POV-Ray : Newsgroups : povray.off-topic : Three guesses why Server Time
14 May 2026 06:38:50 EDT (-0400)
  Three guesses why (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Three guesses why
Date: 17 Jun 2011 04:12:02
Message: <4dfb0c52@news.povray.org>
On 16/06/2011 10:40 PM, Warp wrote:
>    One thing I thought of:
>    A programming language/compiler cannot automatically parallelize all
> possible programs given to it in the most optimal way.
Sure. But parallelism doesn't necessarily have to be "automatic". Doing
it manually is OK, so long as you make it really easy to specify what
you actually want. That works.
> Some problems are more
> easily parallelized in an automatic way, while others are much harder.
Quite. GPUs have been merrily parallising a large class of important
algorithms for decades now. It's no secret that only certain algorithms
fit the GPU model, but when they do, boy do they go fast!
On the other hand, how do you make your word processor go faster? Hell,
*can* you make your word processor go faster? From what I've seen, the
thing that usually slows these down is I/O latency (possibly due to lack
of RAM forcing you to use virtual memory). Adding more CPU power is
going to do nothing about that.
> This is just a fact
> (and I wouldn't be surprised if such an optimization problem would be
> at the very least in the NP category
It took me a moment to think about this one. My initial reaction was
"isn't the NP category only defined for *sequential* algorithms?" And
then I realised that the process of transforming a program could very
well be a sequential algorithm, and hence amenable to classification.
OOC, how many problems can you name for which there is no known optimal
algorithm? How many problems provably cannot be solved optimally?
>    It may even be that in some situation you might even want just the
> program using one core if it can't use the others efficiently, so that
> you can run something else on the others, than the one program hogging
> everything for itself, making other programs run more slowly than they
> would have to.
Even for programs which do run faster in parallel, due to Amdahl's law,
there's usually a point at which adding more cores does not improve
performance. So you probably don't ever want to say "use as many cores
as I have", because that tends to be pessimal. You probably want to
choose the optimal number of cores for each particular program.
>    This automatic parallelization may be also give the false illusion of
> efficiency, when in fact it's far from it. After all, you will see the
> program using 100% of all the cores. That's pretty efficient, isn't it?
> Of course this is just an illusion. CPU usage percentage doesn't necessarily
> directly translate to efficiency.
Quite.
> (And in fact, I think there are examples of programs which actually run
> *slower* on multiple cores than on one core, even though they are using
> 100% of CPU time on each, as contradictory as that might sound.)
This is not a theoretical idea. This is something which commonly happens
in the real world.
Spawn two threads. Have one thread compute the odd-numbered elements of
an array, and the other thread compute the even-numbered elements. This
way, the work is split in half, right?
Except now each CPU core continuously invalidates the other core's L1
cache lines, causing constant memory traffic and hence very high
latency. It's probably vastly slower than just doing all the work in one
thread.
Of course, the solution here is pretty trivial; rather than interleave
the elements, split the array in the middle and have one thread process
each half. If the elements really are independent, you should now see a
50% speedup.
In case this sounds like the kind of mistake only a novice would make,
consider GHC's new parallel garbage collector. Initially they programmed
it to use all available cores. But they quickly discovered that due to
locality issues, performance was rubbish. It turns out to be *faster* to
let cores sit idle rather than generate lots of cache traffic sometimes.
(The solution they eventually implemented was that each core has its own
heap, and garbage-collects it in parallel. At least, for the first
generation. The second generation has a shared heap, which is still
split into "chunks" and collected in parallel.)
Date: 17 Jun 2011 16:50:07
Message: <4dfbbdff$1@news.povray.org>
Is your word processor really not fast enough?
Spell check in one thread, layout of pages you haven't looked at in another
thread, etc.  I think they're already making it faster, if you actually
watch Word or Reader open a big document, for example.
> From what I've seen, the thing
I find that's almost all of the slow-down, actually. Have you seen the video
of the SSD RAID array? Where they open all four office programs with
documents in about half a second?  Where they open every program installed
on the computer in about 10 seconds?
