Subject: This is, in part, why many Windows updates require reboots
Date: 4 Aug 2011 21:45:24
Message: <4e3b4b34$1@news.povray.org>
http://neugierig.org/software/chromium/notes/2011/08/zygote.html
Check out the third paragraph.
How come I never get only one kudo?
Subject: Re: This is, in part, why many Windows updates require reboots
Date: 5 Aug 2011 00:17:33
Message: <4e3b6edd$1@news.povray.org>
It's a shame he doesn't get the Linux pieces down very well.
The package manager, for example, doesn't control whether files are
replaced or deleted - what he's seeing is part of the standard filesystem
behaviour. I could just as easily cause the problems he describes by
deleting necessary files while a program is running.
Similarly, his assertion in the last paragraph is laughably funny - ask
any user of Slackware whether the apps they use are 'lame ports of
Windows apps" because they're all installed through tgz files.
And what he asserts about Chrome and Chromium not working well together
shows a lack of understanding of packaging dependencies for RPM and DEB
packages. They *could* well set up a dependency that says not to install
if Chromium is installed (or to identify the packages as non-compatible).
Jim
Date: 5 Aug 2011 11:12:28
Message: <4e3c085c@news.povray.org>
If the program is keeping the file open, then deleting the file won't
affect it. However, if it's a file that the program opens and closes
repeatedly during its execution, then that's indeed the case.
Date: 5 Aug 2011 14:37:38
Message: <4e3c3872$1@news.povray.org>
>> I could just as easily cause the problems he describes by deleting
Yes, and that's the case regardless of whether it's the user at the
console doing it or a package manager doing it. :)
Jim
Date: 5 Aug 2011 16:31:11
Message: <4e3c530f$1@news.povray.org>
> behaviour.
Nah. I can overwrite a config file, or I can write a new file and rename it
to be the config file, and these are entirely different things on Linux. The
package manager just happens to do the latter.
The whole story is basically:
1) We can't just fork, because glib and other libraries might have locks
open, and in that case things with threads break, and we use threads.
2) We can't just fork+exec, because if we exec, we get the new version of
the executable which expects the new versions of files and it might not
communicate well with the existing running processes.
3) So instead we start a helper process to hold open all the old versions of
files because that's the only way to keep them from being deleted once
they're unlinked, and the package manager unlinks old versions of files. And
stuff often breaks if we forget to make sure every file we might need gets
versioned this way.
Date: 5 Aug 2011 16:35:14
Message: <4e3c5402$1@news.povray.org>
>> what he's seeing is part of the standard filesystem behaviour.
> it to be the config file, and these are entirely different things on
> Linux. The package manager just happens to do the latter.
Sure, but he's describing the behaviour as a package manager behaviour,
when in fact it's an OS/filesystem behaviour.
> of the executable which expects the new versions of files and it might
> not communicate well with the existing running processes.
> versions of files because that's the only way to keep them from being
> deleted once they're unlinked, and the package manager unlinks old
> versions of files. And stuff often breaks if we forget to make sure
> every file we might need gets versioned this way.
But that's not what he wrote, and in writing it the way he did, he got
some things wrong. <shrug> It happens, but it's important to understand
how he got them wrong so the above makes sense.
Jim
Date: 5 Aug 2011 16:46:57
Message: <4e3c56c1$1@news.povray.org>
What "behavior" do you think is enforced by the file system that isn't a
choice of the package manager?
> some things wrong.<shrug> It happens, but it's important to understand
I think that's pretty much exactly what he wrote. I didn't see anything he
actually got wrong.
Date: 5 Aug 2011 17:19:33
Message: <4e3c5e65$1@news.povray.org>
> behaviour.
Or, to put it another way...
% echo alpha > alpha ; echo beta > beta
% (sleep 20 ; cat ) < alpha &
% sleep 3 ; cp beta alpha
What does "cat" print?
% sleep 3 ; mv beta alpha
They're both standard file system behaviors. It's the choice of the package
manager to use one technique over the other, not the choice of the file system.
Date: 5 Aug 2011 21:59:30
Message: <4e3ca002@news.povray.org>
That of allowing files to be deleted while they're open. I don't "think"
that's a choice of the package manager, because it is in fact how *nix
filesystems work, regardless of what the app thinks about it.
>> understand how he got them wrong so the above makes sense.
> he actually got wrong.
I guess we'll have to disagree on it. I read his description and found
that it made no sense at all, and I'm not exactly a newbie to Linux....
Jim
Date: 5 Aug 2011 22:00:43
Message: <4e3ca04b@news.povray.org>
> package manager to use one technique over the other, not the choice of
> the file system.
Yes, it's a choice of whether to rename the file or delete it. That's
not really my point.
Jim
