POV-Ray : Newsgroups : povray.off-topic : Time is not free Server Time
24 Jul 2026 17:09:36 EDT (-0400)
  Time is not free (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Time is not free
Date: 11 Nov 2010 12:19:14
Message: <4cdc2592@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> I always used to think that creating a data structure who's size is not
> statically known required handling it by reference. However, C++ somehow
> manages to do this by value, so it seems my assumptions are incorrect.
  No, dynamically allocated objects can only be handled with a pointer.
You can of course wrap that pointer so that it looks and behaves like
the allocated object itself, but as if handled by-value (including being
scope-bound).
  For example you can handle an instance of std::vector or std::string
by value, but internally they contain a pointer to dynamically allocated
memory (which they manage).
> In fact, thinking about it, you probably /could/ implement Haskell
> without GC. It would just be far less efficient, that's all.
  It would be less efficient because it would require always deep-copying
data when it's passed around?
> Anyway, as an example: Consider the function
>    linear a b x = a*x + b
> You probably think that this function takes three numbers and returns a
> number computed from them. Strictly speaking, this isn't true; in fact
> this function takes three numbers and returns /an expression/ containing
> them. What the caller actually gets back is a reference to the root of
> an expression tree. For example, if I do "linear 2 3 5", I get back a
> reference to the root of a tree that looks like
>      *   3
>    2   5
> If I try to /use/ this value, this will execute the (+) function. The
> first thing this does is inspect its arguments, which causes the (*)
> function to execute. After it executes, the tree looks like
>     10   3
>    2   5
> There are now two items of garbage: the 2 and the 5. Further, after (+)
> finishes executing, we have
>        13
>     10   3
>    2   5
> So now there's 4 items of garbage (2, 5, 10, 3).
> The real situation is of course a bit more complicated than this, but
> you get the idea.
  It looks like a really inefficient way of computing a simple calculation.
Date: 11 Nov 2010 12:47:15
Message: <4cdc2c23$1@news.povray.org>
Warp escreveu:
>   Isn't that what I said above? You write as if I had said the exact
> opposite (ie. that languages using references don't need GC).
doh!  I read it wrong...
a game sig: http://tinyurl.com/d3rxz9
Date: 11 Nov 2010 15:38:38
Message: <4cdc544e$1@news.povray.org>
Basically. Deep-copying and duplicating.
If I say
   X is a list [1, 2, 3]
   Y is a list prepending 0 to X
   Z is a list prepending 9 to X
then X is still out there only once, and Y and Z point to it. Lists are
"linked lists" rather than array-like lists.
>> you get the idea.
It's a lazy calculation. Hopefully the compiler can figure out when it
doesn't actually need to do that.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 11 Nov 2010 16:59:41
Message: <4cdc674d$1@news.povray.org>
However, as I understand it (keeping in mind that I don't actually know
Haskell) it does have the implication that it can be much harder to
reason about the efficiency of a program, since it depends quite a bit
on what tricks the compiler can use.  This is in contrast to a language
like C where the relative simplicity of the compiler means that the
approximate performance is much more obvious.
It seems like a pretty common double-edged sword.  Smarter systems often
allow you to do things more easily at the cost of the need for more
mental space required to know when the smart system will fail and how to
correct it.
Date: 11 Nov 2010 17:20:30
Message: <4cdc6c2e$1@news.povray.org>
Yep.
> correct it.
I think the best model is something SQL-like. Where you express the
semantics of what you want, and then in a separate place say "by the way,
here's hints to make it faster."
It's also the case that, generally speaking, there are on occasion things
you can make more efficient in a higher-level language than a lower-level
language, simply because there's more information about intent there. As in,
it's way easier for C to micro-optimize my call to memcpy() than it is to
micro-optimize my while loop that does semantically the same thing. And it's
way easier for the SQL interpreter to figure out the best access pattern
than it is for my C compiler to analyze my code along with the BDM to figure
out how to optimize access.
Unfortunately, there are relatively few high-level languages that actually
give you the option of telling the system how best to optimize stuff, even
tho the concept has been around for ages.
   Serving Suggestion:
Date: 12 Nov 2010 04:33:54
Message: <4cdd0a02$1@news.povray.org>
> scope-bound).
I see. (I think!) So, presumably, when you copy std::vector "by value",
all it's actually copying is the reference to the real data?
That's one reason.
The other reason is that Haskell expressions are not restricted to being
*trees*. They can be general *graphs*. This is how you implement a
common sub-expression such that it only gets computed once - a very
useful thing to be able to do (obviously). I'm not quite sure how this
would interact with a non-GC implementation.
>> you get the idea.
It is. That's why there's an entire optimiser pass dedicated to removing
all these steps if possible. If a, b and x are just plain ordinary
integers, it's highly likely that the final machine code will just chuck
those variables into machine registers and do the usual binary
arithmetic directly.
Of course, all of this graph reduction /is/ pointless for a simple piece
of arithmetic. But if we choose a less trivial example, it becomes clear
why it's useful. For example, that old chestnut of the Fibonacci
function where the output depends on the output. That's impossible in a
normal language, but trivial in Haskell.
(Obviously no programmer in history has actually /needed/ the Fibonacci
numbers. And if they did, there's a well-known O(1) algorithm for them
anyway. It's just an example.)
Date: 12 Nov 2010 06:46:15
Message: <4cdd2907$1@news.povray.org>
> ...and now I'm reading about Agda, a programming language which has
> MELTED MY MIND! >_<
Idris is similar, with moderately less mind-meltation. Even so, all of
the documentation is clearly written for somebody already familiar with
the idea and just wanting to learn the actual syntax.
Date: 13 Nov 2010 08:44:38
Message: <4cde9646@news.povray.org>
  It's provable (no, not a typo of "probable", different thing) that, in
the general case, the problem "will this line of code ever be executed?"
is an unsolvable problem. Hence a compiler can make that decision only
in the most trivial cases.
Date: 13 Nov 2010 08:51:09
Message: <4cde97cc@news.povray.org>
  Actually, when you assign an std::vector object to another, whether it
performs a deep-copy of the data or if it uses some copy-on-write mechanism
to perform lazy copying depends on the library implementation, but AFAIK
most if not all library implementations use deep-copying.
  Thus, if you assign one std::vector object to another, all the data it
contains will be copied as well.
  Of course if you want copy-on-write instead, then you can create your own
"vector" which does that. (I have actually done precisely this for some
projects because of the benefits of this technique.)
Date: 13 Nov 2010 09:28:11
Message: <4cdea07b$1@news.povray.org>
More tractable is "if X is executed then Y is definitely executed". For
example, the arguments to (+) [over integers] will always be executed.
Therefore, any code that calls (+) can just pass two integers, rather
than bothering to build a graph of heap objects to pass.
It would be one thing if the compiler knew about the special properties
of built-in functions like (+). But in fact it performs a "strictness
analysis" pass which infers this information for all user-written code.
http://blog.orphi.me.uk/
