POV-Ray : Newsgroups : povray.off-topic : Password difficulty Server Time
14 May 2026 02:38:20 EDT (-0400)
  Password difficulty (Message 28 to 37 of 37)
Subject: Re: Password difficulty
Date: 16 Aug 2011 19:05:32
Message: <4e4af7bc@news.povray.org>
On 8/11/2011 11:17, Jim Henderson wrote:
> On Thu, 11 Aug 2011 09:09:01 +0100, Invisible wrote:
>> Personally, I think the most /realistic/ way to gauge password strength
>> is to see how long it takes real, commonly-available password crackers
>> to break your password.
> Arguably that's the most accurate way, but not the most realistic way.
However, I know a number of corporations that will try to crack your
password each time you change it and if they can, they'll make you change it
again. You just get an email after a couple days saying "change it or get
locked out."
   How come I never get only one kudo?
Date: 16 Aug 2011 20:24:05
Message: <4e4b0a25@news.povray.org>
>>> strength is to see how long it takes real, commonly-available password
>>> crackers to break your password.
> change it again. You just get an email after a couple days saying
> "change it or get locked out."
Yeah, that's a different approach - and not necessarily a bad one.
Jim
Date: 17 Aug 2011 09:50:38
Message: <4e4bc72e$1@news.povray.org>
On 8/11/2011 3:09 AM, Invisible wrote:
> On 11/08/2011 03:27 AM, Chambers wrote:
>> I thought this was funny, since there was the recent discussion on
>> password strength...
>> http://xkcd.com/936/
> People on the XKCD forums have posted links to several online "password
> strength meters". These are mostly of the type where you get a +10 point
> bonus for using uppercase and lowercase, but a -N penalty for every N
> consecutive characters of the same type, but then there's also a score
> for...
> to break your password. After all, /that/ is what most unsophisticated
> attackers are going to use against you.
This is the truth.
A better philosophy in creating a password IMO is to come up with a
sentence that includes capitalization and punctuation. This makes it
harder for a computer to brute force it, I think.
~Mike
Date: 17 Aug 2011 09:59:10
Message: <4e4bc92e$1@news.povray.org>
> This is the truth.
As people on the forums have pointed out, a worrying number of things
have a /maximum/ password length. (!) Quite apart from taking a long
time to type a whole sentence, many systems won't allow you to use one
as a password.
(That said, PGP and GPG [yes, those are real product names] don't even
ask for a "password"; they want a "passphrase".)
The method I generally use is to take a complete sentence, but only type
the first letter of each word, plus any punctuation that might be
present. This has the unfortunately result that all my passwords tend to
start with an uppercase letter and end in a full spot. On the other
hand, how many password crackers are going to try "TSHwmygI." as a password?
Well, that rhetorical question is one I'd like to answer. But not on my
employer's VMs, apparently...
Date: 17 Aug 2011 16:18:51
Message: <4e4c222b@news.povray.org>
> as a password.
  For a very long time unixes used only 8 character passwords at most.
(You could write more, but everything after the 8th character was ignored
and could thus be anything.)
  I think most modern unixes have lifted this limitation.
Date: 17 Aug 2011 16:37:21
Message: <4e4c2681$1@news.povray.org>
The way you do a cryptographic hash is to take a symmetric key algorithm and
use the password as the key and encrypt a constant. The result is a hash.
(Of course, there are other ways, but given (say) DES, this is a way to use
DES as a hash.)
The original unix cyrpt (and later DES) were used this way to generate
password hashes, and that's the reason UNIX tossed more than 8 characters.
Just for general edification. :-)
Date: 17 Aug 2011 18:06:21
Message: <4e4c3b5d$1@news.povray.org>
If I'm not very much mistaken, obsolete versions of Windows did
something similar. Like, when you *set* your password, it uses only the
first 14 characters and ignores the rest, but when you *enter* your
password for authentication, it uses all 14 characters...
...in other words, if you set a password containing more than 14
characters, you just locked yourself out of the network. Until you
figure out that by typing only the first 14 characters, it lets you in
again. Like, WTF?
Since Windows XP and higher use Kerberos, a protocol designed by people
who have a clue, I'm guessing this kind of stupidity is gone now...
http://blog.orphi.me.uk/
Date: 17 Aug 2011 18:17:41
Message: <4e4c3e05$1@news.povray.org>
>> ignored and could thus be anything.)
> again. Like, WTF?
Yep, you do remember correctly, in fact, I think I wrote something
similar in this very thread. :)
Well, I remember in Windows Server 2000 (with the first release of AD)
that there were circumstances where NTLM authentication would be used
instead of Kerberos, and it wasn't always predictable.  So you could
actually end up with a real authentication nightmare in a distributed
environment (which is what I was dealing with) where you might change
your password and then try to authenticate using NTLM, but the PDC
Emulator hadn't received the update (depending on your sync schedules and
such), and since the PDC Emulator was used for NTLM authentication, you
could lock yourself out and not even realise that you were setting the
password using one method and trying to authenticate using the other.
I *hope* they got that sorted out (and would be surprised if they
didn't).  We duplicated that in the lab with Microsoft Consulting at the
time....
Jim
Date: 18 Aug 2011 04:17:49
Message: <4e4ccaad$1@news.povray.org>
> environment
Ah yes. I think I recall there may have been some difference between how
Windows NT and Windows XP authenticate. Maybe that's the issue I was
remembering...
I haven't seen this problem in a long time. Then again, I haven't tried
to set a really long password. (And I doubt anybody else has.)
I also have a vague recollection that NTLM didn't like certain
characters in a password. But I don't remember which ones.
Date: 18 Aug 2011 13:20:17
Message: <4e4d49d1$1@news.povray.org>
>>> people who have a clue, I'm guessing this kind of stupidity is gone
>>> now...
>> environment
> remembering...
That could be.
Now that you mention it, I think I ran into that as well.
Jim
