POV-Ray : Newsgroups : povray.off-topic : Curious perversions of IT Server Time
14 May 2026 04:04:35 EDT (-0400)
  Curious perversions of IT (Message 21 to 24 of 24)
Subject: Re: Curious perversions of IT
Date: 20 Aug 2011 06:24:20
Message: <4e4f8b54$1@news.povray.org>
Am 20.08.2011 11:49, schrieb Orchid XP v8:
> Lest anyone doubt this, at uni we learned about something called
> Computer Aided Software Engineering ("CASE"). We used a tool called
> Rational Rose. You draw various class diagrams, flowcharts, etc., and
> then press a button, and it spits out C++ source code. If your diagrams
> are detailed enough, the generated code actually compiles and runs, and
> *is* "the finished system".
Similarly, Matlab/Simulink allows you to write your program by visually
"wiring" kind of "mathematic gates" (arithmetic ops, logical ops,
integrators, differentiators, level triggers, signal generators, signal
filters and what-have-you) and then have that translated to C and
ultimately machine code. Seen that recently hands-on in production use,
for the electronic controller of a car transmission.
> All without you ever writing a single line of code yourself. Or even
> knowing *how* to program C++.
> So yes, if your design is detailed enough, the translation is (or can be
> made) automatic.
... provided you trust the code generator.
Some portions of the car transmission software I mentioned were actually
still written directly in C; those were responsible for fail-safe
functions, so that even a bugs in the code generator couldn't possibly
cause an accident. (I'm not sure how they verified the C compilation
process though.)
Date: 20 Aug 2011 06:41:52
Message: <4e4f8f70$1@news.povray.org>
Reaktor does the some thing with DSP. I can pick up a sawtooth
oscilator, a 2-poly LP filter, an ADSR envolope generator, hook them
together, and I've got a synthesizer. Not impressed? How about I hook
together a couple of 1-sample delay units, some (+) and (*) nodes, and
implement my 2-pole filter from first principles?
Other "module synthesizers" let you connect pre-built filters and so
forth together. Reaktor lets you design new ones from scratch, down to
the level of individual DSP algorithms. (On the other hand, it stupidly
lacks any kind of true subroutine capability, nor any looping constructs...)
>> made) automatic.
And the compiler. And the processor implementation. And, hell, the
entire hardware system you're going to run it on. And, if you want to be
picky about it, assuming your trust mankind's understandig of the laws
of physics...
http://blog.orphi.me.uk/
Date: 20 Aug 2011 10:37:04
Message: <4e4fc690$1@news.povray.org>
Or VHDL, that lets you write the math for your hardware and have it generate
the hardware for you.
> accident. (I'm not sure how they verified the C compilation process though.)
At JPL, they disassemble the machine code and make sure it does what they
think the C said it does.
   How come I never get only one kudo?
Date: 25 Aug 2011 17:19:02
Message: <4E56BC48.2070200@gmail.com>
On 19-8-2011 15:21, Mike the Elder wrote:
> The REAL problem, as I see it, is the pig-headed unwillingness of so many
> corporate executives to employ people who actually KNOW whether $4,000.00
> software or $4,000,000.00 software is needed and allow them to make the purchase
> decisions.
This is mainly based on the idea that management is a skill in itself. A
manager of a workshop does not need to know anything about designing or
making things. Likewise, a manager of a hospital does not need to know
anything about medicine or patient care. Knowing management skills is
enough. Actually knowing what the people are doing will make it
impossible to judge objectively who is necessary and who can be fired.
Therefore the suggestion that you should be able to judge an IT contract
is an insult to management. Worse, people might use that to question the
level of salaries paid.
