POV-Ray : Newsgroups : povray.off-topic : My hypothesis Server Time
14 May 2026 04:18:47 EDT (-0400)
  My hypothesis (Message 31 to 40 of 54)
Subject: Re: My hypothesis
Date: 6 Sep 2011 16:52:44
Message: <4e66881c$1@news.povray.org>
On 9/6/2011 13:28, Warp wrote:
>    I'm not sure how a compiler would be able to do that in a complex program
> where nodes and containers are being passed around.
I don't know about Haskell, but in some of the other languages (like
Erlang), changes tend to be localized enough that you can do essentially a
full-program analysis. It also helps that nothing can point to a newer
object; that is, the old heap can never refer to the newer heap, because
that would require modifying things that already exist.
That said, I don't really understand the details of how such an analysis is
done myself.
>    (Of course the copying is not a big deal if each node contains eg. a
> couple of integers. However, it begins to matter if they contain for example
> large strings, which isn't all that unusual.)
Sure. Or if it's storing a big structure that for whatever reason the
individual fields can't be shared, which would seem not unusual as well.
   How come I never get only one kudo?
Date: 6 Sep 2011 17:11:11
Message: <4e668c6e@news.povray.org>
  That's true if the nodes to be modified are copied for the new heap.
However, the whole question was whether the compiler can elide this copying
for efficiency. If it mistakenly elides the copying of a node that is being
shared by some other part of the code, and makes the change in-place, that
will break the program (because that other part of the code will see the
change even though it shouldn't).
  What I'm wondering is that it's probably way more common for the nodes
to not being shared (and thus have only one single owner), but how can
the compiler know that for sure in a complex program?
  If such a data container is used only inside one single function and
its contents never passed anywhere else, the compiler may be able to
deduce that it can elide copying. However, in many (if not most) situations
such data containers will live for longer than one single function (after
all, that's the most common use of a data container) and used by several
different parts of the program. It's enough for two different parts of the
program to modify (or perhaps even just read) the same data container for
the in-place modifications becoming a program correctness hazard.
Date: 7 Sep 2011 00:15:57
Message: <4e66effd$1@news.povray.org>
Right. Consider the "insert" function itself. It calls nothing else that
mutates the heap except for "insert". So for the duration of the actual
insert call, it knows the heap isn't shared.  Extend this concept a bit
(yes, that's fuzzy, I know) and with sufficient analysis, you can figure out
that when you do something like
    x = insert 27 original
    y = insert 56 x
    z = insert 23 y
that y is an intermediate value that can't be shared with anything else.
(OK, maybe not in the heap case, but in a fair number of other such
structures, it's not uncommon it's possible to determine that. Again, I'm
not familiar with the details of how it's done.)
> and used by several different parts of the program.
If you compile those separately, yes, that can be problematic. If you
compile it all at the same time, or have more sophisticated linking (like a
VM, say), then the range over which the compiler can deduce a lack of
sharing is greater.
Remember, too, that various kinds of GC can tell you whether something is
shared or not. You could conceive of a copy-on-write sort of thing that only
does the copy if the reference count is >1.
True. That's why it's better to leave it to the compiler than the
programmer. ;-)
Date: 7 Sep 2011 05:01:49
Message: <4e6732fd$1@news.povray.org>
>> Is this supposed to be efficient?
> If your functional language is pure enough, your compiler can often
> optimize out the apparent inefficiency. Of course, that requires a
> Sufficiently Smart Compiler.
> In practice, it's less efficient, but not as obviously awful as it would
> appear.
In a way, it's a bit like SQL. In SQL, if you want to find the customer
name for each order, you say "take the Cartesian product of the order
table and a customer table, then go through the result and throw away
all rows except the ones where ord_cust = custID". If both tables are of
size N, then the first step is O(N^2) in time and space, and the second
step is O(N^2) in time and O(N) in space.
That's nauseatingly inefficient! But fortunately, every half-sane RDBMS
on the planet looks at that query and goes "ah-HAH! You're doing a table
join!" and replaces it with a vastly more efficient algorithm. (Be it a
hash-join or an index lookup or whatever.)
If SQL wasn't being run by a "sufficiently smart interpreter", it would
be too laughably inefficient to even consider using. The *only* reason
its so ubiquitous is that everybody has built really, *really* smart
interpreters. And everybody /relies on/ the query you actually write
being optimised into something very fast. Usually it works every well
indeed.
