![](/i/fill.gif) |
Warp wrote:
> Roman Reiner <lim### [at] gmx de> wrote:
>> That depends on what numbers you are using. The number of points in the unit
>> square of rational numbers is countable, the number of points in the unit square
>> of irrational numbers is not.
> Is the set of irrational numbers in a unit square larger or equal to
> the set of irrational numbers in a unit line?
It's the same. Aleph2 = N ^ Aleph1. The only way to get a bigger infinity
is to put it in an exponent.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible <voi### [at] dev null> wrote:
> The unit square contains an infinite number of points. But is it
> countably or uncountably infinite?
I don't really understand why you are asking that. If there are uncountably
many reals in the range [0,1], why wouldn't there likewise be uncountably
many coordinates inside a unit square?
The more interesting question is if those two sets are of equal size.
If I understand correctly, the set of reals in the range [0,1] has the
same cardinality as the set of points inside a unit square, hence there
exists a one-to-one mapping between them, hence they have the same size.
(Defining the "size" of an infinite set is a bit complicated of a subject,
but an interesting one, if you are in any way into math.)
In fact, likewise they are equal to the set of points inside a unit cube,
the set of points inside a 4-dimensional unit hypercube, and so on. Even if
you had a multi-dimensional unit cube of countably infinite dimensions, the
set of points would still be the same size as the reals in the range [0,1].
Now, if the unit cube had uncountably infinite dimensions, the question
becomes more complicated. The cardinality of this set is larger than the
set of reals, but is there a one-to-one mapping between the set of reals
and the set of points inside this uncountably-infinite-dimensional cube?
I don't fully understand the generalized continuum hypothesis to such
extent as to be certain, but I think that whether such a mapping exists
or not cannot be either proven nor disproven using "regular" set theory
math (for a definition of "regular" that goes well beyond my area of math
knowledge).
![](/i/fill.gif) |
