I find it mildly distracting that I can't do this:
void xyz() { ... }
void abc()
if (...)
return xyz();
else blah blah blah;
I can do it if xyz and abc return values, but not if they don't. I have to
instead
if (...)
xyz();
return;
which significantly expands a function that has lots of such dispatches. It
also makes it unclear to the casual reader that this is a tail call.
Also, I realized I tend to have larger functions than necessary because most
languages I'm using don't let me nest functions. For example, I have an
output list, two error bars, and a point. I want to add the point (or a few)
to the list if it's within the two error bars. I do this several times.
In Pascal or Ada or something, I could do something ilke
MaybeAddPoint(x, y);
as the call, and MaybeAddPoint being nested would let it access the other
locals. But in C or C# or Java, I have to do
MaybeAddPoint(x, y, errlo, errhi, output);
where errlo, errhi, and output are the same value for every call of the
function. Hence, when it's only two or three calls, with lots of those
kinds of constant-for-all-calls arguments, I find I sometimes wind up
inlining the stuff, because that's just as clear as passing half a dozen
"parameters" that aren't really parameters at all, but rather the
environment they're working in.
"Coding without comments is like
driving without turn signals."
> void xyz() { ... }
> void abc()
> if (...)
> return xyz();
> to instead
> if (...)
> xyz();
> return;
> It also makes it unclear to the casual reader that this is a tail call.
How about just
if (...)
{xyz(); return;}
else...
That's slightly less load.
Of course, The Real WTF is "functions" that return void. ;-)
> most languages I'm using don't let me nest functions.
No comment. ;-)
Still ugly, and non-standard formatting. :-)
Like functions that return unit are better?
> No comment. ;-)
I realize that this is the primary semantic difference between "Algol-like
languages" and "C-like languages", with the use of punctuation instead of
keywords being the syntactic primary difference.
Yeah. It's about the best you can do though.
How many of those can you name?
> void xyz() { ... }
> void abc()
> if (...)
> return xyz();
What's wrong with:
void abc()
if (...)
xyz();
(Structured programming purists would recommend doing it like that
because there's no early return.)
Not many, but then I work in languages where functions can return void. ;-)
On 5/3/2011 8:50, Warp wrote:
> What's wrong with:
The "else" doesn't end the function, and I tend to have several of these in
a row, and sometimes it's inside a loop, etc.
I could restructure things, sure, but then it's even more verbose and unlike
my initial thought processes. Structured programming wouldn't let me return
a value from the middle of the function either. It's the asymmetry between
a return after a void call and a return after a value-producing call that is
ugly.
(I had to giggle yesterday when I added an "else break" as the last
statement of a do-while loop, too.)
Well, if we go to the strict definition of "function", that's not the
only problem. For one, strict functions must always return the same value
for the same parameters and must not have side-effects. (Hence eg. rand()
is not a true function.)
That too. And I would wonder how realistic it is to have a strict function
returning a "value" that the type system prevents you from ever seeing.
(I.e., the stuff you use to order calculations in a pure language like Haskell.)
> function returning a "value" that the type system prevents you from ever
> seeing. (I.e., the stuff you use to order calculations in a pure
I'm not sure what you're talking about.
http://blog.orphi.me.uk/
