POV-Ray : Newsgroups : povray.off-topic : Complicated Server Time
14 May 2026 05:11:00 EDT (-0400)
  Complicated (Message 11 to 20 of 52)
Subject: Re: Complicated
Date: 6 Jun 2011 13:40:09
Message: <4ded10f9@news.povray.org>
On 06/06/2011 04:59 PM, Darren New wrote:
> On 6/3/2011 7:45, Invisible wrote:
>> (By contrast, a *real* 32-bit chip like the Motorola 68000 has
>> registers A0
>> through A7 and D0 through D7, and when you do an operation,
> Which is fine if you're not trying to be assembly-language compatible.
That's amusing. The 68000 is a 16-bit processor, which is
forwards-compatible with the 68020. You run the same code, but now all
the 32-bit operations automatically go twice as fast. It doesn't /get/
much more compatible than that. (Admittedly later processors did
introduce a few new instructions that won't work on the older models.)
>> In short, they kept kludging more and more stuff in. Having a stack-based
>> FPU register file is a stupid, stupid idea.
> Not when your FPU is a separate chip from your CPU.
In what way does having a bizarre machine model help here?
>> But now all our software depends on this arrangement,
> Not any longer. For example, I believe gcc has a command-line switch to
> say "use x87 instructions" instead of loading floats via the MMX
> instructions.
Yeah, but every OS will have to support the old arrangement forever
more, every VM product will have to support it forever more, and every
processor design will have to support it forever more.
>> Aliasing the MMX registers to the FPU registers was stupid,
> No, it saved chip space.
It's quite clear that the design motivation behind this was not chip
space but OS support. Compared to the space taken up by huge caches, a
piffling 7 registers is nothing...
>> The list goes on...
> It would be nice if it was practical to throw out all software and start
> over every time we had a new idea, wouldn't it? But then, everything
> would be as successful as Haskell. ;-)
This is precisely why Haskell's unofficial motto is "avoid success at
all costs". (I.e., once you are successful, you have to *care* about
backwards compatibility.)
I would argue that backwards compatibility is about balance. On the one
hand, if you change your entire platform every three minutes, nobody
will build anything for it. (For example, Java.) On the other hand, if
you support everything forever, you end up with an unmanageable mess.
(For example, IA32.)
I keep hoping that some day somebody will come up with a chip design
that runs crappy old 16-bit MS-DOS stuff under software emulation, but
runs real Big Boy software that people might give a damn about on a
platform with a modern, coherant design. But apparently I'm just dreaming...
http://blog.orphi.me.uk/
Date: 6 Jun 2011 14:07:09
Message: <4ded174d$1@news.povray.org>
>> Right.. There would need to be some sort of controller that could
>> transfer
>> data from Block A to Block B. Addressing would be quite ...
>> interesting in
>> this scheme.
> This is a well known problem with lots of good solutions, depending on
> how you implement the interconnections. The problem is that lots of
> algorithms are inherently sequential.
Sometimes I start thinking like this:
Why do we have computers in the first place?
To do the sorts of calculations that humans suck at.
What sorts of calculations do humans suck at?
Calculations which aren't easily parallelisable.
If this line of logic is correct... um... we may have a problem here.
Date: 6 Jun 2011 14:12:24
Message: <4ded1888$1@news.povray.org>
>>> registers A0
But that's because it has the same machine code. I'm talking about the 8086
being assembler-language compatible with the 8080.
First, it's not bizarre; it's pretty much how many (for example) VMs define
their machine language. It's called a zero-address machine. Second, it's
because the op codes don't need to have register numbers in them, so they
can be smaller and hence faster to transfer. Most mathematics involving FP
that you are actually willing to pay extra to speed up wind up being larger
expressions, I'd wager. Plus, the intermediate registers were 80 bits.
> Yeah, but every OS will have to support the old arrangement forever more,
> every VM product will have to support it forever more, and every processor
That's not all our software. That's a pretty tiny part of a context switch.
> It's quite clear that the design motivation behind this was not chip space
> but OS support.
True, in this case. But why would you say "the old OS works with new
software to take advantage of this feature" is stupid?
> This is precisely why Haskell's unofficial motto is "avoid success at all
> costs". (I.e., once you are successful, you have to *care* about backwards
> compatibility.)
That's why I mentioned Haskell. Unfortunately, real-world companies building
billion-dollar semiconductor fabs don't get to actively avoid success.
> I keep hoping that some day somebody will come up with a chip design that
> runs crappy old 16-bit MS-DOS stuff under software emulation, but runs real
> Big Boy software that people might give a damn about on a platform with a
They do. Intel chips are RISCs interpreting IA32 instructions. :-)
   "Coding without comments is like
    driving without turn signals."
Date: 6 Jun 2011 14:14:34
Message: <4ded190a$1@news.povray.org>
Am 06.06.2011 19:40, schrieb Orchid XP v8:
> dreaming...
That's what Intel tried with the Itanium.
"I'm making a note here: Huge Success."