Of course, SQL isn't a general-purpose programming language. It solves
one problem well. (Although it's not quite the relational algebra...)
Haskell is a general-purpose programming language. You write constructs
which /look/ horrifyingly inefficient. And then the compiler does its
thing, and the end result is more efficient than you'd imagine. Sure,
probably not as fast as C, but fast enough.
Also: I love how this started out as "how easy is it to understand
Haskell?" and has once again degenerated into "Haskell must be really
slow". Which wasn't the question at all.
You know those C hackers? The ones who write horribly unmaintainable
code in the name of being a few clock cycles faster? The ones who are so
obsessed with using the minimum amount of CPU time and RAM that they
write horrid spaghetti code?
Yeah, everybody hates those guys. You know what their problem is? They
fail to realise that programs are judged on criteria *other* than
run-time efficiency. Obviously nobody /wants/ slow code. But then nobody
/wants/ buggy code, unmaintainable code, code that crashes, code that's
impossible to understand, code that takes months to write and debug.
There's a /reason/ people code stuff in C and not assembly. Even though
(in theory if not in practise) assembly is faster, people use C. As I
recall, there was a long time where people wouldn't use C++ because they
said it was "too slow", and that only C was "fast enough". (Which as
amusing, given that the Language Shootout claims that C++ is actually
marginally /faster/ than C...)
Haskell usually isn't as fast as C or C++. It's also a lot simpler to
program. Especially if you want parallelism. You ask me "how do I update
a heap without copying?" I ask you "how do you update a heap in a
thread-safe manner?" Immutable by default => thread-safe by default.
That's just one example of the kind of benefits that Haskell brings.
According to the Language Shootout, Haskell averages about 3x slower
than C. Java averages only 1.5 slower (but uses more memory than
Haskell). Then again, people actually write applications in Ruby, Python
and so forth. People build high-traffic websites with PHP and Perl. All
of these come in at *hundreds of times* slower than C. And it hasn't
dented their popularity at all.
Sometimes run-time efficiency isn't the most important thing.
(One could argue that although Perl is Turing-complete, it probably
shouldn't be regarded as a general-purpose language. It's probably
blisteringly fast for the tiny fraction of the language that most people
actually use. One could also argue that the Language Shootout is a
benchmark to see which language has the most zealous fans with the most
spare time...)
Date: 7 Sep 2011 05:22:28
Message: <4e6737d4$1@news.povray.org>
On 06/09/2011 09:28 PM, Warp wrote:
>    Hmm, for the compiler to be able to elide the copying and make the changes
> in-place, it would have to know for sure that those nodes that are being
> changed are not being referenced from anywhere else in the program. (Because,
> obviously, if they are referenced by something else, that something else is
> going to see the change although it shouldn't.)
I used to think that the compiler magically performed these kinds of
optimisation somehow. I've gradually learned that this isn't the case.
Oh, sure, if you write one function that puts some data into a box, and
another function that immediately takes the data out of that box again,
the box will probably be optimised away. But for something like updating
a list / tree / whatever, it's usually not feasible to optimise out the
copying.
(There /are/ frameworks designed to spot long chains of container
manipulations and inline them into a giant nested loop. But that's not
compiler magic, that's clever user-level programming. The example I
posted contains no such magic.)
Let us be clear about exactly what is copied:
If you have a heap which contains N internal nodes (since there is only
"one" leaf node, shared by all heaps in the program) and you insert a
new item into that heap, then O(log N) new heap nodes get constructed.
Each [internal] heap node consists of 4 pointers. One points to
something resembling a vtable [that's how you can tell Node and Leaf
apart], one points to the datum, and the other two point to the child nodes.
So copying an internal node amounts to copying (and possibly altering) 4
pointers. This /regardless/ of the type of data the heap holds. Even if
it holds arbitrary-precision integers, you're still only copying 4
pointers. The integers haven't changed, and so are not copied.
It does seem a pity that in the [very common] case of starting from an
empty heap and repeatedly inserting new items into it, you have to keep
continually generating these new nodes and then throwing them away. In
mitigation, the GC is heavily optimised for this activity pattern.
