POV-Ray : Newsgroups : povray.off-topic : chemistry question Server Time
11 Sep 2025 10:48:27 EDT (-0400)
  chemistry question (Message 1 to 9 of 9)
Subject: chemistry question
Date: 29 Mar 2011 17:53:55
Message: <4d9254f3@news.povray.org>
Wanted to get rid of about two cups of muriatic acid, so I dumped it
into a bucket with some dried tile grout on the sides. Forgot about the
bucket for several months. Just found the bucket and the muriatic acid
seems to have been neutralized (forearm test). There are clear, cubic
crystals inside. Anyone know what these would be?
  -Shay
Subject: Re: chemistry question
Date: 29 Mar 2011 19:39:24
Message: <4d926dac@news.povray.org>
> -Shay
After a little Google search, it seems that it's just another name for
Chloridric acid. A solution of HCl in water.
After several months, most of the acid will have evaporated or reacted
with any alcaline substance present. Grout is usualy alcaline.
Those crystals are some salts. It could be identical to common table
salt (NaCl), or be some other chlorine based salts. Some salts are
toxic, so I greatly advise you AGAINST tasting those.
Date: 29 Mar 2011 19:52:19
Message: <4d9270b3$1@news.povray.org>
http://www.youtube.com/watch?v=F6X9KcrXHwg
   "Coding without comments is like
    driving without turn signals."
Date: 29 Mar 2011 19:54:05
Message: <4d92711d@news.povray.org>
>> -Shay
Is there *any* chance the crystals might actually be calcite? I got
pretty excited when I read this post, but if they are just salts, then
bah. I was hoping the "cubes" were actually rhomboids... I honestly
didn't expect calcite to grow so quickly, but it sure would be cool :)
~Sam
Date: 29 Mar 2011 20:06:04
Message: <4d9273ec$1@news.povray.org>
>>> -Shay
> ~Sam
No, calcite's basic formula is CaCO3 (calcium carbonate), while your
cristals could be CaCl2 or some other nClx salts.
Date: 29 Mar 2011 20:08:15
Message: <4d92746f$1@news.povray.org>
Yeah! Time Bandits!
Date: 29 Mar 2011 20:24:47
Message: <4d92784f@news.povray.org>
> Yeah! Time Bandits!
"Don't touch it, it's evil!" A defining moment of a great classic :)
Date: 29 Mar 2011 20:40:17
Message: <4d927bf1@news.povray.org>
Oh well :(
I wonder if there's some way to grow calcite crystals using a saturated
calcium carbonate solution. Acids and bases usually form salts, but
there's got to be *some* way to do it. Even if it took years to grow a
small grain, it would be worth it!
Date: 30 Mar 2011 15:13:59
Message: <4d9380f7@news.povray.org>
> Oh well :(
In a laboratory, or your kitchen, it should take a mather of hours,
maybe a few days to grow any mineral crystal.
You start with a warm saturated solution, put in some nucleating bit. It
can be a grain of sand, a speck of dist, the tip of a needle,...
You sometimes need to slow down the process to get beter quality
crystals. In that case, you start with a solution at room temperature
and only rely on evaporation.
As the solution cools down and the solvent evaporate, the crystals grows.
Very simple process.
The problem you usualy face with calcite, it that it's not very soluble.
This limits the dimention that the crystal can reatch. You can
circumvent that by refreshing the solution by forcing some circulation.
You need a source area with a higher carbonic acid content that make the
calcium carmonate more soluble. Then you need a crystalisation area
where the carbonic acid evaporate into CO2, reducing the solubility of
the carbonate and forcing it to crystalise.