So for the records, it was AMD who convinced people that a backward
compatible 64-bit processor would be a much better idea. And it was the
consumers who bought that message.
In the end it was the users' fear of <Insert Your Favorite 32-bit PC
Video Game Here> running slower than on their older system that won over
any rationale.
Date: 6 Jun 2011 14:27:27
Message: <4ded1c0f@news.povray.org>
>> dreaming...
As far as I can tell, the trouble with Itanium is that it had very, very
poor performance. This is not much incentive to switch.
(Which is surprising really, because on paper it looks like a really
good design...)
Date: 6 Jun 2011 14:33:33
Message: <4ded1d7d$1@news.povray.org>
Am 06.06.2011 20:07, schrieb Orchid XP v8:
Fortunately it isn't.
Humans suck at /any/ calculations requiring higher degree of precision
than rule-of-thumb estimates. The human brain is "designed" to work
/despite/ uncertainties rather than avoid or eliminate them.
However, humans also suck at understanding systems, and are much better
at understanding single entities working on a problem sequentially. At
least that's typically true for men - maybe the next generation of
computers needs women as software developers.
Date: 6 Jun 2011 14:39:46
Message: <4ded1ef2@news.povray.org>
I don't think I agree with any of this.
Pick any two locations in London. Ask a London cabbie how to get from
one to the other. I guarantee they can do it faster than any satnav
computer.
Pick up a picture of Harrison Ford. Show it to a bunch of people. Almost
all of them will instantly be able to tell you who it's a picture of.
Now try getting a computer to figure that out. Good luck with that.
The human brain is really very, very good at certain tasks. Quite
astonishingly good, when you actually think about it. But it's very bad
at certain other tasks.
I think of it as being a bit like GPGPU. The brain is a special-purpose
computational device which is absurdly good at the tasks its designed
for, and quite bad at everything else. To get good performance on other
problems, you have to artificially transform them into a problem that
"looks like" one they're good at. (A bit like the way GPGPU originally
meant encoding your data as video textures before you can process it.)
There are people in the Guinness Book of Records who can do crazy things
like compute the 72nd root of a 15-digit number in their head in under
10 seconds. It's just that most people can't do that.
Date: 6 Jun 2011 14:42:56
Message: <4ded1fb0@news.povray.org>
> define their machine language. It's called a zero-address machine.
> Second, it's because the op codes don't need to have register numbers in
> them, so they can be smaller and hence faster to transfer. Most
> mathematics involving FP that you are actually willing to pay extra to
> speed up wind up being larger expressions, I'd wager. Plus, the
I suppose if you had a really deep stack, this might make sense. You
could just keep subexpressions on the stack in their natural order, and
everything would be fine. Unfortunately, 7 deep is nowhere near enough.
You end up needing to constantly rearrange the data to avoid spilling
registers back to main memory. (The only explanation I can come up with
is that if RAM is faster than CPU, spilling is no biggie.)
>> space
>> but OS support.
Kludging the design in a way which will haunt us forever just to get a
product to market a few months faster sounds pretty stupid to me.
> building billion-dollar semiconductor fabs don't get to actively avoid
> success.
Fortunately, Haskell gave up avoiding success some time ago...
>> real
In other words, they are RISC chips with none of the advantages of RISC.
Date: 6 Jun 2011 15:02:40
Message: <4ded2450@news.povray.org>
Am 06.06.2011 20:27, schrieb Orchid XP v8:
>>> dreaming...
> good design...)
Surprising?
The concept relied heavily on compile-time optimization, which may still
have had room for optimization back then.
The CPU was designed to work with RAMbus, which turned out to have
serious initial performance problems on the RAM chip side, and AFAIK
never managed to catch up with improvements on the DDR protocol.
The CPU was a fairly fresh start, so there may have been significantly
more room for improvement in the chip design than in contemporary x86
designs.
I'm also not sure whether it was "very, very" poor performance.
Date: 6 Jun 2011 15:28:15
Message: <4ded2a4f$1@news.povray.org>
Am 06.06.2011 20:39, schrieb Orchid XP v8:
> computer.
Not a contradiction to my point; note that /those/ types of
"calculations" require almost exactly the /opposite/ of precision. Which
is the domain /computers/ suck at.
For instance, the answers from the people to whom you show the Harrison
Ford photograph will probably often contain phrases such as "I /think/
that's Harrison Ford": They fail at identifying him beyond any doubt
(i.e. /exactly/), and instead identify him with a certain "error margin".
Likewise, the London cabbie will /not/ pick /the/ fastest route. He'll
just pick a "sufficiently fast" route. Based not on parameters that can
be exactly quantified, but on experience and intuition. And not because
he /knows/ the route to be fast, but because he's /sufficiently
convinced/ it is.
Exactly. And among those "certain other tasks" is virtually anything
involving precise computations.
Yes, you /can/ train a human to do high-precision calculations. But
you'd need a huge number of such people (and a REALLY HUGE supply of
coffee :-)) to perform even the simplest multi-step calculations that way.
