POV-Ray : Newsgroups : povray.off-topic : Disappointed in xbox hardware Server Time
14 May 2026 06:39:22 EDT (-0400)
  Disappointed in xbox hardware (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Disappointed in xbox hardware
Date: 14 Apr 2011 12:14:45
Message: <4da71d75@news.povray.org>
On 4/13/2011 23:40, Warp wrote:
>    What do you expect of a device that is cheaper than many cellphones?
If I hadn't seen awesome and visually stunning games running on it, I'd be
less surprised. I'm not complaining about the xbox. I'm complaining that
even seemingly trivial scenes with no motion and Wii-quality graphics takes
knowing a whole lot about graphics to render at a reasonable rate.
I guess the subject line could be read in a way I hadn't intended, as a
criticism of the hardware itself rather than "I regret it's harder than I
expected." :-)
   "Coding without comments is like
    driving without turn signals."
Date: 14 Apr 2011 12:16:40
Message: <4da71de8$1@news.povray.org>
On 4/14/2011 2:23, Patrick Elliott wrote:
> Because they can't, just to use the obvious example of games, make something
> that runs fine,
I can't even figure out who "they" is or what "something" it is that doesn't
run fine.
Date: 14 Apr 2011 12:58:11
Message: <4da727a3$1@news.povray.org>
Darren New escreveu:
> On 4/13/2011 23:41, Slime wrote:
>> Are you using Direct3D?
> I'm using XNA, which is MS's .NET wrapping of Direct3D (at least on the
> xbox - I don't think it uses D3D on the WinPhone).
a-ha!  Are you sure 360 devs aren't actually coding in assembly? ;)
> Fun fact: XNA stands for "XNA is Not an Acronym."
I thought it'd mean something like eXtreme Nondisclosure Agreement. ;)
a game sig: http://tinyurl.com/d3rxz9
Date: 14 Apr 2011 13:06:35
Message: <4da7299b@news.povray.org>
  I'm wondering if part of the cause isn't XNA and C#. In theory it shouldn't,
but who knows about these things. After all, all those beautiful ginormous
games are certainly not done with XNA.
Date: 14 Apr 2011 13:19:47
Message: <4da72cb3$1@news.povray.org>
Commercial developers use C++. If you want to release a game without MS
having to approve it first, you use XNA which (a) is way easier and (b)
locks you into a set of libraries that keeps you from (for example) stealing
user data, DDOSing whitehouse.gov, erasing other peoples' saved games, or
sending their music over the internet to your server.
I thought it was funny they out GNU'ed GNU, acronym-wise.
Date: 14 Apr 2011 13:38:11
Message: <4da73103$1@news.povray.org>
I think that while XNA slows some things down, the graphics probably isn't
one of them. You have to be a little careful with memory management, but
there's enough value types that you can usually go without any per-frame
heap allocations if you're a little careful. The JIT optimizations aren't
great; certainly nothing like as good as on the PC. I don't know how fast
the CPU is, but in doing something like loading and decompressing PNG files,
my 3GHz 64-bit desktop machine runs the same code about 5x to 10x as fast.
The threading is a little wonky, in that threads won't move between cores
for example - you start a thread on a specific core and that's where it runs
(or starves, if you're not careful). I suspect the .NET framework itself
winds up taking up a fair amount of valuable memory if you're going to do a
serious game where half a gig is limiting. It doesn't unload code once
you've loaded it, so if you have a DLL for just posting your high score,
once you invoke that, it's going to take up memory while you play the second
round or whatever. (The actual graphics resources like fonts and images and
sounds can go, tho.)
Note that on Windows, where you can use stuff that's *not* part of XNA, a
lot of these restrictions disappear, too. They're just on the xbox for
sandboxing, basically.