>> This is just a fact
> It took me a moment to think about this one. My initial reaction was "isn't
Sort of. A NDTM isn't exactly a sequential machine.
If it's NP, it's going to be NP on any fixed number of processors. Only if
you let the number of processors scale with the size of the problem does it
come into question. (Granted, that's how a lot of SIMD theory is defined.)
Certainly all the problems that can't be solved can't be solved optimally.
Otherwise, you can always brute force all possible answers and pick out the
optimal one, assuming you have a way of generating answers and evaluating
their relative merits.  I think your question is too ill-specified to be
answered clearly, tho.
> performance.
Certainly having more cores than the number of instructions the program
executes is going to be pointless, so mathematically speaking, the law
*always* applies, even if it's silly in practice to take it to that
exaggeration.
> Except now each CPU core continuously invalidates the other core's L1 cache
> lines, causing constant memory traffic and hence very high latency. It's
> probably vastly slower than just doing all the work in one thread.
And for people who don't have a technical background:
http://blogs.msdn.com/b/ericlippert/archive/2011/06/16/atomicity-volatility-and-immutability-are-different-part-three.aspx
> generation. The second generation has a shared heap, which is still split
GC is definitely one of the harder problems out there. :-) One of those "in
theory it's easy, in practice getting good performance is really hard."
   "Coding without comments is like
    driving without turn signals."
Date: 18 Jun 2011 07:49:53
Message: <4dfc90e1@news.povray.org>
> exaggeration.
  I don't think it works like that. Of course each CPU runs the *same* code,
but each on different input data (or partially different, as some of the
input data may well be shared among the threads, only some parameters being
different; POV-Ray 3.7 would be a perfect example of this).
  Perhaps you meant that having more cores than the amount of generated data
would be useless (because each processor has to output at least one bit of
data to be useful). Since generated data typically has quite many bits, it's
not like you would hit this limit any time soon.
Date: 18 Jun 2011 07:55:20
Message: <4dfc9227@news.povray.org>
  I wonder what gives you that impression.
  The first GPU to support programmable shaders was the GeForce 3 Series,
released in 2001. Back then support for implementing more-or-less generic
algorithms with these shaders was very limited.
  As programmable shader languages were improved, the possibilities
increased, and there were quite many "hacks" to make programmable shaders
do something else than to paint pixels, but it probably was not until CUDA
was published that there was "official" support for generic algorithm
programming on GPUs. The first GPU supporting CUDA was the GeForce 8800
Series, released in 2006.
Date: 18 Jun 2011 15:56:54
Message: <4dfd0306$1@news.povray.org>
>> exaggeration.
I was speaking entirely theoretically. Amahl's law says you only get so much
speed-up, no matter how many CPUs you throw at it. If the sequential program
executes 100 billion instructions over the course of solving the problem,
giving it more than 100 billion processors cannot possibly speed it up any
farther.
Sort of like an O(n) question ignoring the constant factor sort of discussion.
Exactly. That's why I said "mathematically speaking."
When I studied SIMD algorithms in school, the assumption was that you always
had N processors, where N was the same number you were giving to O(N) sorts
of calculations.
Date: 21 Jun 2011 03:55:44
Message: <4e004e80$1@news.povray.org>
> released in 2001.
OK. So the early ones were entirely hard-wired. They're still using
parallel processing to solve a real-world problem. My point was that
some kinds of algorithms are very easy to solve with parallel processing.
Date: 21 Jun 2011 04:31:13
Message: <4e0056d1$1@news.povray.org>
Sometimes. (Depending on which one I'm using.)
> another thread, etc. I think they're already making it faster, if you
> actually watch Word or Reader open a big document, for example.
I wonder if anybody has fixed that thing where closing the CD drive
causes the entire Windows OS to lock up for 30 seconds yet?
