POV-Ray : Newsgroups : povray.off-topic : Unit Testing question Server Time
14 May 2026 05:10:12 EDT (-0400)
  Unit Testing question (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Unit Testing question
Date: 10 Jun 2011 11:05:30
Message: <4df232ba$1@news.povray.org>
Le 10/06/2011 16:45, Darren New a écrit :
> On 6/10/2011 1:18, Le_Forgeron wrote:
>> For instance, in Java, you can redefine the value of 3 and 6.
> Of all the languages out there, I'm pretty sure Java isn't one of those.
> :-)  How do you redefine 3 to be 14?
three years late slogan (for the USA): Yes We Can...
http://thedailywtf.com/Articles/Disgruntled-Bomb-Java-Edition.aspx
basically:
import java.lang.*;
           Field field = Integer.class.getDeclaredField( "value" );
           field.setAccessible( true );
           int i=3;
           field.setInt(i,14);
Integer a = 2;
Integer b = 3;
System.out.println( a + b );
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 10 Jun 2011 11:12:12
Message: <4df2344c$1@news.povray.org>
e.
> basically:
> import java.lang.*;
>             int i=3;
>             field.setInt(i,14);
> Integer a = 2;
> Integer b = 3;
That's not redefining the value of 3 and 6. That's redefining the value o
f
Integer(3) and Integer(6).  The expression "2 + 3" will still return 5.
Note that in Fortran and FORTH at least, it's pretty trivial to make the
literal 3 refer to the value 15.  (By "pretty trivial" I mean "you might
do
it by accident.")
   "Coding without comments is like
    driving without turn signals."
Date: 10 Jun 2011 11:18:03
Message: <4df235ab@news.povray.org>
> of Integer(3) and Integer(6). The expression "2 + 3" will still return 5.
> do it by accident.")
I think Smalltalk will also let you accidentally redefine 3 to mean
something else. (Certainly if you operate on array literals, it
permanently changes the literal to refer to something other than what it
says!)
Haskell will definitely let you define, say, 2+2=5. You'd be hard
pressed to do this "by accident" though...
Date: 10 Jun 2011 11:49:28
Message: <4df23d08$1@news.povray.org>
> something else.
I think anything the parser sees is hard-coded, but I could be wrong there.
> Haskell will definitely let you define, say, 2+2=5. You'd be hard pressed to
And what does this result in?  Is it just that the expression "2+2" matches
before "<integer> + <integer>" or some such, so 2+2=5 but 2+3=5 also?
"By accident" is pretty easy in fortran. All values, including literals, are
passed by reference to a subroutine, so if the subroutine assigns to
something that's a literal, you probably just changed the global value of
that literal. (I.e., in most fortran implementations, "3" refers to an
anonymous global variable that holds the value "3".)
In FORTH, you just write
     : 2 3 ;
So, "the subroutine named 2 now returns 3".  The way the parser works is
that if it can't find the name of a routine, it then tries to parse it as a
literal. But if it finds the name of a function, it uses it. Not something
you're likely to do by accident unless you mess up some metaprogramming.
Date: 10 Jun 2011 12:27:55
Message: <4df2460a@news.povray.org>
  And some people criticize C++ because it supports operator overloading,
which could potentially be used to make operators do something else than
what they seem...
Date: 10 Jun 2011 13:19:28
Message: <4df25220$1@news.povray.org>
> what they seem...
Yeah, I always thought that was a fairly stupid critisism...
http://blog.orphi.me.uk/
Date: 10 Jun 2011 13:23:41
Message: <4df2531d$1@news.povray.org>
>> something else.
I did something like define a method that returns #[1 2 3], and then I
took the result and manipulated it. To my surprise, the method now
returns the new, manipulated value, instead of what it claims to return. (!)
Apparently you shouldn't do that.
> matches before "<integer> + <integer>" or some such, so 2+2=5 but 2+3=5
> also?
You can define a new number type, and have it implement arithmetic any
way you desire. This works because "2" is not an integer. It's a number.
It's *any* number type.
As insane as that sounds, I have actually /used/ this myself. I
implemented a type called HalfInteger, which supports numbers rounded to
the nearest 1/2. So if you say "7", it really stores it as 14. And if
you say "half", that's really one. And if you do "7 + half", you get 15.
Ah, but of course, it doesn't /look/ like 15. It looks like 7.5 (via the
various interfaces that let you inspect it).
The fun part is deciding what the result of half * half should be...
> an anonymous global variable that holds the value "3".)
Isn't that almost exactly what Smalltalk does with [at least] class names?
Date: 10 Jun 2011 14:09:40
Message: <4df25de4$1@news.povray.org>
>>> something else.
> I did something like define a method that returns #[1 2 3], and then I took
> the result and manipulated it. To my surprise, the method now returns the
Especially not in a functional language? That's exactly the sort of thing a
pure functional language is guaranteed not to do. :-)
> You can define a new number type, and have it implement arithmetic any way
> you desire. This works because "2" is not an integer. It's a number. It's
> *any* number type.
I see. So it's not really the integer 2, but the lexical symbol 2 that
you're talking about.
I'm not sure what you're talking about. Are you talking about interred
strings? They're not really *quite* the same thing. FORTRAN only does that
because most machines existing when FORTRAN was created didn't have
immediate-mode machine instructions.
Date: 10 Jun 2011 14:20:21
Message: <4df26065$1@news.povray.org>
I admit, I lolled.
However, I think it's better to go way over the top than (say) to support
operator overloading without supporting literal overloading. The ability to
define "*" on complex numbers without the ability to write complex numbers
inline is understandable but feels kludgey to me.
(Yes, I know for a great many types you can essentially write them inline in
C++. I'm not necessarily talking about C++.)
Date: 10 Jun 2011 14:26:07
Message: <4df261bf$1@news.povray.org>
>> took
> thing a pure functional language is guaranteed not to do. :-)
Yeah, well, Smalltalk is no functional language. ;-)
>> way
>> *any* number type.
Basically, yes. I can make it so that when you type an integer or a
decimal, it resolves to something utterly unexpected.
Of course, monads let you do strange things to what look like simple
imperative statements. (E.g., time travel, quantum superposition, etc.)
Strangely, the Haskell list syntax is so hard-wired that you can't touch
it, however.
>> names?
When you define a class named Foo, it defines a global variable named
Foo which contains a Class object describing the class.
The fun thing is, since True and False are classes, they are also global
variables, and you can do something like True := 42, which utterly
confuses everything.
Then again, Smalltalk := Nil is always fun...