But the graphics library itself makes you allocate vertex buffers and index
buffers, load compiled shaders as byte arrays, etc. It manages all kinds of
formats for the rendering targets and such, uses the DirectX libraries to do
a lot of the stuff like parsing .X and .FX files and compressing textures
and such. So all the underlying stuff is translated pretty much to DX calls
as far as I can tell. You have to deal with the graphics hardware at the
graphics primitives level. While there's a lot of simplification going on in
the library APIs, I don't think there's a lot that's time-consuming that you
wind up doing in C# itself.
Now if you did something even more sophisticated, like real physics or
per-triangle collision detection on a significantly-sized world, you'd
probably start seeing more limitations than I have. But in theory the JIT
should be able to turn that into code not too far off from C++, I would
think. Certainly no worse than any other C# code doing heavy math like that.
But the library calls still have you allocating a vertex buffer with a
declaration of which offsets within each vertex bind to which register in
the shaders, then filling it in a separate write-only call, assigning the
textures, then invoking the shader. And (except on the WinPhone) you can
write your own shaders in a separate C-like language (HLSL) which may very
well be what folks use to write DirectX shaders in non-XNA langauges too.
Date: 14 Apr 2011 14:15:25
Message: <4da739bd$1@news.povray.org>
have you looked into trying to use a ready-made engine instead of
rolling your own without extensive knowledge and optimizations?  Try
some demo version of Unreal or something, though I don't know if they're
compatible with XNA.
There must be a reason why game engines are highly sought and valuable
assets.
Date: 14 Apr 2011 14:27:29
Message: <4da73c91@news.povray.org>
On 4/14/2011 11:15, nemesis wrote:
> have you looked into trying to use a ready-made engine instead of rolling
> your own without extensive knowledge and optimizations? Try some demo
> version of Unreal or something, though I don't know if they're compatible
> with XNA.
They're not compatible with XNA, because XNA is *only* C# because it is
sandboxed. There are a variety of small game engines for XNA that I haven't
really looked into. (Partly because they actually cost money, and while the
amounts they cost are trivial (like $100 is not uncommon), it's more than
I'm actually likely to make on the game. ;-) (Partly because I'm doing this
more to learn than I am to write games per se.)
I've read the Unreal documentation. Looks very cool. Way beyond what's
useful for a one-player simple game.
I'm thinking of trying out some of the Bryce stuff if I do a game after this
and need some animations that are too messy to do in raw code. (So far,
opening doors and stuff I have managed to do with math.)
> There must be a reason why game engines are highly sought and valuable assets.
No doubt. One thing Unreal does that from a programming point of view seems
to be really helpful is that it turns the event loop inside out. So you can
do something like "when you bump the wall, play the rub-head animation. Then
get back to me when that finishes." That's a whole ton of bookkeeping that
you have to do manually if your base library is "update all your objects for
this frame" followed by "draw all your objects for this frame" 60x a second.
  It also has logic for path finding and stuff like that, at least in the
version I read about a couple years ago.
And of course all the level building and art sorts of things.
Date: 14 Apr 2011 19:23:02
Message: <4da781d6@news.povray.org>
>> something
>> that runs fine,
> doesn't run fine.
Uh.. They = developers, something = anything using the damn graphics
card, in this case games. Yeah, I know, the "they" might be different
people porting the things to a PC, from the console, but again.. You
don't "write" games *on* consoles, so how one can run like crap on the
development platform, but not on the end device... I just don't get it.
Date: 14 Apr 2011 23:17:51
Message: <4da7b8df@news.povray.org>
On 4/14/2011 16:23, Patrick Elliott wrote:
> Uh.. They = developers, something = anything using the damn graphics card,
> in this case games.
So you're complaining that games under Linux on the PC don't run as well as
games on the xbox? Or games under Windows don't run as well as on the xbox?
If they're expecting to release it on the xbox, and then you want it to run
as well under Linux, well, that's a problem. Especially if one targets
directx directly instead of with some thin layer that can be replaced.
I am not even sure how one does 3D graphics under X, honestly. Last I looked
at the low-level stuff, that wasn't really supported.
