I am looking for information and recommendations for a database engine.
We are setting up a relational database system that may reside on a
database server in the future.
Linux based solution preferred
Something that is easy to set up and back up and restore.
even a sql sump is ok
I will be using relationships (pk/fk) to keep data straight.
Triggers and stored procedures are a big plus.
The possibility of using GIS functionality int he future will be taken
into consideration.
What are your thoughts on a good system to use?
Two main candidates (at least for me)
- mysql
- postgresql
Please note that MySQL AB is now owned by Oracle.
Opensource derivative to mysql is mariaDB.
Both can be administered via a web interface for the common usage
(phpmyadmin & phppgadmin)
Both have triggers.
Both have stored procedures.
> into consideration.
Both have support for spatial/geometry pieces of information.
Nevertheless, support
Check for yourself:
> http://en.wikipedia.org/wiki/Comparison_of_relational_database_management_systems
(search for indexes & spatial)
Looks like you might want postgis
Unless you are ready for an oracle DB ?
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
> into consideration.
Hi Tom,
in my last project i've used MySQL and InnoDB engine.
I'm using multi column PKs and FKs and triggers.
Regards
Aydan
Be aware that you *will* get script kiddies every day or two trying to break
in via phpmyadmin. Make sure it's behind a firewall, good password, etc.
When I was running Linux servers, that and trying to break into drupal were
the only frequent 404's I was issuing.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
> break in via phpmyadmin. Make sure it's behind a firewall, good
> password, etc. When I was running Linux servers, that and trying to
> break into drupal were the only frequent 404's I was issuing.
Completely off topic, but....
I am looking into implementing a drupal site - is there much to look out
for as far as vulnerabilities?
Thanks
> into consideration.
you are very obviously asking for Postgresql:
http://www.postgresql.org/
besides being the most robust open-source DBMS out there, one of the very first
features I noticed was this strange thing called GIS. This was back then, today
I learned Postgresql comes with no GIS on its own, instead users are directed to
use it together with PostGIS:
http://www.postgis.org/
On 3/14/2011 10:16, Tom Austin wrote:
> I am looking into implementing a drupal site - is there much to look out for
I didn't do drupal. We just had people attacking our non-existant drupal
install. :-)
"That was fatal?"
>> out for
> install. :-)
Reminds me of seeing malformed URL requests to hack a windows based web
server - but the server was on Linux ;-)
I'll have to check out drupal vulnerabilities as I move forward.
Thanks
The best thing to do is keep a log of 404's (or any 400/500 error really)
that you *actually* look at relatively frequently. If you don't get many
404's, mail a summary to your inbox each day and look at it.
"That was fatal?"
Yeah, I had this also, back when I was running Apache on my laptop. Kind
of amusing...
