POV-Ray : Newsgroups : povray.off-topic : Password difficulty Server Time
14 May 2026 04:19:42 EDT (-0400)
  Password difficulty (Message 21 to 30 of 37)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Password difficulty
Date: 12 Aug 2011 14:21:49
Message: <4e456f3d@news.povray.org>
On Fri, 12 Aug 2011 18:18:00 +0100, Orchid XP v8 wrote:
>>> (Obviously, before you try breaking people's passwords "for real",
>>> there are various political issues to consider. But I didn't even get
>>> as far as /testing/ the tool, since the AV classes it as "greyware".
>>> Which I suppose is reasonable.)
>> Indeed, the proper way to do this in a production environment is to get
>> the approval of management so they know what you're doing and why.
>> It's a 'security audit' or 'password audit'.  You don't want to get
>> caught doing any kind of penetration testing on your company's network
>> without TPTB being aware of it - that can lead to serious consequences
>> (potentially personal legal liabilities for that matter).
> Sure. But first I wanted to check whether the tool I've picked actually
> /works/, and have a bit of a play around with it. /Then/ I might see
> about using it on real passwords...
That's what a lab server is for (ie, a server in an IT lab, not a server
in the lab you work for <g>).
You might have to disable the AV software, since it's 'greyware' (that's
a term I've not heard before, but presumably it means 'this is a hacking
tool', to which one might say 'well, duh!').
Jim
Date: 12 Aug 2011 14:29:10
Message: <4e4570f6$1@news.povray.org>
> in the lab you work for<g>).
That's what VMware is for. ;-)
I'm guessing if I boot up a Linux VM and ask it to install the Linux
version of the tool, the AV won't know what just hit it. (I don't think
it scans network traffic, only actual files. On the other hand, maybe it
will recognise the data in the disk image? But on the first hand, I
doubt it scans for Linux threats, only Windows ones...)
http://blog.orphi.me.uk/
Date: 12 Aug 2011 16:56:43
Message: <4e45938b$1@news.povray.org>
>>> actually /works/, and have a bit of a play around with it. /Then/ I
>>> might see about using it on real passwords...
>> server in the lab you work for<g>).
You're learning.  I remember not too long ago when you thought what VMware
did was impossible so not worth even trying out. ;)  And yes, VMware does
make an excellent lab environment.
>> (that's a term I've not heard before, but presumably it means 'this is
>> a hacking tool', to which one might say 'well, duh!').
Yeah, that would probably work as well.
Jim
Date: 13 Aug 2011 05:41:56
Message: <4e4646e4$1@news.povray.org>
I still find it surprising that VMware manages to run software at nearly
native speed. Other emulators I've seen are way, way slower...
It still amuses me that I can run Linux under QEMU, and it's *still*
fast enough to run DOOM with software rendering. ;-)
Date: 13 Aug 2011 14:25:48
Message: <4e46c1ac$1@news.povray.org>
>> VMware did was impossible so not worth even trying out. ;)  And yes,
>> VMware does make an excellent lab environment.
VMware doesn't emulate, that's a big difference.  The code runs natively
in many/most cases.
Computers are pretty speedy these days.
Jim
Date: 15 Aug 2011 04:21:42
Message: <4e48d716$1@news.povray.org>
> in many/most cases.
...until it performs any kind of kernel-mode operation, presumably.
(Which would be ALL THE TIME, more or less.)
That's my point, yes. ;-)
The old POV-Ray benchmark (skyvase.pov) used to take /hours/ to run,
unless you had a cluster. Today it can be run in a few split seconds.
It's so fast it's useless as a benchmark. Now that's progress...
Date: 15 Aug 2011 12:52:57
Message: <4e494ee9@news.povray.org>
>>> nearly native speed. Other emulators I've seen are way, way slower...
>> natively in many/most cases.
Ring 0 has to be emulated, yes, but with various hypervisors implemented
in hardware now, that "emulation" is done by hardware.
Indeed it is.
Jim
Date: 16 Aug 2011 19:05:32
Message: <4e4af7bc@news.povray.org>
On 8/11/2011 11:17, Jim Henderson wrote:
> On Thu, 11 Aug 2011 09:09:01 +0100, Invisible wrote:
>> Personally, I think the most /realistic/ way to gauge password strength
>> is to see how long it takes real, commonly-available password crackers
>> to break your password.
> Arguably that's the most accurate way, but not the most realistic way.
However, I know a number of corporations that will try to crack your
password each time you change it and if they can, they'll make you change it
again. You just get an email after a couple days saying "change it or get
locked out."
   How come I never get only one kudo?
Date: 16 Aug 2011 20:24:05
Message: <4e4b0a25@news.povray.org>
>>> strength is to see how long it takes real, commonly-available password
>>> crackers to break your password.
> change it again. You just get an email after a couple days saying
> "change it or get locked out."
Yeah, that's a different approach - and not necessarily a bad one.
Jim
Date: 17 Aug 2011 09:50:38
Message: <4e4bc72e$1@news.povray.org>
On 8/11/2011 3:09 AM, Invisible wrote:
> On 11/08/2011 03:27 AM, Chambers wrote:
>> I thought this was funny, since there was the recent discussion on
>> password strength...
>> http://xkcd.com/936/
> People on the XKCD forums have posted links to several online "password
> strength meters". These are mostly of the type where you get a +10 point
> bonus for using uppercase and lowercase, but a -N penalty for every N
> consecutive characters of the same type, but then there's also a score
> for...
> to break your password. After all, /that/ is what most unsophisticated
> attackers are going to use against you.
This is the truth.
A better philosophy in creating a password IMO is to come up with a
sentence that includes capitalization and punctuation. This makes it
harder for a computer to brute force it, I think.
~Mike
