POV-Ray : Newsgroups : povray.off-topic : Complicated Server Time
14 May 2026 06:39:27 EDT (-0400)
  Complicated (Message 33 to 42 of 52)
Subject: Re: Complicated
Date: 7 Jun 2011 12:00:01
Message: <web.4dee4a548dd72f563771cd8e0@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> On 07/06/2011 04:41 PM, Darren New wrote:
> > On 6/7/2011 8:39, Invisible wrote:
> >> This would be a rather stunning result for AI.
> > It wasn't even what you'd call AI nowadays. It was just pattern matching.
> Given that two different, unrelated recordings of the same piece of
> music have entirely unrelated waveforms, I'm not sure how you can claim
> that simple pattern matching would find such a complex similarity.
> > Why are you using the subjunctive, as if this is a fictional story?
> Damnit, now I have to go look up what a "subjunctive" is...
You're not matching the waveform but the spectrum.
Date: 7 Jun 2011 12:18:21
Message: <4dee4f4d$1@news.povray.org>
Or, in this case, "I went to the store yesterday" followed by "that would be
cool if it were possible."
   "Coding without comments is like
    driving without turn signals."
Date: 7 Jun 2011 13:22:19
Message: <4dee5e4b$1@news.povray.org>
>> Yes. And these changes are very, very precise. If they weren't, you'd
>> fall over. The fact that it does this in a feedback loop doesn't negate
>> the need for very exact, very fine controls.
> I'd say the changes are NOT precise but they are minute and the update rate is
> fast.
That's one valid way to control error, yes. But I still don't think
that's how the human brain achieves precision, for the most part.
> If the human body would be capable of precice movement then you should be able
> to repeat movements exactly every time you do them.
Yes.
> But that's not how it turns out.
Really?
> Try throwing a ball at something. You won't be able to hit the same spot twice
> in a row. If you practice very very hard, you might get close but you still
> won't hit the same spot every time.
Or how about this: Try pressing the same keys on a keyboard in the same
complex sequence, with your eyes closed.
Oh, wait... I can actually do that. And I frequently do. On a daily
basis, in fact. Obviously my brain lacks the "precision" necessary to
position my fingers to exactly align with the notes even though there's
no tactile feedback until I actually touch the key...
http://blog.orphi.me.uk/
Date: 7 Jun 2011 13:44:35
Message: <4dee6383$1@news.povray.org>
On 07/06/2011 04:58 PM, Darren New wrote:
> On 6/7/2011 8:45, Invisible wrote:
>> I'm not sure how you can claim that
> I'm not saying it would. I'm saying it *did*.
And if I told you that scientists have come up with a computer program
that can accurately estimate a person's intelligence from an analysis of
their DNA, you'd call BS. Even though you don't have a shred of proof
that it's not true, and there's no logical reason why it's impossible.
You wouldn't believe it.
And that's why when somebody says "one time I did <insert very unlikely
thing here>", people tend not to believe it.
Date: 7 Jun 2011 14:34:23
Message: <4dee6f2f$1@news.povray.org>
So, you're saying I'm lying?
Date: 7 Jun 2011 14:35:00
Message: <web.4dee6e6c8dd72f563771cd8e0@news.povray.org>
Every time you touch a key you get the feedback you need to compensate for
drift, because you feel if you were to the right or to the left of the key
center or you hit the wrong key entirely.
The same for touch typing on a computer keyboard. You wouldn't be able to do
that on a touchscreen without tactile feedback where the keys actually are.
Date: 7 Jun 2011 14:50:00
Message: <web.4dee72ba8dd72f563771cd8e0@news.povray.org>
As for precision, try the following experiment:
1. Sit in front of your computer and put your finger on a key.
2. Close your eyes
3. wave aroud wildly with your arms
4. put the finger back on the key from step one.
5. open your eyes
Did you hit the same key? I doubt it.
If you can do that than that's what I'd call precice.
Moving youf finger a few centimeters without watching and hitting a key that is
more than a finger wide is not precise.
Date: 7 Jun 2011 18:18:15
Message: <4deea3a7$1@news.povray.org>
Betting that, sans mechanical failure, or vibration, a robot would wear
down a very "tiny" spot on each keyboard, following such a complex
pattern, while humans would have a wider area of wearing. That said, the
hands, being a high use part, with specific adaptations *may* include
additional feedback, or more precise control, specifically due to the
fact that using them *requires* it. Throwing a ball is a bit different,
it requires larger muscles, more motion, usually doesn't imply/require
as much precision, and is more dependent on anomalies in the position of
other limbs, this means a much *larger* number of inputs, more variance,
and probably less precise control, since you would have to be processing
feedback for nearly every muscle in the body, to get anything close to
the same level of precision as your hands, which can remain in a fixed
position, or resting against something, which minimizes secondary movements.
Date: 8 Jun 2011 04:03:07
Message: <4def2cbb@news.povray.org>
> 2. Close your eyes
> 5. open your eyes
News flash: Robots can't do this either.
For example, a hard drive has a "servo track" recorded on one platter,
so that the read/write heads can sense where they are, since the voice
coils that steer the heads can't reliably return to the same location
with the necessary precision.
This, even though those voice coils are controlled by a normal computer,
which is capable of doing perfectly "precise" calculations.
This has nothing to do with the precision of the calculations that the
controller performs, be it a computer or a brain. It's just an inherent
result of mechanical devices being imprecise.
> Moving your finger a few centimeters without watching and hitting a key that is
You don't play a musical instrument, do you?
Let me tell you, the black keys are *narrower* than a human finger. And
if you're not careful, your fingers slip off the side. Doesn't sound
very nice...
Anyway, if that fails to convince you, try throwing a ball through a
hoop. By the time you get any feedback about whether you hit or not,
it's far too late to do anything about it; you've already let go of the
ball! And yet, many people manage to throw precisely enough to do this
reliably.
Similar story for anyone who plays darts, snooker, tennis, ...
Date: 8 Jun 2011 04:10:33
Message: <4def2e79$1@news.povray.org>
I'm saying that if you casually claim to have solved a problem which has
stumped AI researchers for decades, I'm going to be /slightly sceptical/
about it. Which seems quite rational to me...
