![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Random wonderings 0x20c26764ae15b956c9a5eb7c1a237639
Date: 8 Mar 2011 15:36:40
Message: <4d769358@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> I suppose if we're not talking about real, physical space, but about
>> some mathematical abstraction, it can have whatever properties we
>> define it to have - including the point you describe not being part of
>> the set.
> Well, sure. But if you're going to start screwing with the defintion of
> "unit square" rather than using the standard "set of points whose X and
> Y are both from 0 to 1", then the answer comes out of your definition
> and you don't have to ask.
Yeah, but "from 0 to 1" in which set? The integers? The rationals? The
reals?
As you say, I guess the answer depends on how you define the question.
(Perhaps we're not even talking about Euclidian geometry, so a unit
"square" might not even be squarish...)
> Plus, I'm not sure that physical space is actually continuous, so it's
> possible such a square doesn't have a sqrt(2),sqrt(2) point either.
Ah yes, the "which mathematical abstraction actually describes the
*real* world" argument. :-D
I gather space actually has a slight negative curvature, so it strictly
isn't Euclidian...
>> Right. So you have to take some matter and mash it somehow?
> Basically. You can do it by taking some matter and slapping it together
> so forcefully it overcomes the non-gravitational forces. I'm not sure
> that's physically possible in the universe as it exists today.
Hmm, theoretical physics for the win!
>>>> But then, wouldn't that just mean that as soon as you remove the
>>>> force, it wouldn't be a black hole any more?
>>> No. Science!
>> I don't know... Normally if you remove external force, pressure
>> decreases.
> It's not pressure. It's gravity.
I know that the way black holes normally form is because matter is
crushed by gravity. But you said that to make a small black hole, you'd
need an external force to crush it instead.
Also, I'm still not getting how you can have [gravitational] black holes
of different sizes. Presumably the force required to crush matter is a
constant, so...?
>> I was under the impression that light does not require a transmission
>> medium.
> It doesn't. But it does have different speeds in different media.
OK.
>> I don't understand.
> The speed of light in a diamond is less than half the speed of light in
> free space/vacuum.
Really? I didn't think it was such a big difference! o_O
> Hence, it's possible to move through a diamond at
> faster than the speed of light in a diamond.
Ah, I see.
> http://en.wikipedia.org/wiki/Cherenkov_radiation
> It's what gives the weird blue light coming out of nuclear reactors
> underwater - particles from the reactor hitting the water at speeds
> faster than the speed of light through water.
The real world is utterly fricking weird!
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 16:06:30
Message: <4d769a56$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 08 Mar 2011 20:20:42 +0000, Orchid XP v8 wrote:
>> and
>> yes, I do check that what I was charged is what I paid. That's how you
>> (a) avoid getting ripped off, and (b) avoid finding yourself in an
>> overdraft situation.
> So, what, you literally sit down and check all of the thousands of
> transactions you make, one at a time, to make sure every single one
> matches the printed recipt?
Yes, I thought everyone does that.
> Doesn't that take an insane amount of time?
Sure, that's all I did the entire month of January.
OK, I'm being somewhat facetious here.
So realistically, no, I don't check every single item. But if I'm out
shopping, I have a vague idea of how much the items I've bought come to,
and if the receipt shows a different value than I expect, then I do get
an adjustment.
And of course, I'm the kind of person who will say "you didn't charge me
enough" in some circumstances. There's a restaurant that my wife and I
frequent, for example, and every once in a while they leave our drinks
off, so I just have them add them back in at the register (I know they're
not there because the bill doesn't include them).
I've also had occasions where a clerk has double-entered an item and not
realized it, and I use the receipt to get that corrected as well.
It's called "money management". If I don't have at least an awareness of
how much I'm spending, I might end up overdrawn, and that incurs more
fees. People make mistakes, and a receipt is a good tool for catching
those mistakes.
>>> Why is it called a "square root"? Surely "square route" would make far
>>> more sense...
>> It seems to have grown out of the old English "Rote" (there's a
>> citation circa 1425). Etymologically it derives from the French word
>> 'racine' (which translates to 'root', natch). "radix" also is used,
>> and that's latin for 'root'.
