POV-Ray : Newsgroups : povray.off-topic : Mini-languages Server Time
1 Jul 2026 06:24:06 EDT (-0400)
  Mini-languages (Message 21 to 30 of 108)
Subject: Re: Mini-languages
Date: 10 Nov 2010 04:08:51
Message: <4cda6123$1@news.povray.org>
On 09/11/2010 10:11 PM, Warp wrote:
>    *Using* a parser library for something which can be easily expressed with
> a regexp string would be complete overkill.
Yeah, that's true. Writing
   string "foo"
   many char
   string "bar"
is drastically harder than just saying "foo*bar".
Oh, wait...
Date: 10 Nov 2010 04:15:37
Message: <4cda62b9@news.povray.org>
On 08/11/2010 05:31 PM, Darren New wrote:
> Invisible wrote:
>> I'd much prefer to see a much bigger separation between what's a
>> literal character and what's a command.
> Technically, they're all commands. The letter "s" means "match against
> the letter s." :-)
Well, if you wanted to split hairs, it's the implicit command "match
against a specific character" plus the argument "s". :-P
>> you could probably use it to match against streams of other data, not
>> just characters.
> You can.
Not in any regex product I've ever seen. (Although I won't claim to be
an authority on the subject.) Most people seem to equate "regex" with
"shorthand for writing text parsers".
>> A quick inspection of Wikipedia suggests that POSIX ERE involves at
>> least .[]^$()\*{}?+|:, which is 16, not 10. (Still, it's not the
>> thousands it seemed like last time I tried to learn this stuff.)
> : and {} and ^ $ aren't original regular expression characters.
> Technically not + either, so I think that's where the 10 come from. The
> rest are short-cuts for what you can already otherwise specify (: + {
> }), or are useful for programming but outside the theory (^$).
So much for theory. Most "regular expressions" out there aren't even
regular. I don't know much about the theory; what I know about is the
actual regex tools that you can actually use.
>> I recall reading somewhere that Perl's "regular expressions" aren't
>> actually regular, and so require exponential time for matching. Truly
>> regular expressions apparently require only linear time.
> Correct. And not only exponential time, but memory as well. A regular
> expression is regular because it requires a fixed amount of memory to
> match or reject.
Is that the definition of "regular" then?
>> The other thing I dislike is that people seem to have a tendency to
>> use regexs where they should be using a real parser.
> Yes, well, that's because people are stupid, not regexps.
> Only stupid people. Learn regexps, and learn the theory behind them, so
> when the boss asks you to write a parser, you know which one to use.
My boss well never, ever ask me to write a parser. (Mostly because he
doesn't know what one is, or that such a process is actually necessary.)
Regardless, if you're trying to do complicated parsing, you should use
real parser tools, not a regex.
Now if you just want to do a quick wildcard search, then why not? It can
be useful to be able to say, for example, DELETE *.PNG or something. But
by the time you get to the point where your search term is practically a
predicate calculus, you really shouldn't be trying to encode the entire
thing as a flat character string. You should use a real language instead.
Date: 10 Nov 2010 10:28:52
Message: <4cdaba34@news.povray.org>
>    string "foo"
>    many char
>    string "bar"
> Oh, wait...
  Nice straw man. (And "foo*bar" still doesn't mean what you think it means
as a regex.)
Date: 10 Nov 2010 10:45:26
Message: <4cdabe16$1@news.povray.org>
>    Nice straw man.
Wasn't his problem that he didn't have a brain?
> as a regex.)
So, what, it means
   string "fo"
   many (char 'o')
   string "bar"
Or am I reading this wrong?
Date: 10 Nov 2010 10:54:36
Message: <4cdac03c$1@news.povray.org>
You don't even use text regular expressions, so that's not very
authoritative. ;-)
Seriously, any DFA is the equivalent of a regex.
> Most people seem to equate "regex" with "shorthand for writing text parsers".
Sure. But exactly the same theory works for any stream of tokens. You can
use most modern libraries to match, for example, unicode, which includes
chinese, so right there you're outside the "text" area, let alone if you
write your own parser.
> regular.
Sure they are. Unless you use a back-escape (i.e., substitute in something
that you earlier matched) then it's all regular. Stuff like {} and + are
just trivial macros to reduce typing.  I think I use a backmatch maybe once
every two or three years interactively, and I don't think I've ever used one
programmatically.
>> match or reject.
Wikipedia is your friend. But yes, that's part of the definition. A language
is regular if it can be matched by a DFA.
Again, it depends what you're trying to parse. Are you trying to parse a
file full of lines like
structure_size = 37
structure_drift = 92.7E13
etc?  A regexp will do just fine.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 10 Nov 2010 10:57:54
Message: <4cdac102$1@news.povray.org>
>> expressed with
>   string "foo"
>   many char
>   string "bar"
> Oh, wait...
OK, so how do you do
(\+|-)[0-9]+(\.[0-9]+)?(E(\+|-)?[0-9]{1,3})?
in your parser language?
(That is, optional sign, one or more digits, optional decimal point followed
by one or more digits, optional E followed by optional sign followed by one
to three digits.)
   Serving Suggestion:
Date: 10 Nov 2010 11:28:45
Message: <4cdac83c@news.povray.org>
  Btw, it's a surprisingly little known fact that at least in C and C++
things like 10. and 10.e5 are valid floating point literals (besides the
more usual .1 form).
  If you wanted to take that into account in a regexp like the one above,
it actually becomes a bit verbose (so that a lone . wouldn't be considered
a valid floating point literal). Basically you need to write the above twice
(with slight differences, and the two parts separated with a |.)
Date: 10 Nov 2010 11:53:35
Message: <4cdace0f$1@news.povray.org>
OK, that's one big ol' complex regex, right there.
> followed by one or more digits, optional E followed by optional sign
> followed by one to three digits.)
If I've understood the spec correctly, it's
   do
     option (char '+' <|> char '-')
     many1 digit
     option (char '.')
     many1 digit
     option (do char 'E'; option (char '+' <|> char '-'); many1 digit)
Enforcing that the exponent is less than or equal to 3 digits would be
slightly more wordy. The obvious way is
   xs <- many1 digit
   if length xs > 3 then fail else return ()
Notice that since this is written in a /real/ programming language and
not a text string, we can do
   sign = char '+' <|> char '-'
   number = do
     option sign
     many1 digit
     option (char '.')
     many1 digit
     option (do char 'E'; option sign; many1 digit)
and save a little typing. You can also factor the task into smaller pieces:
   exponent = do
     char 'E'
     option sign
     xs <- many1 digit
   number = do
     option sign
     many1 digit
     option (char '.')
     many1 digit
     option exponent
You can also do things like write a function that builds a special kind
of parser given a simpler spec.
With a regex, on the other hand, you cannot even statically guarantee
that a given string is even a syntactically valid regex. And that's
before you try to programmatically construct new ones. :-P
Date: 10 Nov 2010 12:55:46
Message: <4cdadca2@news.povray.org>
>   do
>     many1 digit
>     option (char '.')
>     many1 digit
Hmm, now which one is more readable?
Date: 10 Nov 2010 14:25:47
Message: <4cdaf1bb$1@news.povray.org>
I would think at the worst you'd need to write the part before the "E" twice.
   Serving Suggestion:
