POV-Ray : Newsgroups : povray.off-topic : Unit Testing question Server Time
14 May 2026 06:40:14 EDT (-0400)
  Unit Testing question (Message 21 to 22 of 22)
Subject: Re: Unit Testing question
Date: 10 Jun 2011 16:11:11
Message: <4df27a5f$1@news.povray.org>
On 6/10/2011 11:26, Orchid XP v8 wrote:
> Yeah, well, Smalltalk is no functional language. ;-)
Oh, sorry, I thought we were still talking about Haskell.
Yeah, the thing is when you compile the expression #[1, 2, 3] it creates a
list and points the executable code to that, or some such.
The same thing happens with Python default arguments.
> When you define a class named Foo, it defines a global variable named Foo
> which contains a Class object describing the class.
Yes. But "global variable" is a bit of a misnomer in a language where global
variables are simply names in a hashtable that the compiler looks up at runtime.
> The fun thing is, since True and False are classes, they are also global
> variables, and you can do something like True := 42, which utterly confuses
> everything.
I think true, false, and nil are usually special-cased in the compiler
(along with ifTrue:ifFalse:, etc) for performance reasons. But yes, in
theory, you could do that.
   "Coding without comments is like
    driving without turn signals."
Date: 10 Jun 2011 17:03:15
Message: <4df28693$1@news.povray.org>
Uh, yeah. You can't do anything crazy like that in Haskell.
Worst thing you can do is unsafePerformIO. Also known as "tell the
compiler that its assumptions hold for this expression, because I say
so". Naturally, if you are mistaken... bad things happen.
> a list and points the executable code to that, or some such.
That's the one.
> global variables are simply names in a hashtable that the compiler looks
> up at runtime.
Not just the compiler. The entire runtime system. And since the IDE *is*
the runtime system...
It probably varies by implementation. I suppose I could dig out my copy
of VisualWorks if I /really/ cared...
http://blog.orphi.me.uk/
