POV-Ray : Newsgroups : povray.off-topic : Rare for a reason Server Time
26 Feb 2026 10:05:16 EST (-0500)
  Rare for a reason (Message 1 to 10 of 44)
Subject: Rare for a reason
Date: 23 Apr 2011 11:59:45
Message: <4db2f771$1@news.povray.org>
Pipe organs measure pitch in "feet". Bigger number = lower pitch. The
number is not /directly/ related to the physical size of the pipes,
although generally bigger numbers mean bigger pipes.
A "normal" organ stop has 8' pitch. The pipes controlled by the peddles
are normally 16' pitch (i.e., one octave lower). Most organs will also
have 4' and 2' pitches, and unless it's a really small organ, there's
usually at least one 16' stop.
Now, a *cathedral* pipe organ will have at least one 32' stop, and a
really powerful one might have several of them.
There are exactly two pipe organs in the entire world which have a 64'
stop. And here's why:
http://www.sydneyorgan.com/STH64.mp3 [Sydney Town Hall]
http://www.die-orgelseite.de/audio/atlanticcity_64ft.mp3 [Broadwalk Hall
Auditorium Organ, New Jersey]
(Many organs have a 64' stop which actually generates /harmonics of/ a
64' pitch, but only these two actually have true 64' pitch pipes.)
Worth it... :-P
Then again, the organ at Liverpool Cathedral has a 32' Double Open Bass
which the organ's designer referred to as "the expensive draft". When
played, it makes a vague fluttering sound. The louder 32' stops make a
more definite sort of noise. (As best as I can tell, from video
recordings made with professional equipment...) If 32' isn't that
useful, why bother with 64'?
http://blog.orphi.me.uk/
Subject: Re: Rare for a reason
Date: 25 Apr 2011 09:04:27
Message: <4db5715b$1@news.povray.org>
Nigel Tufnel: The numbers all go to eleven. Look, right across the
board, eleven, eleven, eleven and...
Marty DiBergi: Oh, I see. And most amps go up to ten?
Nigel Tufnel: Exactly.
Marty DiBergi: Does that mean it's louder? Is it any louder?
Nigel Tufnel: Well, it's one louder, isn't it? It's not ten. You see,
most blokes, you know, will be playing at ten. You're on ten here, all
the way up, all the way up, all the way up, you're on ten on your
guitar. Where can you go from there? Where?
Marty DiBergi: I don't know.
Nigel Tufnel: Nowhere. Exactly. What we do is, if we need that extra
push over the cliff, you know what we do?
Marty DiBergi: Put it up to eleven.
Nigel Tufnel: Eleven. Exactly. One louder.
Marty DiBergi: Why don't you just make ten louder and make ten be the
top number and make that a little louder?
Nigel Tufnel: [pause] These go to eleven.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 25 Apr 2011 15:23:59
Message: <4db5ca4f$1@news.povray.org>
And then, the harmonics of 64 are:
32, 21 1/3, 16, 12 4/5, 10 2/3, 9 1/7, 8, 7 1/9, 6 4/10,....
Date: 3 May 2011 04:45:00
Message: <4dbfc08c$1@news.povray.org>
I love how the harmonics look like completely randomly chosen numbers,
with no obvious pattern at all.
Date: 3 May 2011 08:41:22
Message: <4dbff7f2$1@news.povray.org>
64/1 = 64
64/2 = 32
64/3 = 21 1/3
64/4 = 16
64/5 = 12 4/5
64/6 = 10 2/3
64/7 = 9 1/7
64/8 = 8
64/9 = 7 1/9
64/10 = 6 4/10
Nope, no discernable pattern at all
Date: 3 May 2011 08:47:41
Message: <4dbff96d$1@news.povray.org>
> 64/1 = 64
> 64/2 = 32
> 64/3 = 21 1/3
> 64/4 = 16
> 64/5 = 12 4/5
> 64/6 = 10 2/3
> 64/7 = 9 1/7
> 64/8 = 8
> 64/9 = 7 1/9
> 64/10 = 6 4/10
> Nope, no discernable pattern at all ;)
Exactly. I mean, unless you happen to be able to compute 64/7 mentally,
which normal humans can't.
If it was notated some other way, the pattern might be more obvious. But
as it is...
Date: 3 May 2011 19:21:53
Message: <4dc08e11@news.povray.org>
Harmonics are integer multiple of the base frequency, or integer
quotients of the base wave length having integer quotient of the power.
Armonic 1 is the base signal.
Armonic 2 have twice the frequency, or half the wave length, and half
the amplitude. For 64, it gives 32.
Nothing random here, not even a bad pseudo-random. It's totaly
deterministic.
Date: 4 May 2011 04:02:05
Message: <4dc107fd$1@news.povray.org>
> deterministic.
So is a psuedo-random number generator, and yet it still *looks* random.
Date: 4 May 2011 08:22:34
Message: <4dc1450a$1@news.povray.org>
>> 64/1 = 64
>> 64/2 = 32
>> 64/3 = 21 1/3
>> 64/4 = 16
>> 64/5 = 12 4/5
>> 64/6 = 10 2/3
>> 64/7 = 9 1/7
>> 64/8 = 8
>> 64/9 = 7 1/9
>> 64/10 = 6 4/10
You're not that much younger than me, so maybe there's something
fundamentally different between the school system in the UK vs. Canada,
but in the 2nd or 3rd grade, we had to learn our multiplication tables
by heart.
Normal humans should remember that 7 * 9 = 63.
Or if they don't, they should be able to guestimate that since 64 is
rather close to 70, there's a good chance that 64/7 would be just a bit
less than 70/7, which is easy to compute.
If not, I weep for humanity.
Date: 4 May 2011 08:34:46
Message: <4dc147e6$1@news.povray.org>
> by heart.
This is almost universally regarded as one of the most useless things
you learn in school. I haven't studied this statistically, but I suspect
the majority of adults long since forgot all this stuff.
Start weeping. This kind of reasoning is apparently far beyond the
ability of most average people.
Even if it wasn't, standing there for five minutes computing tables
isn't very immediate. If, instead of notating note pitches as
wavelengths, they were noticed as, say "K * 7" or something, it would be
far more instantly obvious what the relationship is, without having to
perform complex mental arithmetic.
