POV-Ray : Newsgroups : povray.off-topic : Computer language quirks Server Time
11 Sep 2025 10:52:12 EDT (-0400)
  Computer language quirks (Message 1 to 10 of 33)
Subject: Computer language quirks
Date: 2 May 2011 13:26:39
Message: <4dbee94f$1@news.povray.org>
I find it mildly distracting that I can't do this:
void xyz() { ... }
void abc()
     if (...)
        return xyz();
     else blah blah blah;
I can do it if xyz and abc return values, but not if they don't. I have to
instead
      if (...)
         xyz();
         return;
which significantly expands a function that has lots of such dispatches. It
also makes it unclear to the casual reader that this is a tail call.
Also, I realized I tend to have larger functions than necessary because most
languages I'm using don't let me nest functions.  For example, I have an
output list, two error bars, and a point. I want to add the point (or a few)
to the list if it's within the two error bars.  I do this several times.
In Pascal or Ada or something, I could do something ilke
     MaybeAddPoint(x, y);
as the call, and MaybeAddPoint being nested would let it access the other
locals. But in C or C# or Java, I have to do
     MaybeAddPoint(x, y, errlo, errhi, output);
where errlo, errhi, and output are the same value for every call of the
function.  Hence, when it's only two or three calls, with lots of those
kinds of constant-for-all-calls arguments, I find I sometimes wind up
inlining the stuff, because that's just as clear as passing half a dozen
"parameters" that aren't really parameters at all, but rather the
environment they're working in.
   "Coding without comments is like
    driving without turn signals."
Subject: Re: Computer language quirks
Date: 3 May 2011 04:43:33
Message: <4dbfc035$1@news.povray.org>
> void xyz() { ... }
> void abc()
> if (...)
> return xyz();
> to instead
> if (...)
> xyz();
> return;
> It also makes it unclear to the casual reader that this is a tail call.
How about just
   if (...)
   {xyz(); return;}
   else...
That's slightly less load.
Of course, The Real WTF is "functions" that return void. ;-)
> most languages I'm using don't let me nest functions.
No comment. ;-)
Date: 3 May 2011 11:40:35
Message: <4dc021f3$1@news.povray.org>
Still ugly, and non-standard formatting. :-)
Like functions that return unit are better?
> No comment. ;-)
I realize that this is the primary semantic difference between "Algol-like
languages" and "C-like languages", with the use of punctuation instead of
keywords being the syntactic primary difference.
Date: 3 May 2011 11:43:04
Message: <4dc02288$1@news.povray.org>
Yeah. It's about the best you can do though.
How many of those can you name?
Date: 3 May 2011 11:50:30
Message: <4dc02445@news.povray.org>
> void xyz() { ... }
> void abc()
>      if (...)
>         return xyz();
  What's wrong with:
void abc()
     if (...)
        xyz();
  (Structured programming purists would recommend doing it like that
because there's no early return.)
Date: 3 May 2011 12:04:57
Message: <4dc027a9$1@news.povray.org>
Not many, but then I work in languages where functions can return void. ;-)
Date: 3 May 2011 12:08:33
Message: <4dc02881@news.povray.org>
On 5/3/2011 8:50, Warp wrote:
>    What's wrong with:
The "else" doesn't end the function, and I tend to have several of these in
a row, and sometimes it's inside a loop, etc.
I could restructure things, sure, but then it's even more verbose and unlike
my initial thought processes.  Structured programming wouldn't let me return
a value from the middle of the function either.  It's the asymmetry between
a return after a void call and a return after a value-producing call that is
ugly.
(I had to giggle yesterday when I added an "else break" as the last
statement of a do-while loop, too.)
Date: 3 May 2011 14:36:32
Message: <4dc04b30@news.povray.org>
  Well, if we go to the strict definition of "function", that's not the
only problem. For one, strict functions must always return the same value
for the same parameters and must not have side-effects. (Hence eg. rand()
is not a true function.)
Date: 3 May 2011 15:02:12
Message: <4dc05134$1@news.povray.org>
That too. And I would wonder how realistic it is to have a strict function
returning a "value" that the type system prevents you from ever seeing.
(I.e., the stuff you use to order calculations in a pure language like Haskell.)
Date: 3 May 2011 15:52:13
Message: <4dc05ced$1@news.povray.org>
> function returning a "value" that the type system prevents you from ever
> seeing. (I.e., the stuff you use to order calculations in a pure
I'm not sure what you're talking about.
http://blog.orphi.me.uk/
