POV-Ray : Newsgroups : povray.off-topic : All your radix are belong to us! Server Time
10 Sep 2025 23:59:59 EDT (-0400)
  All your radix are belong to us! (Message 1 to 10 of 27)
Subject: All your radix are belong to us!
Date: 22 Jul 2011 06:50:49
Message: <4e295609$1@news.povray.org>
http://blog.llvm.org/2011/05/what-every-c-programmer-should-know.html
http://blog.llvm.org/2011/05/what-every-c-programmer-should-know_14.html
http://blog.llvm.org/2011/05/what-every-c-programmer-should-know_21.html
...OK, I'm scared. o_O
http://blog.orphi.me.uk/
Subject: Re: All your radix are belong to us!
Date: 22 Jul 2011 11:28:20
Message: <4e299713@news.povray.org>
  Why?
Date: 23 Jul 2011 06:29:55
Message: <4e2aa2a3$1@news.povray.org>
>    Why?
A language where the language spec specifically allows you to optimise
away bounds checks, null checks and so forth in the name of performance?
Yeah, sounds fairly scary to me.
Not having these things automatically is one thing. Automatically
removing them when the programmer explicitly added them is another. And
apparently even the "experts" get surprised by this behaviour, so...
Date: 23 Jul 2011 10:59:45
Message: <4e2ae1e0@news.povray.org>
> >    Why?
  If you access first and check bounds afterwards, that's kind of a bit
late, don't you think? That's the whole point. If you access before making
the bounds check, then the compiler can assume that the checking is useless.
(The check won't do anything useful because the accessing has already been
made by that point, so the check won't retroactively make it work.)
  If you make the check first, and only then access based on that, then the
compiler cannot make the assumption.
  Well, if the code is accessing out of boundaries, there's a bug. If there's
such a bug, the compiler is free to do whatever it likes. There's nothing
surprising about that.
Date: 23 Jul 2011 13:13:04
Message: <4e2b0120$1@news.povray.org>
In the first example, he reads, then checks, then writes, and it's not
unreasonable to think that he's ensuring the write isn't out of bounds
because the read is harmless.  (Yes, there are still architectures where
*NULL does not trap.)
It is to a large number of people who work with safe languages. :-) Even
more surprising to people who work with languages where having an index out
of bounds doesn't even make sense, let alone be "a bug".
   "Coding without comments is like
    driving without turn signals."
Date: 23 Jul 2011 13:36:47
Message: <4e2b06af@news.povray.org>
  But there are many architectures where dereferencing null will trap,
which is why the C standard does not want to force it either way (in
other words, it does not want to force compilers to add a check to each
dereferencing to see if it's dereferencing null, and then either cause
an abort() or some other defined behavior).
  If dereferencing null is normal in a certain architecture, then compilers
made for that architecture should take that into account (which the standard
fully allows, obviously).
  (As always, this is a compromise between efficiency and safety. If the
standard said "thou shalt not dereference null, or you'll be abort()ed",
then every single pointer and array access would become slower.)
  Then these people either have to learn C properly, or not use it.
It really is a case of "take it or leave it".
Date: 23 Jul 2011 13:40:21
Message: <4e2b0785@news.povray.org>
Yes, I know that. :-)
I didn't say it's normal. I said it's something someone who knows the
hardware might expect and thus be surprised by the compiler deleting
completely different code.
If I compiled something like that first version for a Z-80, I can easily
believe I would be surprised if that code ever wrote to the interrupt
vector.  I'm not criticizing C. I'm simply saying it's reasonable to be
surprised. :-)
Yes. I'm simply pointing out to people who know C very well why it would be
that people who don't know it very well might be surprised. Heck, code like
that wound up in the Linux kernel, so I think it's save to say "it sometimes
surprises even experts", yes?
Date: 23 Jul 2011 13:51:37
Message: <4e2b0a29@news.povray.org>
  But wasn't it a bug, rather than an intentional "trick" which the
programmers didn't realize would trigger undefined behavior?
Date: 23 Jul 2011 19:05:04
Message: <4e2b53a0@news.povray.org>
Yes. It was a bug caused by the programmer not knowing a null pointer check
would not wind up in the object code, because they accessed the pointer
first. I.e., it was pretty much exactly the contains_null_check code on the
second link.
I.e., I'm pretty sure anyone committing code to the Linux kernel "knows C
properly."  It really is a surprising language.  Saying "real programmers
never make this sort of mistake" is a no-true-scotsman argument.
I'm not saying anything is *wrong* with C or the decisions the standards
committee made. Just that expressing surprise that it's as tricky as it is
doesn't imply you're ignorant.  "Real programmers think C isn't surprising,
because if you're surprised by C, it means you're not a real programmer."
Date: 24 Jul 2011 06:22:44
Message: <4e2bf274@news.povray.org>
  We are probably using a slightly different meaning for "surprised".
  Everybody makes errors, and sometimes those errors happen because you
don't know the language well enough. The error would be a surprise if you
make that latter kind of error, and you have never heard of that feature
before, so it catches you by surprise. It's not a surprise if you already
knew about that language feature, but didn't realize it comes into play in
a complex piece of code. (The difference would be that after you resolve
the situation you think "ah, true, it indeed is that language feature
kicking in", so it's doesn't surprise you, rather than "I didn't know that
feature even existed".)