> I knew it would be French! :-P
The OED is my friend for this type of question. :-) My local library
makes the online edition available to me.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 16:14:24
Message: <4d769c30$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> isn't Euclidian...
Well, it isn't uniformly curved, for sure.
>>> decreases.
Yes. But once you have a black hole, you can take away the pressure and the
gravity will keep it "crushed". Indeed, "black hole" is the extent to which
you have to "crush" some amount of matter before the gravity alone is enough
to keep it "crushed". That's kind of the definition of a black hole.
> constant, so...?
OK, make a black hole that weighs 10x as much as the sun. Now drop 50 more
of our sun into it. Do you think the gravity will remain the same?
>>> I don't understand.
>> free space/vacuum.
The index of refraction (IOR) is the ratio of the speed of light in vacuum
to the speed of light in that material.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 16:46:34
Message: <4d76a3ba$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 08/03/2011 09:14 PM, Darren New wrote:
>> strictly isn't Euclidian...
Oh crud, I forgot about that... >_<
> the gravity will keep it "crushed". Indeed, "black hole" is the extent
> to which you have to "crush" some amount of matter before the gravity
> alone is enough to keep it "crushed". That's kind of the definition of a
> black hole.
Right, OK.
> more of our sun into it. Do you think the gravity will remain the same?
You make a persuasive argument, young man.
>>> free space/vacuum.
> vacuum to the speed of light in that material.
Sure. But I thought most things had an IOR of almost exactly 1...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 17:24:27
Message: <4d76ac9b$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Given this is a ray-tracing newsgroup, I'm rather shocked. :-)
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Mar 2011 03:36:38
Message: <4d773c16$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Umm, to keep track of what's in your account? I generally do reconcile
>> my bank statement to my register (I keep mine electronically, so it's
>> fairly simple to do)
>> I think this is basic home finance 101.
> Wait - you actually use a sophisticated electronic accounting package
> just for your home finance?
I use a single sheet in Excel.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Mar 2011 04:02:35
Message: <4d77422b@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Uh... OK... but doesn't that still take a really long time?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Mar 2011 04:07:30
Message: <4d774352$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, this is the first time I've heard of it. I don't think even my
sister does this - and she's a qualified accountant!
(Heck, my mum doesn't even bother opening her bank statements when they
arrive. Then again, I'm pretty sure that's unique to her. Strange person...)
> an adjustment.
Yeah, sure. I get that. But usually by the time you get the receipt,
you've already paid. So I'm still not sure what use the actual piece of
paper is. (Unless you're really going to check that the number on your
bank statement actually matches the number on the receipt and the card
reader...)
That doesn't happen very often. (Fortunately!) About the only time I've
seen this is in a busy restaurant. (This also just happens to be about
the only place where you get an itemised list *before* you hand over the
money.)
> those mistakes.
Oh hell, I have literally *no idea* how much money is in my account. My
technique is to just avoid spending money as much as possible.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Mar 2011 07:51:51
Message: <4d7777e7$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I only keep track of the balance in each account every month or so, I
don't put in every transaction (I check my account online every couple
of weeks for that).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Mar 2011 13:48:29
Message: <4d77cb7d$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> person...)
Of course, I was kidding, hopefully you caught that in the rest of my
reply. :-)
>> to, and if the receipt shows a different value than I expect, then I do
>> get an adjustment.
> reader...)
If I know I only bought one widget at CostCo and they charged me for 2,
then I know there's something wrong, and I can get it corrected before I
leave the store.
>> not realized it, and I use the receipt to get that corrected as well.
> money.)
You'd be surprised at how often it really happens. It's more common in
places that use a barcode scanner to scan items into the register,
sometimes it gets double-scanned (I've seen that more frequently than I
would have expected), or when an item is scanned and then a quantity
entered (for example, you buy 5 frozen pizzas and the clerk miskeys and
hits '8' instead).
>> of how much I'm spending, I might end up overdrawn, and that incurs
>> more fees. People make mistakes, and a receipt is a good tool for
>> catching those mistakes.
Well, surely that is one way that could work, as long as you don't go
into overdraft. A better way is to check your account balance
periodically (I do that as well) to make sure there's still money there.
Otherwise you also wouldn't know if someone fraudulently used your
account for something.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
