> in java becomes
>> Lists.filter(y, new
>> return x.id = myID;
You don't understand. Those *are* the shortcuts in Java.
No, I am not exaggerating.  For example, "Lists" is nothing but a static
class full of static routines that are shortcuts for actually shortcuts for
the more full-bodied declarations including all the generic types.
   People tell me I am the counter-example.
Subject: Re: Java
Date: 18 Nov 2011 04:21:43
Message: <4ec623a7@news.povray.org>
IT BURNS!! >_<
Subject: Re: Java
Date: 18 Nov 2011 10:55:29
Message: <4ec67ff1$1@news.povray.org>
Darren New escreveu:
>>> What would be in C#
>>> in java becomes
>>> Lists.filter(y, new
>>> return x.id = myID;
> for the more full-bodied declarations including all the generic types.
problem is that you're trying to make java look worse than it is (and I
agree it is bad) by programming it in a functional style it simply is
not meant to.  Java is all about imperative programming at its worse,
but at least it makes some sense when programmed that way.
I'm not quite natural to java, but I guess the correct way to program:
in it would be something like:
List<OrganizationIndividualRelationshipEntity> y, z;
for (OrganizationIndividualRelationshipEntity x : y)
   if (x.id = myID) z.add(x);
that doesn't look half as bad as trying to program C in Object-Oriented
fashion.  Still, not as fun as without type declarations.  I suppose if
the code snippet was inside some generics method you could call
"OrganizationIndividualRelationshipEntity" "T" and have:
List<T> y, z;
for (T x : y)