Allocations are cheap. They happen in a per-core allocation area (so no
cache coherency issues), and each allocation is O(1). When the
allocation area fills up, a GC sweep happens. Because the allocation
area is quite small, it can be swept very quickly. The sweep identifies
garbage, frees it, and defragments the free space (so that allocation is
still O(1) in all cases).
It would be faster if you didn't have to do all this work, but it's not
as slow as you'd think.
There are two key scenarios where immutable data becomes a Big Win:
First, there's parallel programming. Immutable data is thread-safe data.
It /cannot/ change while you're examining it, so race conditions are a
non-issue. Obviously if you want to /communicate/ between threads,
that's another matter. But you don't ever have to worry about making one
thread wait to update something until after the other thread has
definitely finished using it. You won't ever see bugs where you mutate
something and then discover that another thread was actually still
reading it.
Second, backtracking search problems. You might think that copying stuff
every time you want to change it is inefficient, but if you're doing
some kind of search problem where you want to search multiple avenues,
then still having the old copy around drastically simplifies the
algorithm, and probably /increases/ efficiency. Because the alternative
is to deduce (or remember) what you did, and then manually undo it if
you need to backtrack.
Some guy at Google wrote a paper about translating a Python (?) system
to Haskell, and actually devoted a whole section to the problems of
trying to enforce immutability in Python, and the difficulties of doing
without it. Immutable data was sited as one of Haskell's biggest advantages.
The one place where immutability /does/ bit is arrays. Almost all
Haskell data structures are linked lists or trees of some kind, because
that way the copying is cheap. But if you update one index of a
one-million index array, you've got to copy a contiguous block of a
million elements. Not fast. Immutable arrays are great as super-fast
lookup tables, but unless the data changes very infrequently, you end up
needing mutable arrays. Immutable arrays just aren't all that useful.
[Insert rant about how Haskell's array implementation sucks...]
Date: 8 Sep 2011 00:09:42
Message: <4e684006$1@news.povray.org>
Which, incidentally, is the same number of nodes you'd have to update in a
mutable heap, too.
> But you don't ever have to worry about making one thread
> wait to update something until after the other thread has definitely
> finished using it.
That's not strictly true. It's entirely possible in modern processors that
the pointer gets written and is visible to other processors before the data
it points to gets flushed from the cache into main memory.
> Immutable arrays are great as super-fast lookup tables, but unless the data
> changes very infrequently, you end up needing mutable arrays. Immutable
Some of the google stuff is cool in that way. You can imagine you don't want
to update the entire file that holds the entire web every time you scan a
new document.
Date: 8 Sep 2011 04:13:41
Message: <4e687935$1@news.povray.org>
> a mutable heap, too.
Indeed. The only difference is that with Haskell, you *copy* these nodes
rather than simply modify them in-place.
>> finished using it.
> that the pointer gets written and is visible to other processors before
> the data it points to gets flushed from the cache into main memory.
No, that's exactly what the "cache coherence" protocol prevents.
>> data
> want to update the entire file that holds the entire web every time you
> scan a new document.
If defies my comprehension that what Google does is actually physically
possible, but anyway...
Date: 8 Sep 2011 13:24:29
Message: <4e68fa4d@news.povray.org>
Sure. I'm just saying that saying "it's write-once" doesn't automatically
mean it's thread safe in a modern multi-processor. The generated code
actually has to take some care to tell the processor to flush cache lines
and such.
It kind of boggles my mind too. Just the complexity of the monitoring stuff
is stunning, let alone actually getting work done. :-)
Date: 8 Sep 2011 14:37:01
Message: <4e690b4d$1@news.povray.org>
> automatically mean it's thread safe in a modern multi-processor. The
> generated code actually has to take some care to tell the processor to
> flush cache lines and such.
According to the documentation I read, this is automatic. As in, the
code doesn't have to take any explicit action at all to ensure that all
processors see a consistent image of main memory. It's just that if
several cores try to access the same area at once, it gets very, very slow.
> stuff is stunning, let alone actually getting work done. :-)
Apparently it's one of the monitoring and load-balancing systems they
translated to Haskell...
http://blog.orphi.me.uk/
Date: 9 Sep 2011 12:14:22
Message: <4e6a3b5e$1@news.povray.org>
It certainly depends on the CPU and architecture.
http://en.wikipedia.org/wiki/Memory_barrier
You also have to make sure you're not caching something in a register that
you've written out the pointer to.
What is?