I'm just bitter because our document management system requires you to
open a Word document that lives on a Windows share at HQ. Of course, for
all the people at HQ, that's just a subnet away. But for everyone
else... SMB over a WAN is not fast. 5 Mbit/sec bandwidth and 105 ms
latency is not fun with such a chatty protocol.
> Have you seen the
> video of the SSD RAID array? Where they open all four office programs
> with documents in about half a second? Where they open every program
> installed on the computer in about 10 seconds?
I do remember configuring my Amiga 1200 to boot from a RAM disk. Jesus,
that was fast...
> optimally. Otherwise, you can always brute force all possible answers
> and pick out the optimal one, assuming you have a way of generating
> answers and evaluating their relative merits. I think your question is
> too ill-specified to be answered clearly, tho.
OK, so a problem would be provably impossible to solve if the search
space is infinite or if there's no way to enumerate all possible solutions?
>> performance.
> exaggeration.
Sure. My point was that for some programs, adding more cores yields more
speed, at least until you reach ridiculous limits. For other programs,
adding just one or two cores means you already reach that point.
> "in theory it's easy, in practice getting good performance is really hard."
I think the fundamental thing is that GC wants to traverse pointers
backwards, but the heap structure only allows you to traverse them forwards.
Other than that, we keep getting processors with more and more cores,
but exactly the same amount of memory bandwidth. This seems very
unsustainable.
Date: 21 Jun 2011 13:41:44
Message: <4e00d7d8@news.povray.org>
  Scanline rendering is easy to parallelize because all the pixels can be
rendered independently of each other (not unlike raytracing).
Date: 21 Jun 2011 13:55:45
Message: <4e00db21$1@news.povray.org>
On 6/21/2011 1:31, Invisible wrote:
> I wonder if anybody has fixed that thing where closing the CD drive causes
Yes. They call it "NT".  Your flaw is thinking the entire OS is locked up,
when it's really just explorer waiting to read the disk.
> WAN is not fast. 5 Mbit/sec bandwidth and 105 ms latency is not fun with
Yeah. Try starting up SunOS and X Windows on a 4-meg sparcstation with no
internal disk paging over the 10Mbps ethernet.  Ninety seconds to switch
window focus?
> I do remember configuring my Amiga 1200 to boot from a RAM disk. Jesus, that
> was fast...
Amazing how when you get rid of the moving parts and the simulation of
moving parts it goes really fast.
> OK, so a problem would be provably impossible to solve if the search space
It would be provably impossible to solve via brute force, sure. That's
exactly what keeps the halting problem from being solved, in at least some
sense.
Beyond that, you'll have to say what you mean by "solving optimally". We
know the optimal Big-O for a number of problems. Is that what you're talking
about?
Right. My comment was more of an aside.
I also realized yesterday, when driving past the building I tried to model
for my game that slowed the frame rate to a crawl when I actually drew it,
that the reason the universe doesn't have trouble keeping up with the
frame-rate is that it really does have N processors for a problem of size N.
How do you calculate in real time exactly what it would look like to have
light reflecting off that building built out of all those atoms?  Give each
atom the ability to process its contribution to the reflected light in
parallel.  How do you do the clipping and shadow casting in real time? Have
each atom doing the clipping and shadow casting in parallel for all the
pixels it affects. Etc.
(Yes, maybe obvious, but it kind of twinged with this conversation.)
I don't think GC wants to traverse backwards, except perhaps in purely
functional languages/heaps. GC works by starting at the roots and seeing
what's still reachable, so that's all forward pointers.
> Other than that, we keep getting processors with more and more cores, but
> exactly the same amount of memory bandwidth. This seems very unsustainable.
Yep.  That's why NUMA is getting more popular and such.
Date: 22 Jun 2011 04:07:13
Message: <4e01a2b1$1@news.povray.org>
Indeed, a great many graphical tasks parallise very well. For example,
image scaling (whether bilinear or trilinear or anisotropic or
whatever). Or DCT / inverse DCT operations [on independent pixel blocks].
Other tasks don't parallise so well.
