POV-Ray : Newsgroups : povray.off-topic : Old fart? Server Time
14 May 2026 08:09:45 EDT (-0400)
  Old fart? (Message 98 to 107 of 117)
Subject: Re: Old fart?
Date: 20 Apr 2011 17:54:01
Message: <4daf55f9$1@news.povray.org>
On 4/20/2011 11:33, Alain wrote:
> Le 2011/04/20 14:23, Darren New a écrit :
>> On 4/20/2011 10:37, Alain wrote:
>>> Comments, comments, comments and more comments.
>>> That's the only way that code can be used as documentation.
>> Yep. And that assumes you know the right place to look in the code to
>> find the documentation. Without an overview, you wind up guessing whic
h
>> source files of which subdirectories you need to read for comments.
> You start the main with a big comment block that contains an exaustive
> overview of the project. It's then followed by a table of content and a
n
> index...
> Then, each individual source files also contains a specific overview of
 the
> function(s) of the following code, what kind of data it expect and what
 kind
> of data it's expected to return. Don't forget the local table of conten
t and
> index.
I'm at a loss as to why such would be in comments in source code, but OK.
   "Coding without comments is like
    driving without turn signals."
Date: 20 Apr 2011 18:07:54
Message: <4DAF5939.4060601@gmail.com>
On 20-4-2011 23:53, Darren New wrote:
> On 4/20/2011 13:01, Jim Henderson wrote:
>> I have to admit I like that way of looking at it. :)
> Elegantly described in detail here, along with what to do about it:
> http://www.whyprogramsfail.com/
Suspiciously absent from the blurb is 'how to prevent them'.
Suspiciously present is a foreword by a MS employee.
Coincidence? you'll be the judge.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 20 Apr 2011 22:31:20
Message: <4daf96f8$1@news.povray.org>
Actually, the beginning of the book basically says "there's lots of books
about preventing bugs. This is a book about fixing them once they happen."
He's very clear about that.
Date: 21 Apr 2011 04:11:13
Message: <4dafe6a1$1@news.povray.org>
> OK. :-)
Some people do advocate putting all your documentation inside your
source code.
On the one hand, the idea is that the documentation is more likely to
stay in sync with the source code. (E.g., if you swap the order of the
arguments to a function, the documentation is right next to it, so you
can update that as well.)
On the other hand, your source code is now littered with miles of text
which have nothing to do with the compiler error you're now getting...
Date: 21 Apr 2011 11:31:31
Message: <4db04dd3$1@news.povray.org>
On 4/21/2011 1:11, Invisible wrote:
> On the one hand, the idea is that the documentation is more likely to stay
> in sync with the source code. (E.g., if you swap the order of the arguments
> to a function, the documentation is right next to it, so you can update that
> as well.)
I have no problem with that for how the source code works.
I would object to something like storing RFC822 as comments inside your SMTP
implementation.
> On the other hand, your source code is now littered with miles of text which
Which also forces a recompile every time you change it, and means anyone
writing (or reading) technical documentation has to have access to the code,
potentially breaking stuff when they accidentally modify the file.
Date: 21 Apr 2011 11:37:53
Message: <4db04f51$1@news.povray.org>
> SMTP implementation.
Yeah, that's really not very appropriate.
>> which
> code, potentially breaking stuff when they accidentally modify the file.
I think we can perhaps summarise this:
Embedding the API reference in the source code might be a good idea.
Embedding the end-user documentation in the source code is a terrible idea.
As an aside, everyone in the Haskell world seems to document their stuff
using a tool called Haddock. Like Java's docgen (and presumably a
bazillion similar tools), it takes source code comments and builds an
API reference from it.
What it *doesn't* really let you do in a consistent way is write "this
is WTF this project actually does and how it's structured" type
documentation, which tends to be completely absent as a direct result...
Date: 21 Apr 2011 11:39:24
Message: <4db04fac$1@news.povray.org>
I may be incorrect here, but didn't Knuth embed The TeX Book in the
source code for TeX?
(This would IMHO fall under the category of "utterly inappropriate".)
Date: 21 Apr 2011 12:31:57
Message: <4db05bfd$1@news.povray.org>
Embedding overview-for-maintainers as comments distributed throughout the
project is a bad idea.  Embedding code samples as comments in the source
code is a bad idea. Embedding design decision discussions as comments is a
bad idea.
> What it *doesn't* really let you do in a consistent way is write "this is
> WTF this project actually does and how it's structured" type documentation,
That's precisely my point.
Date: 21 Apr 2011 12:33:58
Message: <4db05c76$1@news.povray.org>
> I may be incorrect here, but didn't Knuth embed The TeX Book in the source
> code for TeX?
Literate programming is something different. In that case, you simply have
one file that has both the compilable code and the documentation discussing
it, with a tool to extract the two.  If you have a programming language in
which comments are *designed* to generate books with tables of contents and
all that sort of stuff, and what you're documenting is the process of
writing the code, then sure, that's not bad.
That's not what I'd consider "comments in the code", tho.
Date: 21 Apr 2011 15:53:44
Message: <4db08b48$1@news.povray.org>
I'm not sure what the difference is.
http://blog.orphi.me.uk/
